Old 04-11-2007, 08:17 PM   #1
fla keys
1971 27' Overlander
boynton beach , Florida
71 overlander
hi yall
bought it on ebay. love that 70's look it's retro. newbie the skin on the inside is alumimum with some kind of vinyl on it? its moldy and so is the fiberglass insulation.
1. dose the aluminum on the inside have structual value
2. could it be replaced with thin marine plywood or should i remove it clean it and rivet it back in
3. i live in florida and plan to leave it in the keys for weekend fishing trips do i
need to replace the insulation
please help save a 71
michael
supergrafix is offline   Reply With Quote
Old 04-11-2007, 08:25 PM   #2
Silver Threads's Avatar
2000 25' Excella
Kingston , Tennessee
Welcome
When we first got ur 72 it had a mold problem also. I used Mean Green which can be picked up at Walmart to scub it down. We then placed an ozone machine in it for 24 hrs to kill the mold and havent had any problems since. Good luck! I love the 70's models also.
Tammy
John & Tammy Adams
Silver Threads Custom RV Curtains
2000 Airstream Excella | AIR 15902
https://www.etsy.com/your/listings
Silver Threads is offline   Reply With Quote
Old 04-11-2007, 08:26 PM   #3
Fyrzowt's Avatar
West of Fort Worth , Texas
Images: 8
Quick and dirty:
1. Yes
2. No, if you plan to tow it.
3. Your choice, but for restore/resale value, both 2 and 3 should be YES.
Welcome to the forums, good luck with the project.
Dave
Fyrzowt is offline   Reply With Quote
Old 04-11-2007, 08:54 PM   #4
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Originally Posted by Fyrzowt
Quick and dirty:
1. Yes
Dave
Removing the inner skin is a no-no? I guess I could see how, just never really thought about that.
Old 04-11-2007, 10:37 PM   #5
fla keys
1971 27' Overlander
thanks for the info. is there a good way to remove the insulation? without removing the aluminum panels? what do you think about spray foam insulation? should i be in another forum
michael
Old 04-11-2007, 11:11 PM   #6
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
Michael, click on the Forums tab up top then scroll down the page. There are many sub-forums covering the topics you are asking about. Try searching thru those, lots of good info there.
I don't know of a way to remove the old insulation without taking the interior skins out. As far as the spray insulation goes, that idea has been tossed around, but I don't know if anybody has successfully done it.
www.nesa.org
Air No. 6427
Old 04-11-2007, 11:15 PM   #7
fla keys
1971 27' Overlander
thanks been doin that. still looking
michael
Old 04-12-2007, 04:50 AM   #8
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Michael-
Greetings- The interior skin is structural as well as adding interior surface. The ribs are kept lateral by the exterior and interior skins. We have tossed around the idea of foam insulation but there are too many what ifs. What if it over expands, what if you need to get back into the inner layer for plumbing or wiring, etc. Plus you would still need to remove the old insulation prior to foaming. Removing the inner wall skins is lot easier than you might think and reinstalling is just as easy. All it takes is time and carefulness. Check out the other threads. Good luck and keep us posted.
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 04-12-2007, 07:48 AM   #9
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
The interior skins help keep everything in place, so they should be retained. To remove insulation, you will need to remove the interior skin, replace the insulation, and replace the interior skin. You can clean the mold (mildew) off the skin while you have it out replacing the insulation.
Expanding foam insulation is not recommended, it will crumble to dust and wind up being useless.
Old 04-12-2007, 09:38 AM   #10
69 Silverback's Avatar
1969 27' Overlander
Firth , Nebraska
foam insulation
I too, looked into the spray foam. the company I was dealing with, had done the cube bodies of the trucks for thier company. These were aluminum sheet over a ribbed frame. In one vehicle, they injected the foam between the inside and outside panels. It had very noticeable outward bowing from rib to rib. on this one, they had a plywood tnterior. Thier thoughts were the that the expansion caused the bowing. On another vehicle , they removed the inside plywoodas to allow the foam expansion to be able to go away from the exterior. This only helped minimumly in the bowing effect . End analysis thoughts were that the heat from the foam cureing caused the skin to expand and streach.
Needless to say, I didn't go with the foam. We chose HVAC duct insulation.
Loren
69 Silverback is offline   Reply With Quote
First shower in my 1975 Overlander !!! pjtaia Our Community 14 07-05-2015 12:46 PM
1966 Overlander International Double Tamara 1965 - 1969 Overlander 30 03-28-2006 02:55 PM
1976 Overlander davidz71 Our Community 2 09-24-2002 07:48 PM
2-door Overlander InsideOut 1960 - 1964 Overlander 0 08-30-2002 08:14 AM
Looking at a '64 Overlander N80 1960 - 1964 Overlander 1 06-02-2002 08:25 PM
