Old 03-20-2015, 04:54 PM   #1
Question '89/'90 345 LE Rear A/C drain tube
Hi, I'm trying to determine the location where the rear a/c unit drain tube is located both at the unit and where the tube exits down below. Thanks!
Bikerlarry is offline   Reply With Quote
Old 03-22-2015, 06:47 PM   #2
3 Dog Nite's Avatar
1989 34.5' Airstream 345
Cleveland , Tennessee
My 89 345 has the Coleman Super Mach series model 6798 Air conditioner. I believe they are original. If you have the same or similar, I may be able to help. You have to remove the lower cover and control assembly. The inside tube location is in the divider section where hot air goes uo in and cold air comes out of the vent area. It looks like a square that's divided into 2 rectangles with a 2" divider. This divider is a gray plastic on mine. If you're looking to clear out a plugged drain, go at it from above. I took the plastic cover off from the roof and was able to clean leaves and other debris from the divider drain parts with my hand.
The lower end of the drain is above the tag axle on the driver side. I blow the line out at the beginning of every season. Do this by putting the air line on the lower end near the tag axle.
"Sometimes I wonder if the world is being run by smart people who are putting us on, or by imbeciles who really mean it." Mark Twain
AIR 22749 WBCCI 2349 NOVA TAC TN-6
1989 345 LE Classic Motorhome
3 Dog Nite is offline   Reply With Quote
Old 03-23-2015, 06:40 AM   #3
Yes they are the original units. Thanks Three Dig Nite!
How do I clean my AC drain tube? tyndalelady Furnaces, Heaters, Fireplaces & Air Conditioning 67 05-13-2013 11:55 AM
Rubber drain tube near H2O hookup - what is it? mendosoft All Argosy Trailers 13 07-17-2008 08:27 PM
Coleman TSR Mach 3 Drain tube bertro Furnaces, Heaters, Fireplaces & Air Conditioning 3 06-07-2008 10:57 AM
drain tube for ac ?? PeteL Furnaces, Heaters, Fireplaces & Air Conditioning 9 05-26-2008 09:26 AM
AC condensation drain tube IndyAnne 1959-69 Tradewind 10 04-10-2008 03:05 PM
