Old 02-21-2019, 03:07 PM   #1
Julie-Bob's Avatar
2009 25' FB Classic
Scottsdale , Arizona
Updating our 25FB 2009 Classic
We are replacing the mouse fur on the sidewall, the flooring, and changing the dinning are to an horseshoe type sitting. I was very surprised that the mouse fur came off so easy. Glad Mother ship didn’t use a lot of glue. Click image for larger version
ID:	334109Click image for larger version
ID:	334110Click image for larger version
ID:	334111Click image for larger version
Bob & Julie # 5587, 4CU in AZ
Julie-Bob is offline   Reply With Quote
Old 03-13-2019, 05:43 PM   #2
Julie-Bob's Avatar
2009 25' FB Classic
New flooring installed Click image for larger version
ID:	335575Click image for larger version
ID:	335576Click image for larger version
Old 03-20-2019, 08:25 PM   #3
Julie-Bob's Avatar
2009 25' FB Classic
Building the horseshoe seating, built and installed a small cabinet on street side to replace the AS cushion, built and installing a cabinet under TV. Click image for larger version
ID:	336198Click image for larger version
ID:	336199Click image for larger version
Replacing wood under shower door, found a water line hidden under shower pan so will build a door here in place of the wood panel.
Old 03-22-2019, 08:28 PM   #4
Julie-Bob's Avatar
2009 25' FB Classic
Installing new wall covering , replacing the wooden panel under shower door, with a door to access the water line under shower pan if needed. Click image for larger version
ID:	336319Click image for larger version
ID:	336320Click image for larger version
ID:	336321Click image for larger version
Old 03-30-2019, 07:55 PM   #5
Julie-Bob's Avatar
2009 25' FB Classic
ID:	336952Click image for larger version
No more mouse fur.
Old 04-01-2019, 10:20 AM   #6
2007 27' Classic FB
Ridgefield , Washington
What type of flooring did you use? Been thinking about replacing ours. Trying to figure out the best way to lay the flooring from the hallway to the bathroom.
John
Woosch is offline   Reply With Quote
Old 04-03-2019, 08:51 PM   #7
Julie-Bob's Avatar
2009 25' FB Classic
Originally Posted by woosch View Post
what type of flooring did you use? Been thinking about replacing ours. Trying to figure out the best way to lay the flooring from the hallway to the bathroom.
Old 04-03-2019, 09:14 PM   #8
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Nice work on the new flooring and the wall covering replacement. How did you attach the new material to the walls?
I am doing a makeover on our 95 34’. Not sure what we are going to replace the mouse fur or the vinyl ceiling with. May just install new aluminum over the old.
Dan
Old 04-04-2019, 02:21 PM   #9
Julie-Bob's Avatar
2009 25' FB Classic
The wall fabric was glued on with spray glue. Lightly. More photos Click image for larger version
ID:	337306Click image for larger version
ID:	337307Click image for larger version
ID:	337308Click image for larger version
ID:	337309Click image for larger version
ID:	337310Click image for larger version
Old 04-09-2019, 04:17 PM   #10
Julie-Bob's Avatar
2009 25' FB Classic
Dinning area finished Click image for larger version
ID:	337780Click image for larger version
ID:	337781Click image for larger version
Old 04-11-2019, 02:34 PM   #11
Julie-Bob's Avatar
2009 25' FB Classic
These are the folks that did the work. Click image for larger version
Old 04-12-2019, 08:18 AM   #12
Julie-Bob's Avatar
2009 25' FB Classic
2009 Airstream 25FB Classic Limited eBay Watch Airstreams on eBay 0 01-11-2011 08:50 AM
We did it!! Our new 2009 International 25FB jagzoo 2006 - 2010 International 18 04-25-2010 11:34 AM
2009 Airstream 25FB Classic Limited eBay Watch Airstreams on eBay 0 02-19-2010 06:50 PM
Pics of our 2009 International 25FB Paprika & Smart Car jagzoo 2006 - 2010 International 2 06-20-2009 06:12 PM
Updating our '73 Excella 500 Brian W General Interior Topics 2 03-15-2006 11:21 AM
