Old 02-01-2015, 09:23 AM   #1
acstokes's Avatar
2009 30' Classic
Melbourne, FL , Searsport, ME
Where's the transfer switch?
I have a 2009 Rear Bed Classic. It has a receptacle on the front for generator power, but it doesn't work so I thought I'd troubleshoot the transfer switch. According to my trailer original invoice I have one, but I haven't been able to find it. Anyone have any suggestions where to look?
Thanks.
Fred Stokes
RV Rearview Camera Systems, LLC
WBCCI #2810
acstokes is offline   Reply With Quote
Old 02-01-2015, 09:45 AM   #2
2011 25' FB Flying Cloud
Anywhere & , Everywhere
No expert on your model but most if not all transfer switches are behind the converter.
Al - K4GLU is offline   Reply With Quote
Old 02-01-2015, 11:16 AM   #3
acstokes's Avatar
2009 30' Classic
Thanks for your suggestion, but mine's not there. I think AS never installed it because it's no where to be found.
Fred Stokes
WBCCI #2810
Old 02-01-2015, 12:44 PM   #4
You could always give Airstream a call Mon and ask where it should be in your model. Or send them an e-mail.
Old 02-01-2015, 12:57 PM   #5
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Some models have the transfer switch under the corner lounge, next to the cabinet that houses the galley sink.
Are you sure it was originally equipped with a second inlet?
Old 02-01-2015, 03:29 PM   #6
acstokes's Avatar
2009 30' Classic
All I know for sure is there's a male 30 amp generator receptacle on the trailer front and that a transfer switch is listed on the original invoice. I've replaced the converter and there was not one present in that area. I've looked in the area of the 120v panel and cannot find one there.
Any other suggestions?
Fred Stokes
WBCCI #2810
Old 02-01-2015, 11:35 PM   #7
"Space A" S/O Registry 11
2006 34' Classic S/O
Fort Worth , Texas
On my Classic it is behind a screwed on grey carpeted cover located on the inside of the roadside rear corner under the A/C shoreline male socket. On the rear queen bed it is in the storage compartment on the rear curbside corner. Hope this helps.
Old 02-02-2015, 07:38 AM   #8
acstokes's Avatar
2009 30' Classic
Thanks Guskmg. I found it's supposed to be where you said. However, it proves you don't always get what you pay for. As you can see from the pictures, AS plant never installed it. Notice the wire marked "Gen" that is not connected to anything much less a transfer switch. Wonder if AS will fix this under warranty on a 2009? Somehow I doubt it, but I'm going to call them anyhow. I'll let you all know if they do.
ID:	231543   Click image for larger version
Fred Stokes
WBCCI #2810
Old 02-02-2015, 07:45 AM   #9
Tincampers's Avatar
Sneedville , Tennessee
Are you the original owner? If not, maybe the original owner removed the switch.
Tincampers is offline   Reply With Quote
Old 02-02-2015, 08:00 AM   #10
acstokes's Avatar
2009 30' Classic
I'm the second owner. I cannot imagine why someone would remove a transfer switch and not replace it. Furthermore, the wires are stripped, but the ends are straight as though they've never been terminated or connected with anything (e.g. wirenuts, connectors, etc.
Fred Stokes
WBCCI #2810
Old 02-02-2015, 08:12 AM   #11
Tincampers's Avatar
I saw that. Very strange situation. People do weird things sometimes. Don't ask me how I know! O-)
Old 02-02-2015, 08:47 AM   #12
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Can't help with the question, but I am just wondering why a transfer switch is used with an RV?
If I understand, a transfer switch is used in a house when an emergency generator is to be used to ensure that the home owner cannot inadvertently back feed the incoming power lines and maybe injure of kill an electrical worker who maybe working on the distribution lines outside.
But why do you need a transfer switch with a trailer?
I don't have one in our 2005 Classic 30, and any time I use the gennie I just plug the main "power in" cable into the gennie instead of a campground supply box. Presume that is what most folks do.
What am I missing here insofar as the reason for a transfer switch on an Airstream?
Just curious!
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 02-02-2015, 09:04 AM   #13
acstokes's Avatar
2009 30' Classic
AS mounts a 30 amp male receptacle on the trailer front (this may be an option) for plugging a genset there. As you said, the shore power cord and receptacle could be used, but it's a convenience sometimes to plug into the front instead.
My main interest in wanting a transfer switch and knowing its location is to use it or a replacement one, if need be, in conjunction with an inverter powered by the solar system I just installed.
You're right that a transfer switch or relay is also used to switch between grid power and generator power. Same principle, but different application.
Fred Stokes
WBCCI #2810
Old 02-02-2015, 09:19 AM   #14
z , North Carolina
Hmm
Please edumacate me as I am getting ready to purchase a gen-set.
It IS normal to have to turn a transfer switch inside of your rig if you are to use the front 30 amp male receptacle?
My previous owner mentioned nothing about this, but he didn't have a generator either. So I too should find a transfer switch?
Thank you for educating me.
Gavin
FishinHatteras is offline   Reply With Quote
'92 LY transfer switch location 92landyacht Land Yacht/Legacy Motorhomes 0 11-26-2011 04:00 PM
Transfer Switch GlenCoombe General Motorhome Topics 8 11-09-2008 07:54 PM
Inverter transfer switch help walter1 Electrical - Systems, Generators, Batteries & Solar 6 11-24-2006 10:41 AM
Remote Generator Transfer Switch Question flyfisher Generators & Solar Power 1 07-15-2006 08:32 AM
Transfer switch markdoane Electrical - Systems, Generators, Batteries & Solar 1 02-21-2004 12:43 PM
