Old 07-06-2015, 08:08 AM   #15
pappy19's Avatar
2002 30' Classic S/O
Garden Valley , Idaho
Originally Posted by kleimanr View Post
I too have a 2006 30SO. Tire stories just like yours. Switched to 16" and Michelins. No complaints yet. Even tows better.
I had a similar issue on my 2002 30' Classic with SO, and after reading all of the associated threads, I went with the following:
4 Tireco Sendel 16 X 6 6-5.5 aluminum rims (same design that As puts on their newer trailers)
4 Stainless Steel Caps
1 Dexter Steel Rim 16 X 6 6-5.5 (spare tire rim)
Total = $648.16 delivered
Discount Tire
4 Michelin E rated LTX MS/2's 16" $213.00 each
1 Falken Rocky Mtn (same exact diameter as the Michelin's) for
the spare = $104
Centramatics = full set was $235
Never looked back, even with this added expense, I do not worry about a blowout any more.
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
pappy19 is offline   Reply With Quote
Old 07-06-2015, 09:25 AM   #16
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
When we bought our 2008 Classic 25fb (8000lb GVWR) I bought Michelin LT235/75x15 MS. Their max inflation is 50lbs for about 2100lbs on each tire (downgraded slightly due to trailer use). If I had your trailer I'd go with the 16" rim/Michelin upgrade.
Kelvin
Old 07-06-2015, 10:58 PM   #17
ASTailgate's Avatar
1981 28' Airstream 280
Looks like I'm going to go with the Sendel 16" what size tire in the LTX ms2? My tire size now is 225/75/15.
ASTailgate is offline   Reply With Quote
Old 07-07-2015, 10:05 AM   #18
KJRitchie's Avatar
2008 25' Classic
Found this thread.
http://www.airforums.com/forums/f438...ns-136895.html
Kelvin
Old 07-10-2015, 10:37 AM   #19
1993 30' Excella
Kaplan , Louisiana
Tire problems
The best thing you can invest in for tire problems is to get some type of tire pressure measuring like the Advantage Pressure Pro in Harrisonville, MO. Call them at 800-959-3505 to get the details on getting this product. I have used this system for the past 13 years and it has saved me many headaches when tires start to lose pressure and it warns you immediately.
jmland is offline   Reply With Quote
Old 07-10-2015, 11:34 AM   #20
pappy19's Avatar
I had a tire pressure monitoring system on my ST's but when each of the 3 tires went on me, it wasn't a slow leak, it was BAM! So I might as well not have had the monitor system because by the time it went off, the tire was already blown. After the 3rd one, I went with all new 16" rims and MS-2's. Now my tire monitor system can really tell me my current pressures and temps.
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
Old 07-10-2015, 12:18 PM   #21
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
Originally Posted by Bill M. View Post
My guess is to go with the 16" wheels and Michelin tires. But that is not all of it. Keep a close eye on the wheel bearings and grease because I have heard of the bearings failing on a 30 SO. No, I do not know why the bearings failed. But I bet the heavy load has something to do with it.
Never had a bearing failure but at my last wheel bearing greasing I chunked Chinese bearings for set of Timken bearings. I did keep one old set of bearings. I greased them back up, put them in a ziplock bag and threw them in my trailer toolbox for an emergency spare.
Anecdotal story - one of our unit members went to 16" LT tires on their 30' slideout this Spring. He also claims the trailer tows better.
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Airstream Classic, 75th year Anniversary model :: 2006 Airstream Classic Dinet DNucha Airstream Registry Discussions 0 10-08-2012 04:24 PM
2006 Airstream 31 Classic S2006 Airstream 31 Classic eBay Watch Airstreams on eBay 0 03-26-2012 10:00 AM
Tire Recommendation 2006 25' Safari jhohe Tires 3 03-08-2012 05:49 PM
Canadian Tire's $129 Tire Pressure Monitoring System SilverCottage Tires 9 10-30-2007 07:55 PM
