Old 11-29-2007, 09:26 AM   #1
1979 29' Ambassador
Norman , Oklahoma
'79 Ambassador questions from a newbie
I donít own an Airstream at this point, but I have an opportunity to buy a 1979, 29í Ambassador at what seems to be a decent price ($3,000 or less). It has been sitting for several years, and has some condition problems. Being a potential newbie to the Airstream world, I have a couple of questions that I canít find answers to from the trailer itself. First, I need the tongue weight. The info plate on the front is almost unreadable; the serial number came from the plate on the door side. Second, I currently pull a 17í fiberglass trailer with my 2002 Chevy half-ton with a small V8, and donít I donít know whether or not I could safely and easily pull the bigger, heavier Airstream with the same truck or if I would need a larger, more powerful one.
Thanks for any information and/advice advice.
mjjnorman is offline   Reply With Quote
Old 11-29-2007, 09:53 AM   #2
Thanks a cheap price for that trailer.
If it has been parked for a long time, then several things will need to be addressed as soon as you purchase the coach, that is if you do.
The first is the axles. The following will teach you how to check them out yourself.
Dura Torque Axle
How about body damage?
Surely, the entrance door, access compartment doors, window and especially the sewer vent pipe gaskets, ceiling vent cover gaskets, will all need replacing.
Has the water system gone thru a freeze up?
Do all the appliances work? Correctly?.
Tires?
Could be a heck of a deal, but odds are that it has many problems.
Old 11-29-2007, 10:26 AM   #3
sander17's Avatar
1996 28' Excella
Okemos , Michigan
Images: 42
Our previous trailer was a 79 Ambassador. Its dry weight was listed as 4650 lbs. I towed it with a 98 Dodge Ram 1/2 ton 4x4 with the 5.9 liter gas engine and an auto tranny. Its tow rating was roughly 8000 lbs, so it had no problem. You need to check the tow rating for your truck. It is heavily dependent on the gear ratio in the differential.
PM me if you have any questions about the Ambassador, or just post them on this thread.
Good luck!
Dave
Okemos, MI
T.V.:'05 Dodge Ram 2500 4x4 Quad Cab Cummins
AIR#2276
sander17 is offline   Reply With Quote
Old 11-29-2007, 11:31 AM   #4
87MH's Avatar
1978 31' Sovereign
Images: 292
I don’t own an Airstream at this point, but I have an opportunity to buy a 1979, 29’ Ambassador at what seems to be a decent price ($3,000 or less).... I currently pull a 17’ fiberglass trailer with my 2002 Chevy half-ton with a small V8.....
On the price - the 3 grand could well be only the entry ticket for expenditures - or, like Andy said, it could be a really good deal - it all depends if you are able to use it as it is - and you and your family are happy with it "as is". Your best ammunition to determine the real value of the trailer is to read as many of the postings on late 70's models as you can prior to making the decision to purchase or not.
As per the weight, my '78 Sovereign (with all of the recent mods) weighs in at 6600 lbs, with 600 of them on the tongue. The '79 you are looking at should be very close to those numbers, if not a bit lighter.
As Sander17 said, you really need to check the specs on your Chebby to determine the towing capacity - I had a 2001 that had a Tow Rating of 1500 lbs - seriously....I bought it new and put a whole 2000 miles on it before I sold it 6 months later.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 11-29-2007, 11:44 AM   #5
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Weight Chart
This may help you a little. Welcome to the Forum.
Newbie Questions LHall Fresh Water Systems 8 04-22-2010 11:05 AM
A newbie with questions ciquing Member Introductions 12 11-17-2006 01:00 PM
Newbie Questions RVNUTTY Electrical - Systems, Generators, Batteries & Solar 5 02-29-2004 08:52 PM
Newbie with questions Tin Hut Axles 11 08-21-2003 06:10 PM
Newbie with Questions autoist Airstream Motorhome Forums 2 12-15-2002 06:55 AM
