Old 12-06-2005, 05:44 PM   #1
No dregs in a 65 Safari
1965 22' Safari
corral de tierra , California
a 65 Safari in need
Hello, I just recently acquired a '65 Safari that is in need of a lot of attention. A lot starting with inverter, converter, batteries, bed, sofa, water pump, I'm sure some re-wiring and plumbing, and, and and . . . Doing the work and building everything is no problem. I'm looking for a recommendation on the best manual or two that help me put this big suppository back on the road. I'm not looking for original equipment. I'm looking for modern, functional and to code. Ive looked on Amazon and other websites, but Im not entirely happy with what I see.
I would also like to find someone within driving distance from Monterey, CA that has a similar trailer so that I can take some pictures for reference
Thx,
tim
NoDregs is offline   Reply With Quote
Old 12-06-2005, 05:53 PM   #2
Remember Burma Shave!
driftwood's Avatar
2006 19' Safari
2000 25' Safari
1985 25' Sovereign
Fort Myers , SW.Florida
Images: 35
Rivet
NoDregs,
Go HERE for interior & exterior pix of most everything you need.
If there are specific 65 Safari pix you require, email me your needs & I will attempt to accommodate you. (click on 'driftwood' to left & use drop down box)
For specific repair of items and equipment, you may be best served to utilize the search tools, located at the top right of each page. Most times the ‘advanced search’ is more direct.
Good luck with your repairs & refurbishment. & welcome to the Forums.
NORM #3305
"... there is nothing you can't fix yourself ...
... if you're handy ...
... with a check book! ..."
driftwood is offline   Reply With Quote
Old 12-06-2005, 06:10 PM   #3
1965 22' Safari
thx
Thanks Norm,
My first project is to install a water tank so that I can build a bed over it. The last owner removed it and sealed the water intake on the outside skin. He ran water direct from a hose. I also have no controls for bypassing the water pump. But then again, I have no water pump. I'm assuming the water pump bolts down in the rear compartment under the toilet. If you could fire me over a picture of the what the rear compartment is supposed to look like, that would be great. From that I can somewhat reverse engineer it.
I did pick up the manual for the trailer that gives a rough diagram of the plumbing, electrical and such. I can plumb it and wire it to those specs, but it's the controls that have me at a temprary road block.
I should also say that this is my first venture into trailerdom. I'll have to follow this up with you later. I have a house being shown this weekend and I need to rush off from work and install a water heater. I'll definately be getting back with you. thx again,
tim
Old 12-06-2005, 06:40 PM   #4
driftwood's Avatar
2006 19' Safari
2000 25' Safari
1985 25' Sovereign
Images: 35
Rivet
Provide me with an email address ... so I can attach pix. If your going to place a new tank in the original position, I have a tank source for you.
The 12VDC pumps, although originally located in the rear, are designed to 'push' better than they are to 'pull' fluids. You may want to consider locating the pump forward to one side of the tank. Free's up space in the rear.
This pix is of the original tank installation. You are looking forward, of course.
GEE! A California hot water tank install - don't forget to secure it for the earthquakes!
Name:	FW Tank-Inca quote pix.jpg
NORM #3305
Old 12-07-2005, 01:04 PM   #5
1965 22' Safari
No Earhtquakes in California
Hi Norm,
Thanks for the heads up on the pump. It'll be easy to mount it next to the tank. I vaguely remember that pumps always need an on and off switch for when they are used. Is that still the case?
This weekend I'm looking at ordering a 30 gallon tank. I picked up a 5.7 Sureflo pump that supposed to be super quiet. Once I have the tank, I'll build a bedrame with drawers around it.
Keep you posted. thx Earthquakes are a fig newton of everyone's imagination. They don't exist. It's all hype to keep the population under control.
tim
patterson@orchidsandwine.com
Old 12-07-2005, 02:41 PM   #6
driftwood's Avatar
2006 19' Safari
2000 25' Safari
1985 25' Sovereign
Images: 35
Rivet
After months of research, I located a near perfect dimensional match for the original tank. My requirement was for all the fittings to be on one end. I also wanted to restore the as-original sight level indicator. (The new tank has 4 electrical contacts imbedded in the tank end if you wish to install an unreliable electronic level indicator)
My pump is being located within the dead space, outboard the tank - street side, where the fittings are. (fill, pump supply, vent, & sight level tubing).
I located my power switch on street side + from the galley basin. It it a rocker type and 'lit' when in 'on' position. Further, I placed an in-line fuse at the pump.
PS. I was in Oakland October '89 - no earthquakes huh? That bridge sure did 'rock-&-roll' for some reason.
ID:	16932   Click image for larger version
NORM #3305
Old 12-07-2005, 02:57 PM   #7
1965 22' Safari
OK, dumb question,
Old 12-07-2005, 03:00 PM   #8
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
That was a good question!
Tom
Old 12-07-2005, 03:05 PM   #9
driftwood's Avatar
2006 19' Safari
2000 25' Safari
1985 25' Sovereign
Images: 35
Cool
HEY Tom,
OK, dumb question ..., reminds me of THIS Thread. Best I ever saw in this Forum. See post #1.
NORM #3305
Old 12-07-2005, 03:11 PM   #10
TomW's Avatar
1967 26' Overlander
Yeah Norm, I thought about that post too.
Tom
Old 12-07-2005, 04:27 PM   #11
1965 22' Safari
You guys are hurting my feelings. I wrote that with lemon juice. Hold a candle behind the monitor to heat it up. What can I say, it's a Monterey thing.
tim
2003 Safari 25' Melvin P. Thorpe 2003 Safari 24 09-15-2007 10:53 AM
Safari VS. Classic Questions kkrogh Our Community 24 12-20-2005 11:10 AM
Towing my 1964 Safari - what tow vehicle do I use Neenm Tow Vehicles 6 06-28-2002 04:26 PM
Problem with electrical system (1965 safari) rslaymaker Electrical - Systems, Generators, Batteries & Solar 4 06-13-2002 05:49 PM
Where do you suppose they put the antenna jack -'73 safari ? Chuck 1969 - 1973 Safari 14 06-13-2002 11:34 AM
