Old 12-26-2007, 06:24 PM   #1
Kajtek1's Avatar
1965 22' Safari
Orinda , California
1965 22' Safari ?
Hi. Being automotive enthusiast I used to watch an Airstream trailer sitting on my neighbor backyard for about 2 decades. Finally after about 2 years of negotiations I am proud to tell, that the trailer is mine. The main issue in negotiations were books, that the neighbor and his stepdaughter accumulated in the trailer. They were hoping to have time to select them, but finally gave up, so the first restoration job was removing the books. Took 3 pallets, what I estimate is 4-6 tons. Amazingly I was able to inflate the tires and they hold the weight of the trailer and the books on about 1/4 mile drive.
After washing all the vegetation from the siding, turned out the aluminum siding still shines in some areas. It does have few dents and dings, but generally the trailer is in good condition. Deteriorated roof vents cost some leak and sofas damage, but this is minor. After our New Year vacations I'll get on mechanical parts.
The first question (I am sure more will follow) is do those trailers have identification tags? I have old registration slip saying "first registered 1965" but on the side of model names, I have no knowledge what year exactly it is.
Pictures will come.
Kajtek1 is offline   Reply With Quote
Old 12-26-2007, 07:00 PM   #2
yukionna's Avatar
Massachusetts
Images: 18
Send a message via Yahoo to yukionna
Congrats on your purchase!
With regard to your question about tags -- some trailers had them with the trailer model written on them but many don't have the tag. If there is a tag, it is usually located to the left or the right of the entry door. If nothing else, there should at least be a tag, or badge, with the serial number on it. It is through the use of the serial number that the model can be identified.
I hope this helps. If you could post photos and the serial number, we might be able to help you identify the model.
WBCCI Region One
Attitude is the only difference between ordeal and adventure
yukionna is offline   Reply With Quote
Old 12-26-2007, 08:53 PM   #3
Kajtek1's Avatar
1965 22' Safari
Orinda , California
There is "Safari" molded sign on the side, so this is an easy one. Here some pictures of "before" and as well a sticker in the rear bumper are. That looks like CA legal sticker. Notice "Division of housing" and "This mobilehome" on it
Old 12-26-2007, 08:54 PM   #4
Kajtek1's Avatar
1965 22' Safari
Orinda , California
Old 12-26-2007, 08:55 PM   #5
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Welcome to the Ariforums! Congratulations on beginning your Airstream journey... Now all you have to do is get it roadworthy so you can begin your journeys IN it! Lots of helpful people and good information to be had here...
Glad you could join in...
Ease on down the road...
TB
TB & Greg and Abbey Schnauzer
#3954
Old 12-26-2007, 08:56 PM   #6
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
(Love the green stuff growing out from under that plate!)
#3954
Old 12-26-2007, 08:59 PM   #7
GreatPumpkin's Avatar
Colville , Washington
Images: 70
Well, the "safari" plate gives it away as to what you have, but the actual serial number will tell for sure what year it was made (model year) vs what year it was first registered.
The plate in your picture is from the state, there should be another plate similiar to this that will have a serial number on it:
AIR 12256
Currently Looking
2001 Dodge Ram 1500
2001 Honda XR650R
Currently Looking...for an Avion Truck Camper (or a Classic Argosy MoHo)
"In regione caecorum rex est luscus." GP
GreatPumpkin is offline   Reply With Quote
Old 12-26-2007, 09:01 PM   #8
Images: 70
Actually, I can see the plate in your first pic, just not close enough to read it. It does appear from the border around it, that you have the "internationl" options.
AIR 12256
Currently Looking
2001 Dodge Ram 1500
2001 Honda XR650R
Old 12-26-2007, 09:05 PM   #9
Kajtek1's Avatar
1965 22' Safari
Orinda , California
Got it. It is bolted on the side of the trailer. This forum is having strange for me system for attaching the pictures. How can I make them smaller?
Old 12-26-2007, 09:14 PM   #10
Images: 70
SI22S5209
S = California built
I = International model
22 = Length
5209 sequential number (also designates twin beds vs double)
I use MS Picture Manager and select the "compress" or "resize" option. Most photo software has the means to resize your photos, check under the options.
AIR 12256
Currently Looking
2001 Dodge Ram 1500
2001 Honda XR650R
Old 12-26-2007, 10:02 PM   #11
Kajtek1's Avatar
1965 22' Safari
Orinda , California
Thanks for all the help.
Some forums have option of resizing the picture on the site that's why I asked. Will have to work on it in the future.
Old 12-27-2007, 03:34 PM   #12
Kajtek1's Avatar
1965 22' Safari
Orinda , California
Now I assume, that sequential number might give me precision manufacturing data?
Where could I find it?
Old 12-27-2007, 03:45 PM   #13
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Welcome to the forums!
Try this: 65 Safari
You probably won't find much more thorough info than what's there ~
Shari
RMVAC | WBCCI DenCO Unit | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 12-27-2007, 03:54 PM   #14
MarkR's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
Folsom , California
Images: 12
i believe the "5" in 5209 indicates 1965, I don't know that you'll get an actual manufactured date from your numbers.
this site has lots of great info:
Vintage Airstream Photo Archives
Aluminumbskull with Led Balloon in Drag
Birch Plywood and Aluminum go together like
Peanut Butter and Chocolate
MarkR is offline   Reply With Quote
replace cabinet doors 1965 safari RiverRat Cabinets, Counter Tops & Furnishings 3 06-22-2007 12:14 PM
1965 Safari Air Conditioning Install Glorette Furnaces, Heaters, Fireplaces & Air Conditioning 1 06-15-2007 12:23 PM
1965 safari Gllj05 Member Introductions 5 05-29-2006 06:53 AM
New Acquisition 1965 Safari driftwood 1965 Safari 3 04-27-2005 08:17 AM
Problem with electrical system (1965 safari) rslaymaker Electrical - Systems, Generators, Batteries & Solar 4 06-13-2002 05:49 PM
