Old 02-08-2007, 03:11 PM   #1
1961 16' Bambi
Buckeye , Arizona
61 Bambi
My husband and I are towing our Bambi up and down the hill for the first time. Any advice on whether we need electric brakes or not? The tow vehicle is equipped, but the trailer is not. Where in the Phoenix area would I have elec. brakes installed on an Airstream?
61 Bambi is offline   Reply With Quote
Old 02-08-2007, 03:27 PM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
Hello mdoster -- and welcome to the Forums!
How well do you know this Bambi? Do you know that the wheel bearings are lubed and up to the task? Are you doing short distance transport before you restore it?
Up and down the hill? Would I consider a 25- to 50-mile transport at slow speeds and showing great care? Probably. Your profile doesn't give any indication of what tow vehicle you have. Are you saying the tow vehicle has a brake controller installed?
I transported my Argosy quite a distance without a battery -- once! All states require a functioning breakaway braking system on trailers over ... is it 2000#? And that requires a good battery aboard. There's more to the picture than that.
You will want to look at the umbilical connection and get the lights in working condition at some point (have a knowledgeable person follow right behind with flashers going if they aren't!). There's a lot of info and willingness to help you assess the braking system on the trailer. Should you contact local authorities and ask about guidelines for pulling a trailer with nonfunctioning systems? Probably.
Thank you -- more info would help. Better yet, jump in and involve yourself with more questions. Delve into the wide variety of info and "live" input here!
5 meter Langford Nahanni
Old 02-08-2007, 03:27 PM   #3
AirstreamGypsy's Avatar
1961 16' Bambi
Mancos , Colorado
Send a message via Skype™ to AirstreamGypsy
Welcome to the forums and congratulations! I too have a '61 Bambi. Are you sure you don't have brakes? I cannot imagine that they are not a part of the wheel assembly. Red line coming out from under the trailer by the wheels....
Post a few pictures and people can get a better idea.
You might want a new axle anyway. It took me from 1999 til just last year to realize I needed one. The new one will have the electric brake assembly in them for sure. Most likely wherever you get your axle installed can run a brake line up to your trailer pigtail for you. Then you are set to go.
What is your tow vehicle?
I would not tow distance or hills without brakes.
Good luck!
AirstreamGypsy
___________
Charter Member FCU WBCCI 1818 CP(Courtesy Parking) Wi-Fi
My Earthship
AirstreamGypsy is offline   Reply With Quote
Old 02-08-2007, 03:37 PM   #4
robandzoe's Avatar
1958 30' Sovereign of the Road
Plymouth , New York
Send a message via Skype™ to robandzoe
Drive it to Tucson
I recommend Oasis RV - an Airstream dealer over in Tucson, and one that cares about the Vintage ones..
OASIS R.V. CENTER, INC. - Home
I agree - just go for the new axle, as many, many of your worries while towing will be relieved.
Rob
Rob, Zoe', Stanton, Bryce, Braedon and Finn Baker
Do you Listen to the www.theVAP.com
Plymouth, NY 13832
http://bakersacresofchenango.blogspot.com/
Courtesy parking
Flag Pole Holders - http://robsflagpoleholders.blogspot.com/
robandzoe is offline   Reply With Quote
Old 02-08-2007, 03:49 PM   #5
Ohh, absolutely! Thanks Rob -- I frequently recommend Oasis for mail order parts. Just don't have my head screwed on as them being accessible for actual repairs.... Too much 10-below weather chilling my brain of late.
1961 - 1963 Bambi Serial Number Guide Andy R 1961 - 1963 Bambi 52 05-08-2018 01:31 PM
1961 Bambi '16 (Serial #16TDSS1728) Andy R 1961 - 1963 Bambi 28 02-27-2012 10:57 AM
Newbie AS Bambi Owner! KY Girl Our Community 12 10-27-2002 09:06 PM
Interior lights - 61 Bambi 61BambiCanada Electrical - Systems, Generators, Batteries & Solar 0 06-07-2002 09:52 AM
Bambi II is a Caravel... VintageRV 1964 Bambi II 0 02-24-2002 07:55 PM
