Old 07-11-2019, 10:50 PM   #729
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
I experienced the door issue a couple times during the first few outings with my trailer over ten years ago. Thereafter, I stuck to the following sequence which stopped the issue except for a handful of times when the soil got drenched during the stay and compressed.
I start by dropping the forward street side stabilizer closest to the slide and work my way around until I reach the forward curb side. I almost always use a 8"x8"x3/4" board under the pads and turn the crank just a fraction less than 1/4 turn after contact. The larger contact pad seems to have helped with loamy field compression issues.
Sir Tristan
Air #48582, S/SO #003, WBCCI #4584
SeeMore is offline   Reply With Quote
Old 07-13-2019, 06:31 PM   #730
white laker's Avatar
2008 34' Classic S/O
lanark , Ontario
Thanks for the feedback. My door is as tight as a mouse's ear! The part that bugs me is that there is no rhyme nor reason to it! I think that I will look closer the next time out and play with the stab adjustments a bit more. I have the electric versions so maybe I need to get faster on the trigger when I set them down. This is going to need some deep thought and a lot of beer!
Thanks to all
Pete
Pete Crook
"Put it all behind you!"
S/OS#88
WBCCI # 8160
white laker is offline   Reply With Quote
Old 07-14-2019, 05:11 AM   #731
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Got beer get solutions. Itís in the handbook.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is online now   Reply With Quote
Old 07-14-2019, 04:29 PM   #732
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Stabilizer Wired Remote Control
I'm considering doing this. Actually I am within $60 of being committed to do this.
It hurts my back and quads to bend over long enough to run the stabilizer jacks up and down every time I make or break camp. I have designed an add on consisting of two sets of a relay box with two relays and a single plug-in switch box with two switches. The idea is you would take the switch box to the rear stabilizer jack panel, plug it in to the added relay box and while standing use the two switches to run the roadside and curbside jacks up or down as required, unplug, move to the front and repeat.
So I'm wondering if this is something that folks with electric stabilizer jacks (like Slideouts, for sure) would be interested in. I'm ordering 9 boards, due to the minimum buy from the PCB house. I will build mine and test them and if successful I will have 7 boards left over. It takes one relay for each motor, i.e. 4 per trailer and they run about $6 each. If the interest is overwhelming (doubtful) I can order more boards.
Each user would buy their own housings, switches, relays, and PCBs, build up their relay boxes and switch box and connect the relay boxes into the jack control panel. Each relay box would connect to power, ground and the two motors for a total of 6 wires.
An upgrade I'm considering is to add on key fob remote control to eliminate the need for the switch box and waterproof connectors on the relay boxes.
PM me if this is something you would be interested in doing.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 07-14-2019, 04:47 PM   #733
GCinSC2's Avatar
Al
Understand the issue and Iíve thought about separating the switches and moving switch for curb jack from street side to curb side.
Never thought of a remote like youíre proposing.
Iíll be curiously watching.
Gary
S/OS #001
Old 07-15-2019, 06:39 AM   #734
pappy19's Avatar
Garden Valley , Idaho
Speaking of the jacks, I got tired of bending down on my knees to position the blocks/pads under the jacks, and retrieving them. So I bought a junker golf iron for $5 and have been using it for years. It maneuvers the pads exactly where I want, and makes it easy to drag them out as well. In a pinch, it could be a weapon too.
Pap
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
pappy19 is offline   Reply With Quote
Old 07-18-2019, 06:18 AM   #735
2003 28' Safari S/O
Garner , North Carolina
Slide Out Society
I'm interested. 03 safari 28so. So how do I sign up?
Philcan56
Philcan56 is offline   Reply With Quote
Old 07-18-2019, 08:40 AM   #736
GCinSC2's Avatar
Philcan56,
You just signed up wasnít that easy. Iíll get your number tonight Iím still in the office for a little while.
Gary
S/OS #001
Old 07-18-2019, 05:40 PM   #737
GCinSC2's Avatar
Philcan56
OK Philcan56,
From the S/OS HQ in the Pee Dee region of SC yeah it's for real I can't make that one up with the big traditional Whump of the Hickory Stick and the Buddy Rich drum solo, wait for it, here it comes
Philcan56 you're S/OS#0108
If you have any questions, please feel free to post. Guaranteed honest answers absolute bluffs, and other sorted levels of forum replies.
You've got a unique trailer, enjoy and safe travels.
And Data Officer Tom will update the official list as soon as W lets him.
Gary
S/OS #001
Old 07-19-2019, 12:46 AM   #738
2005 28' Safari S/O
Phoenix , Arizona
Originally Posted by GCinSC2 View Post
OK Philcan56,
Gary
Welcome, Philcan56! Iím #107 and I have on 04 Safari 28 s/o.
Ed
AirEd is offline   Reply With Quote
Old 07-19-2019, 05:06 AM   #739
STREMN's Avatar
2008 30' Classic S/O
Hampton Beach , New Hampshire
Slide-Out Society - Updated Member List
Welcome aboard Philcan56 S/OS#108 with that cool 03 Safari S/O !!!
Our Grand Slider has done the job of sliding out that coveted S/OS #...thanks for that Gary!
Hot here in the Northeast...in for a hot weekend of mid 90's. It's not the norm for us folks...so if your in the area please avoid the piles of clothes where people are just melting away from the heat.
I've included our member list updated with Philcan56 S/OS #108 and the model count.
Great adventures!
Tom - S/OS #025
ID:	347043   Click image for larger version
- Tom and Wendy - AirSTREMN from New Hampshire -
- 2008 30' Classic S/O - S/OS #025 - Riding on 16" Wheels and Tires -
- Live Free or Die -
STREMN is offline   Reply With Quote
Old 07-23-2019, 05:16 PM   #740
Planerider
Clermont , Florida
Hi Everyone,
Just realized there was a Slide Out group.
Have not been on the forum for a while.
We have had ours since 2007 Classic Limited 30. We have in Parked in Tennessee.
We just decided to sell it so if you know anyone interested it is on the Classified.
planerider is offline   Reply With Quote
Old 08-06-2019, 08:52 PM   #741
2001 34' Limited S/O
Burleson , Texas
This is Ande Rushing...Kipziprip. Our slider number is #96. Please add my wife "Lynn" as a member. Also she sent you a message a day or so ago about chances of getting a site with electricity for the next slider get together. If you hear of one please advise. If one does not come available by next week we will just sign up and bring a generator.
ande
kipziprip is offline   Reply With Quote
Old 08-07-2019, 04:41 AM   #742
GCinSC2's Avatar
Ande,
I saw your post. Can you check to see if you have a Private Message (PM). If you haven't, let me know please.
Lynn, glad to meet you.
Gary
S/OS #001
1961-1963 Airstream Bambi owners registry RichardT 1961 - 1963 Bambi 64 11-20-2015 10:47 PM
Registry - How do I add mine to AIR Registry? tomandjana97 Forum Admin, News and Member Account Info 1 07-07-2015 05:05 PM
'Secret Society'?????? jordandvm Off Topic Forum 28 04-11-2008 12:02 PM
WBCCI A Secret Society? myboyburt WBCCI Forum 35 02-28-2006 02:04 PM
