Old 10-19-2006, 08:50 AM   #1
1967 22' Safari
1954 22' Flying Cloud
Seattle , Washington
Smile 67 Swaying Safari
Hey there, I'm Mike, a teacher up here in sundrenched Seattle. I am almost ready to head down the the Oregon Rally on the 28th. I have one dilemna left to solve. I have a fairly new equalizer hitch, Drawtite, but on my 67 Safari, I have an older set of hook-up brackets that cinch the sway bars to the tongue of the trailer. They are a set of brackets with chains and there is a gizmo that goes towards the front of the hitch so it looks like a mini set of bars underneath the trailer tongue.
After struggling for an hour, I was not able to hook my new sway bars to the old sway brackets. Any word of wisdom out there?/
Mike
mikemurph123 is offline   Reply With Quote
Old 10-19-2006, 09:43 AM   #2
1975 29' Ambassador
Reno , Nevada
That sounds like a Reese Dual Cam setup. See http://rvinfo1.tripod.com/ for an installation guide. TheDieselStop.Com Forums: Help with Reese Dual Cam looks like it might be on this issue.
Unless you have instability problems towing your trailer, you really don't need sway control. And you shouldn't have such problems with your Safari if you have a decent tow vehicle with good tires and proper loading.
Hope it helps. There should also be some folks at the Rally to help you out, too.
Old 10-19-2006, 10:23 AM   #3
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
two different systems..
I think your WD setup is one type (the Drawtite), and the "gizmo" is for a Reese setup. If you need sway control (and it doesn't hurt to have it... I'd use it) you can buy a friction sway control device (Evergreen RV in Shoreline should be close by) and install it fairly quickly. Do you have an "extra" small ball on the hitch head (should be on the passenger side of the hitch head next to the big hitch)?
Pictures help too. If I wasn't working right now, I'd offer to come over and help you out. When are you leaving?
Marc (also in Seattle)
Old 10-21-2006, 03:36 PM   #4
1967 22' Safari
Hey there, My friend karen, kitchen , cloase and I are leaving Friday morning. I am located by Northgate, she is in west seattle
Mike 206-524-3871
Old 10-21-2006, 03:39 PM   #5
1967 22' Safari
Cool Thanks
everyone for your helpful advice. I ended up going to Evergreen Rv yesterday and they said the same things you did. I have two different set-ups. After searching unsuccessfully for the adaptor bracket for the drawtite to the dual cam, I decided to take off the dual cam , and just use the brackets for my sway bars. I just finished now 2 pm on Sat as a matter of fact.
thanks again
Mike
Safari VS. Classic Questions kkrogh Our Community 24 12-20-2005 11:10 AM
1977 Safari Manual RamblinRose General Interior Topics 2 04-17-2004 04:51 PM
Purchase of 73 safari april Our Community 11 09-01-2002 01:33 PM
Towing my 1964 Safari - what tow vehicle do I use Neenm Tow Vehicles 6 06-28-2002 04:26 PM
Problem with electrical system (1965 safari) rslaymaker Electrical - Systems, Generators, Batteries & Solar 4 06-13-2002 05:49 PM
