Old 07-01-2006, 10:23 PM   #1
1978 30' Argosy 30
tappan , New York
78 30 ft argosy
I just purchased a 1978 30ft mid bath argosy,which I still have to pickup.All the rain in upstate Ny has prevented this.I will be replacing at least a good part of the floor.Thank to all the information here I am confident about doing it.Will post pictures
bc057 is offline   Reply With Quote
Old 07-01-2006, 11:36 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Welcome to the forums. I have many fond memories of our Argosy 20, and sometimes wish we still had it. Like, for example, when I am washing or polishing the Overlander...
Old 07-02-2006, 08:15 AM   #3
Happycampers's Avatar
1979 30' Argosy
Havelock , where we park it
bc057, You must be older than dirt. Just kidding. Welcome to the forums.We just bought a 1979 Argosy with center bath and twin beds which we are in the process of changing to a queen. What bed setup do you have? We have to replace three sections of floor too, and repaint. We redid a 26ft a couple years ago and sold it last year. Good luck with your Argosy.
Marvin & Annie
Niki (fur baby)
1979 Argosy 30 (Costalotta)
WBCCI 10103
"Happiness is a warm Puppy" Charles Schulz
Happycampers is offline   Reply With Quote
Old 07-02-2006, 05:15 PM   #4
1978 30' Argosy 30
tappan , New York
It has the two what I suppose are singles in the rear.That will be addressed when the floor is done.I am 6'6" and Don't see me fitting to well.bruce
Old 07-02-2006, 05:33 PM   #5
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
Welcome to the forums. what an exciting time picking up your first Airstream. Good luck to you on your floor project and I will be looking forward to the pictures.
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Old 07-10-2006, 08:09 PM   #6
1978 30' Argosy 30
tappan , New York
Having picked up the trailer finally and started going thru it.So far it appears plumbing has been replaced with pex,ac and fridge work.Floor is shot so this week we will start cleaning out front area.Trailer was used for first 6 years and then sat for 22 years. Will say trailer towed sweet. Will post pictures this week
Old 07-29-2006, 05:06 PM   #7
1978 30' Argosy 30
tappan , New York
I am uncovering the front floor and have found under where the fresh water tank sits, under the plywood there is a aluminum sheet riveted to the frame.I assume this was if you had the spare carrier underneath, to protect the plywood. Does this serve any other purpose and should I put it back?
thanks bruce
Old 07-29-2006, 07:56 PM   #8
Well Preserved
1993 21' Sovereign
thanks bruce
You are entirely correct. I would put it back, you never know when you may decide to install a spare tire carrier, and if you did you would have to reinstall the aluminum sheet.
Old 07-29-2006, 08:17 PM   #9
league city , Texas
congratulations on your purchase
I am still in the process of finding a mh but always like to hear that someone has found their project to scratch their "aluminitis".
Keep us informed and look forward to the pictures.
mr. bill is offline   Reply With Quote
Old 09-04-2006, 04:45 PM   #10
1978 30' Argosy 30
tappan , New York
I have dropped the belly pan and bananna wraps and was pleasantly surprised that there is little welding to do.I have also stripped out the living room area walls and the floor.I was shocked at the poor job of welding in the outriggers, a spot weld on the one side and nothing on the top.I found that airstream used elevator bolts with nuts only to bolt down the body to the outrigger. In the field of the floor they used self tapping elevator bolts.
thanks for all the info here. bruce
Old 10-08-2006, 08:46 PM   #11
1978 30' Argosy 30
tappan , New York
Does any one know where to buy the aluminum coil to make the bannana wraps? thanks bruce
Old 10-08-2006, 09:39 PM   #12
Well Preserved
1993 21' Sovereign
Bruce, IIRC it is just basic 2025 alclad, bent to fit, nothing fancy.
Argosy Motorhome Manual & Brochures WANTED Rik Argosy Motorhomes 28 05-22-2017 11:45 AM
Stripping an Argosy CHRIS CANNON Cleaning, Stripping & Polishing 8 05-11-2017 04:42 PM
confused Argosy newbie Dave Cole All Argosy Trailers 23 09-15-2006 09:36 PM
New Argosy owner! barbwire All Argosy Trailers 33 04-15-2003 07:14 PM
1985 Argosy MH???? ViewRVs Airstream Motorhome Forums 8 03-21-2002 07:39 PM
