Old 04-29-2014, 08:59 PM   #1
lrw
2007 30' Classic S/O
Ann Arbor , Michigan
Water heater
Trying to figure out how to get the water heater to run with propane. It's fine with electric.
lrw is offline   Reply With Quote
Old 04-29-2014, 11:35 PM   #2
1974 Argosy 20
Kooskia , Idaho
I am sure you have a electronic spark ignition on the propane part of your water heater. Just turn the switch on (probably in the bathroom). You will see a short red light flash and then it should just run. The light will go out and only come back on if there is any problem.
I assume you will have the propane tanks on. Light the stove for a minute to be sure you have propane available in the pipes
Propane Heater or Instant water heater valontjej Plumbing - Systems & Fixtures 1 04-09-2012 08:56 PM
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 07:17 AM
hot water water on demand with a with a normal water heater Frank's Trailer Works Water Heaters, Filters & Pumps 3 09-25-2007 12:24 AM
Water heater prob, pilot won't stay lit & heater won't fire. johnboy Water Heaters, Filters & Pumps 1 06-20-2006 04:24 PM
water heater and heater cabbage76 Furnaces, Heaters, Fireplaces & Air Conditioning 7 11-12-2003 08:06 PM
