Using a pair of adjustable wrenches (or the correct size if you can figure out what size they are), loosen the water feed line with one wrench while holding the fitting on the toilet base steady.
Then, using a 1/2" socket or wrench, remove the two bolts holding the toilet to the closet flange. Lift the toilet off the closet flange. Installation is the reverse.
