Hi, to ALL,
We're new to this, so please bear with us until we get to know how things work.
OK, on Saturday we take delivery on a '98 AS 30' Excella 1000. From What we can tell, our GVWR is 8300# and our 'Dry Weight" is 7205. Now, it has a 60Gal. water tank (501# full) and 2 30# Propane Tanks and 2 Batteries weighing about 40# each. Is it true that our allowance for gear will be 8300 less 7205 less 501 less 60 (Propane) less 80 (Batteries) or a net of 454#? That's pretty tight. We'd like to know how others deal with this. And, also we'd like to know if we've done something wrong in the math.
Any comments & feedback will be appreciated.
We've held off on buying the tow vehicle (A Long Bed, Extended Cab pickup of some sort) until we're sure we understand what's needed.
Hi, to ALL,
Walt
It's not a bleak as you think. I have the same trailer (97 30' Excella). My typical road weight runs about 73-7400 lbs on the tandems with slightly less than 1000 lbs of tongue weight. It's true that Airstream raised the GVWR on these trailers in later years (it's 10,000 lbs now). I'm not saying that you should ignore the GVWR, I just wouldn't worry that much about it as long as you don't overpack.
A sidebar concerning these trailers. This model Airstream has the lowest percentage of tongue weight of any of the wide-body Airstreams. Hitch setup is CRITICAL! The trailer must be either absolutely level or even slightly nose down when attached to the tow vehicle. The hitch MUST transfer some of the tongue weight to the front axle of the tow vehicle.
Steve Heywood
Buckeye, AZ
2005 Ford F250 CC Powerstroke
1997 30' Excella (SOLD)
When you say "It's true that Airstream raised the GVWR on these trailers in later years (it's 10,000 lbs now).", does that mean they just recalculated with different safety margins, or did they actually change something in the suspension?
I've read that 10 to 15% of the trailer weight should be on the hitch and I was planning on 12%. This seems to fit with your obsservations (ie. about 1000#).
How much Linens, cookware, clothing, Blenders, fishing rods, etc. weight do you load? Your 7400# indicates 195# over the dry weight. Do you travel with an empty water tank?
According to Airstream (I got these figures from the AS factory website) both the 97 & 98 30' Excellas weigh 6810 lbs dry with a 610 lb tongue weight. The tongue weight is included in the dry weight.
When I said 73-7400 lbs on my tandems AND nearly 1000 lbs of tongue weight you need to add the two together to get my trailer total road weight. I'm pushing 81-8300 lbs TOTAL when I'm loaded. As long as I'm well under my axle ratings I don't worry too much about my total weight. My tongue weight observations are a "SWAG", in other words I've never dropped the trailer and gotten an exact tongue weight. I know that it's less than 1000 lbs, just not sure how much less.
My trailer has 225/75-15 load range D Marathons (just like the 06 Classics). Airstream specs 50 PSI cold, I run a minimum of 55 PSI.
I know from experience (used to own a slide-in camper) that we carry about 800 lbs of "stuff" inside the trailer plus water and LPG. I travel with a full or nearly full water tank as we dry-camp every chance we get.
I checked this morning and my blog page is working fine. AOL won't let you access outside pages by clicking on them. Open a seperate browser and you can access it without problems. This was one of the many reasons I gave up AOL so many years ago.
Steve Heywood
Buckeye, AZ
That prior response to Steve should have said "I know more than I did".
I hope that name means you have 2. You have a lot of posts -- I appreciate that since I do Excel VBA postings (Backed off lately)!
Thanks for the response. I wish I didn't have the math right! That really is tight. We're OK with more in the truck, but need to know -- how much if we want to have 2000# ceiling on gear? Looks like ~1500# is real. The truck buy is critical.
Learning is a GOOD thing - tell me more please,
Walt
If it's good stuff others should find, please post to the forum. If it's very specific (And not relevant to others), please write me at: xlsWalt@aol.com
airsteam did change things...
they used axles with higher ratings and wheels and tires with higher ratings...
i'm not sure if they modified the frames in any way or spec'd different frames...from the vendor.
for example the 34s were uprated in 05 by a 1000lbs or so just by doing axles, wheels and tires...i've got one....
so IF i owned a unit with more limited carrying capacity...
and IF i wanted to upgrade it...
if and when the brakes need work or tires are toast...
i'd consider going to wheels/tires with higher limits,
then add rubber torsen axles with higher ratings...
this would cost 3-5 grand....and i'd call the factory service center for expert opinions on IF this would work....
but it might just be easier to enjoy the trailer 'as is' for a few years and then trade for one with higher ratings...
the same issues exist for the 3/4 ton truck...some years have higher payloads because of bigger axles, tires, wheels...
so you will need to do the math of the tv too.
cheers
2air'
__________________ all of the true things that i am about to tell you are shameless lies. l.b.johnson
I have a 2004 30' Classic, with an 8700# GVWR and a 600# carying capacity, per the trailer's specs.
However, I believe the published weights are theoretical, and do not reflect any options that may have been included (or perhaps deleted) from the standard "base" trailer. It's probably best to go to a CAT scale and have your trailer weighed when it is fully loaded as you'd normally expect to travel.
The problem I have is that when I've loaded everything in my truck and trailer (F250 4x4 PSD) my truck is slightly overweight, and I'm approaching the theoretical total weight limits of the truck and trailer combined. However, having made several cross country trips, including driving up and down the Rocky Mountains in the western US and Canada, I've not yet incurred an actual problem.
I ordinarily do not carry water in any of my holding tanks - the fresh water tank alone holds just over 500#.
Do the 8300# GVWR and the fact that about 1000# is on the tongue/hitch mean that the axles/wheels/tires are really only rated at about 7300#?Thanks,Walt
well the brain wheels are turning now...thinking is good.
short answer no.
your trailer axles and oem tires were rated to carry the full gvwr...
and the fact that 10-15% of that load
should be near the front for ideal towing characteristics,
doesn't mean you're allowed to add more stuff beyond the gvwr...
it is important to think in terms of the weakest link...
tires, wheels and axles are rated for the fully loaded figure...
trailer brakes are expected to slow/stop the fully loaded trailer...
packing that load properly gives good handling
w/d systems help redistribute tongue mass to the steering wheels/axles and the trialer axles...
receiver and hitch and safety chains also must be properly rated..
w/d must be at or near tongue weight..
and many try to stay 10-20% under all the limits...
others are right at them and still safe...
and so on...
flyfisher advice to visit a scale and measure weights is very important...
steer axle, drive axle, trailer axles, tongue, trailer, truck and total rig.
and some measures with various w/d systems....
while he mentions being near/over on the truck...
understanding the truck rating and how they evolve is important...
the 2000 superduty psd and the 2005 sd psd have basically the same frame...so why a higher rating on the newer model?
well, a little more power/torque, bigger brakes, higher rated axles and springs to match.
so my view is that means the 2000 may have a longer brake distance or accelerate slower
or wheel bearings may wear a little quicker or truck brake pads ....over the long term...
but springs, axles, brakes and tires could be uprated as aftermarket mods,
and exhaust, timing and air intake changes could bring power up...
no one wants to blindly violate the ratings...but understanding them is useful just like getting on the scales.
there is lots of good info in the archives here...search or browse the towing threads...
cheers
2air'
My truck weighs 6800 lbs wet but otherwise empty, my wife, 4 year old son, and 1 small dog were in the truck. About 300 lbs of stuff in the bed of the truck. I was not in the truck when it was weighed.
Steve Heywood
Buckeye, AZ
The rig configuration I'm working toward is a bit unusual. The boat and it's trailer are hauled up into the pickup bed by a winch and rail system, then the Airstream hooks on normally. Below are the calcs I'm working with so far (Copied in from an Excel sheet - the graphic of the rig wouldn't load here).
I hope this works.
Walt
Ford F250 5.4 Gas SCab LB 4.1 Axle 4x2 / 1998 Airstream Classic Excella 1000 30'9/8/2006 14:41Unused
CapacityVehicleGCWR (Combined Wt)18,0001,496
I hope this works.
Walt
Ford F250 5.4 Gas SCab LB 4.1 Axle 4x2 / 1998 Airstream Classic Excella 1000 30'9/8/2006 14:41Unused CapacityVehicleGCWR (Combined Wt)18,0001,496
Walt,
Here's my take on your proposed combination. Unless you have already found this combination (5.4 V8/4.10 gears) on a dealer's lot you will have to order it. 18 months ago when I was shopping for a truck I attempted to find this combination and came up dry. If you have to order it you will pay closer to MSRP than if you take a truck already on the dealer's lot. Just because Ford says that you can move 18,000 lbs with the 5.4/4.10 combination doesn't means it's a good idea.
Based on my experience with my rig I'm REALLY GLAD I bought a diesel. With a combined weight of over 15,000 lbs my rig moves SMARTLY but I never forget that I have an 8,000 lb + trailer behind me. My truck produces 570 lb ft of torque at only 2000 RPM, 205 lb ft MORE than the 5.4 makes @ 3750 RPM. Besides the quantity of power available from the diesel it's the quality. When my engine upshifts at 3300 RPM (a RPM level a gas is just starting to wake up at) it comes down ABOVE it's torque peak and keeps accellerating. When traffic forces me to slow when climbing a 6% grade I have enough power on tap to get back to speed, with a 5.4 if you loose speed in the mountains YOU'LL NEVER GET IT BACK!
If you absolutely do not want a diesel then save your sanity and buy the V10 with at least 4.10 gears.
Steve Heywood
Buckeye, AZ
