Old 05-22-2012, 10:38 AM   #1
1975 31' Sovereign
Auburndale , Florida
Question 1970's cooper tube sizes
I have a piece of plumbing pipe with an apparent 11/16 OD and 10/16 ID meaning inside diameter. Where do I get the odd size to get pipe or fittings to fix leaks?
rpprice49 is offline   Reply With Quote
Old 05-22-2012, 10:45 AM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Most of the copper tubing would have been 1/2 inch OD. When water freezes inside the tubing it will expand and stretch and/or split the line.
Instead of patching, you might consider replacing all of the lines with PEX.
Richard
Old 05-22-2012, 11:45 AM   #3
tphan's Avatar
1972 27' Overlander
Longmont , Colorado
I agree with AZfly- replace all your cooper tube with PEX.
tphan is offline   Reply With Quote
Old 05-22-2012, 01:16 PM   #4
damonbeals's Avatar
1998 31' Excella 1000
1979 23' Safari
Mooresville , Indiana
copper hot water and cold water pipes are different sizes. 1/2" hot is a different size then 1/2" cold.
Also if the pipe has frozen it can swell and not be a standard size anymore.
Damon
damonbeals is offline   Reply With Quote
Old 05-22-2012, 01:31 PM   #5
WineStream's Avatar
2005 30' Safari
Pleasanton , California
Images: 24
Yup. Your pipes have frozen at some time and expanded. I'm surprised at the sizes you mention though that they have not burst before getting to that size.
Trace the copper to a point where it's the correct size and then cut it. Replace the cut-out section with PEX and shark-bite connectors (there's other ways to connect, but shark bites are best IMHO).
WineStream is offline   Reply With Quote
