Old 12-19-2021, 03:12 PM   #921
2001 30' Classic S/O
Lady's Island , South Carolina
Gary,
I believe I may have mistakenly unsubscribed from the SOS.
IS there any way to get an expanded membership roster ( or at least one these old eyes can actually read)?
Thanks.
Happy Holidays
booma is offline   Reply With Quote
Old 12-19-2021, 04:20 PM   #922
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Booma
See if post 914 helps. The list was just updated.
Gary
GCinSC2 is offline   Reply With Quote
Old 12-20-2021, 05:29 AM   #923
SOS roster
Gary,
Sorry, still cannot make it out.
Not sure if it is just me or if anyone else has the same issue.
It may be that all I have is an iPad.
Scotty
Old 12-20-2021, 05:45 AM   #924
STREMN's Avatar
2008 30' Classic S/O
Hampton Beach , New Hampshire
S/OS Member List
S/OS Member List -
Originally Posted by booma View Post
Gary,
Scotty
Hi Scotty - In our last update of the list we increased the number of rows available to post on. The list as we see it on the forum is a .jpg photo that gets scaled down to display as a thumbnail.
Tapping or clicking on the thumbnail opens it into a larger screen format. For detailed viewing: Use pinch and stretch gestures on the image with index finger and thumb...that should magnify and expand the image as it's displayed on screen.
Tom - S/OS #025
Name:	ipad screen gesturres.jpg
- Tom and Wendy - AirSTREMN from New Hampshire -
- 2008 30' Classic S/O - S/OS #025 - Riding on 16" Wheels and Tires -
- Live Free or Die -
STREMN is offline   Reply With Quote
Old 12-20-2021, 06:55 AM   #925
STREMN's Avatar
Member List Updated Format
Member List Updated Format -
I found an iPad to view the forum and thumbnails to better understand Scotty's request. The iPad screen resolution to view the expanded thumbnail wasn't enough to clearly read the list.
I reformatted the list to a PDF document to fix the resolution issue for iPad. Surprisingly Android Phone and Windows Desktop didn't have the same resolution issue.
I'll explore other options if the PDF format ends up being too cumbersome.
Tom - S/OS #025
Old 12-20-2021, 07:14 AM   #926
GCinSC2's Avatar
Data Officer Tom to the rescue.
Old 12-20-2021, 07:38 AM   #927
STREMN's Avatar
Member List Format
Member List Format
I changed up the member list and split it into a couple of pages. Pretty cool that there are so many Sliders on board. I'm trying this again with JPG's of each page for simpler "at a glance" reference.
Tom - S/OS #025
Name:	Slide-Out Member List Pg 1.jpg
ID:	409525 Click image for larger version
Name:	Slide-Out Member List Pg 2.jpg
Old 12-29-2021, 07:43 AM   #928
Al and Missy's Avatar
2002 30' Classic S/O
Fleming Island , Florida
30’ Classic SO Black Dump Linkage
The black tank dump linkage, among other things, was damaged when I had a tire tread separation. 10 weeks at a dealer repeatedly asking them to make sure it was functional after repair and it doesn’t close the valve all the way but the linkage is out of travel at the handle support bracket. If I back the handle out the rod end pushes past the bracket.
If you have a Classic 30 slideout please send me pictures of your black tank dump handle linkage to the dump valve.
Old 12-29-2021, 08:03 AM   #929
GCinSC2's Avatar
Al,
Pic of both valves and stem extensions from my 2007. Is that what you're looking for?
Gary
Old 12-29-2021, 08:09 AM   #930
Looks exactly like mine. I’m thinking about replacing at least the black tank link with the Camco cable system or even the electric actuator. What did you do?
Old 12-29-2021, 08:23 AM   #931
GCinSC2's Avatar
Al,
It does have a bind quality on a rough day. Never messed with ether alternatives. Sometimes I have double handed the valve, one on handle, one where extension attaches to valve stem.
Gary
Old 01-04-2022, 03:56 PM   #932
Out with the old, in with the new
Water compartment, that is. I either needed to pull and refurbish it or replace it. I had been looking for the stainless replacement for a year or more and finally found one. Since they couldn’t get my damaged door replaced after waiting 10 weeks I packed up and came home. If they had put the door on I would have had to pull it to replace the compartment. So now I’ll be ready if the door ever comes. .
Old 01-04-2022, 04:04 PM   #933
GCinSC2's Avatar
Al,
Didn't know it was a bolted in unit. Make sure you lock it in lest an envious Classic owner spots it. Looks nice.
Gary
Old 01-05-2022, 06:29 AM   #934
stanp001's Avatar
2005 30' Classic S/O
2003 34' Classic
Madison , Alabama
Originally Posted by GCinSC2 View Post
Al,
Gary
Al,
An tips or tricks to the replacement that you can share? I have one I need to do for my non-slideout trailer. My slide out trailer will eventually need the replacement as well.
Stan
BRN 1221, S/OS #024, KK4PF
2016 Silverado K2500
stanp001 is offline   Reply With Quote
Old 01-06-2022, 07:31 AM   #935
Originally Posted by stanp001 View Post
Al,
Stan
Hi Stan,
Generally speaking, it was easier than I thought, at least after I found the stainless unit. I have been looking for over a year. Airstream has/had the "right side" (city water hookup and water faucet on the right end) unit in stock, but not the left.
You have to remove the water compartment door, then take out the rear and front screws and the screws holding the black tank flush inlet sub-panel, all of which are in the removable partition in the middle of the compartment and remove it. This will give you access to unscrew the hose-bib-type fittings on the rear of the city water inlet and the hose bib. Then you remove the screws at each end and the rear of the compartment and you can pull it down and out.
There are a couple of potential "gotchas" with the stainless unit. The screw holes at the bottom rear for the partition and the one at the right rear weren't there and there was a hole at the rear of the right end in the stainless unit that wasn't in the original. I drilled the compartment for the screw to hold the partition and drilled the trailer at the rear of the right end panel to match the hole in the new compartment. I just realized that the holes to mount the compartment door may not be there in the stainless version (I'll have to look to be sure) and would be a lot easier to drill with the compartment out. I'll have to wait until I get a replacement door to match drill to mount it.
There is one problem I haven't solved yet. Garden variety stainless sheet metal screws will not start in the stainless compartment. The stainless sheet metal is harder than the screw and just wears away the threads on the screw. A friend who is a machinist suggested just using pop rivets but I don't think that is a good idea for the plastic city water inlet, and there may not be access for the rear of the partition. Harder screws made of 410 stainless are available. I'll try to round up some and see if they will work. I may put in "Rivetnuts" for the city water inlet and the partition if the 410 screws don't work out.
This "RVing" is fun.....
Al
Old 01-11-2022, 05:40 AM   #936
stanp001's Avatar
2003 34' Classic
Madison , Alabama
Originally Posted by Al and Missy View Post
Hi Stan,
Generally speaking, it was easier than I thought...
Al
Al,
Thanks for the detailed reply. This will be very helpful when I get to this project.
Stan
Old 01-12-2022, 09:23 AM   #937
Al,
Stan
On finishing up, I have a clarification and a couple more tips.
Tip 1. Match drill the compartment front to take the pop rivets for the door. I did’t do this. It is much harder to do after the compartment is mounted.
Clarification:
What I described as “garden variety sheet metal screws” were not. I tried to re-use the screws Airstream used to mount the city water inlet, the hose bib, and the partition. They were self-drilling screws and apparently the threads were not as tall as a standard sheet metal screw and wouldn’t bite in the stainless. In desperation I bought some standard sheet metal screws at HD. They worked.
Tip 2:
To mount the black flush inlet, I did the following:
0. Before mounting everything, leak test the city water inlet under pressure.
1. Loop some string around the black tank flush fitting behind the flange and route it out the front.
2. Slant the rear of the partition into the compartment with the plumbing.
3. Guide the black tank flush inlet fitting into its hole in the partition.
4. Maneuver the partition roughly into position.
5. Use an ice pick to align the rear mounting hole in the black tank flush sub-panel with the hole in the partition.
6. Pull out and up or down on the string as required to align the front mounting hole of the black tank flush mounting flange with the hole in the partition and secure the two with a screw.
7. Pull the ice pick and put in a mounting screw.
8. Align the hole in the rear of the partition with the hole in the rear of the water compartment and screw it in place.
9. Pull the string out.
10. Maneuver the partition into position and secure the front with two screws.
Congratulations- you just saved $350, which is what I was quoted for a dealer to do the job.
Old 01-12-2022, 12:12 PM   #938
All done!
Here’s the end product (minus the AWOL door).
Old 01-13-2022, 07:25 AM   #939
Al,
Gary
Gary,
How is it your valves were out? Did you replace them? Did you replace the black extension? If so where did you get it? Did you bend it?
Al
Old 01-13-2022, 07:39 AM   #940
GCinSC2's Avatar
Al,
One of my valves was weeping from a damaged blade/seal. As I was going in I did R&R both valves.
The Z bend in the black tank extension valve is stock, as issued. If you're having difficulty finding one I think I know where some are.
Gary
1961-1963 Airstream Bambi owners registry RichardT 1961 - 1963 Bambi 66 08-20-2022 05:39 PM
Registry - How do I add mine to AIR Registry? tomandjana97 Forum Admin, News and Member Account Info 1 07-07-2015 05:05 PM
'Secret Society'?????? jordandvm Off Topic Forum 28 04-11-2008 12:02 PM
WBCCI A Secret Society? myboyburt WBCCI Forum 35 02-28-2006 02:04 PM
