Old 06-15-2016, 03:47 PM   #1
Bbelk's Avatar
2010 27' FB Classic
Trailer Plug Wiring
I am on the road for a few months with my 2010 classic 27FB. The trailer plug on the trailer side has one pole totally corroded away. It is the pole responsible for charging the batteries while driving.
I have a new plug, but before I cut the old one off, does anyone have a wire color chart for this? It would save me a lot of trial and error.
2010 27FB Classic
1989 190 Class B (Sold)
1977 29 Ambassador Land Yacht (Sold)
Bbelk is offline   Reply With Quote
Old 06-15-2016, 04:07 PM   #2
1991 25' Excella
Stanfield , Oregon
Hope this helps https://www.etrailer.com/faq-wiring.aspx
SpletKay06 is offline   Reply With Quote
Old 06-15-2016, 04:09 PM   #3
2011 25' FB Flying Cloud
Anywhere & , Everywhere
If you had put trailer plug wiring in your Google search box instead of AirForums you would have the info in about 2 seconds.
Al - K4GLU is offline   Reply With Quote
Old 06-19-2016, 09:50 AM   #4
Bbelk's Avatar
2010 27' FB Classic
This is weird
Originally Posted by SpletKay06 View Post
I finally found civilization, Walmart and the internet. I bought a new plug for the trailer and started cutting up the old one. I found the green, yellow, brown and white wires I am used to, but there was also Black, red, and light blue. There was a handy hot wire (Black) right there, so I decided to test the other colors to see if they came out like I expected. They did not.
The PDF file you provided a link to looked right to me, but it had NOTHING TO DO with how the Airstream plug was wired.
Brown has always been running lights. It turned out to be the Right turn signal.
Green is usually the right turn signal. It turned out to be the running lights.
Yellow is usually the left turn signal. It turned out to be the Back Up Lights.
White is usually ground and it turned out to be the ground.
Black was the hot wire.
Light Blue was the breaks.
Red was the left turn signal.
It all works now. Ainít standardization great!
2010 27FB Classic
Old 06-19-2016, 10:00 AM   #5
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
When I replaced my old plug I cut it leaving enough of the cable so I could open it up and using a meter have a Way It Was reference, later permanently marked the outside with a letter color code matching the wire color.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 06-19-2016, 10:11 AM   #6
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Glad you got it done. I have had to do that 3 times while on the road. In either a Wal-Mart or Ace hardware parking lot. Once from corrision. Twice from dragging. Finally fixed it so it works right. I do carry a owner's manual with a corrected plug diagrahm.
Bill M. is online now   Reply With Quote
Old 06-19-2016, 11:00 AM   #7
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Hanover , Pennsylvania
Could you please clarify what you mean by "finally fixed it so it works right"?
Thanks!
Hans627 is online now   Reply With Quote
Old 06-19-2016, 11:18 AM   #8
Morgan guy's Avatar
2007 27' Classic FB
Fredericksburg , Texas
One thing you should remember is that most of the wiring diagrams you will see show what the connections are from the back end of the plug, not the end inserted into the TV.
The Tex-i-can is Ready to Camp
Morgan guy is offline   Reply With Quote
Old 06-19-2016, 11:25 AM   #9
1988 25' Excella
1987 32' Excella
My TV factory plug does not always lock the plug in. I do not want to mess with the factory harness to change it. So I have the trailer wire mounted so there is plenty of slack for turns and yet it cannot drag if it comes loose. And I run with the trailer lights on to keep a check.
Old 06-19-2016, 11:41 AM   #10
Hans627's Avatar
Got it.
Thanks for clarifying!
Original trailer plug wiring diagram? edglenn Electrical - Systems, Generators, Batteries & Solar 15 05-04-2018 07:55 PM
to plug in or to not plug in...that is the questions 4hartungs Batteries, Univolts, Converters & Inverters 39 04-23-2014 03:44 PM
12V Trailer Plug Wiring dominicjohn Electrical - Systems, Generators, Batteries & Solar 15 05-08-2013 06:25 AM
Trailer plug - Adapter or New Plug?? Jason1101 Brakes & Brake Controllers 4 01-23-2003 05:24 PM
