06-26-2019, 04:24 PM
#721
Slide out society #002
2003 30' Classic S/O
Newnan
, Georgia
Big Daddy is about whooped!
Big Daddy and Nonna have our grandkids camping this week in Cherokee, NC. We are not accustomed to extra company in the Stream. The slide makes it possible! That extra room makes a nice difference.
Having a blast just wanted to say hello to all you sliders out there! Having a ball.....Don & Betsy
06-26-2019, 05:34 PM
#722
2007 30' Classic S/O
Somewhere
, South Carolina
Crawdad stew and crawdad omelets coming up courtesy of the g-kids.
Behave your selves, sorta.
Gary
06-30-2019, 12:56 PM
#723
Slide-Out Society #107
2006 30' Classic S/O
Bloomington
, Indiana
Slide-Out Owners Society Registry
Haven't been on the Forums in a while and found I missed a message (forgot to change email on Forum). Still have my 2006 30' S/O Classic Limited Wally Biam Caravan Club 50th Anniversary Edition. Updated my email to received messages in the future!!
Phillip Dart
dart110
06-30-2019, 07:27 PM
#724
2008 30' Classic S/O
Hampton Beach
, New Hampshire
Slide-Out Society
Phillip Dart
dart110
Hi Phillip,
We're glad you found us! Welcome aboard! Gary S/OS #001 will come sliding around and get you one of those "Official" like S/OS #'s...
All the best!
Tom - S/OS #025
- Tom and Wendy - AirSTREMN from New Hampshire -
- 2008 30' Classic S/O - S/OS #025 - Riding on 16" Wheels and Tires -
- Live Free or Die -
06-30-2019, 07:42 PM
#725
Hampton Beach
, New Hampshire
Slide-Out Society - Updated Member List
I haven't posted an updated member list in awhile and with the latest Sliding in of dart101 it's probably a good time for it.
I'm gonna jump protocol and put it out so our Grand Slider Gary S/OS #001 can confirm our latest addition.
Humbly yours...
Tom - S/OS #025
07-01-2019, 06:00 PM
#726
Somewhere
, South Carolina
Phillip Dart
dart110
Man oh man I'm slipping took me almost 24hr to catch up with Phillip and Data Officer Tom.
Phillip greetings and such from kinda steamy SC and D.O. Tom got it right but he keeps the books anyway.
Phillip you're S/OS#0107
Enjoy the slide and travel safe. Good looking combo rig BTW I'm partial to those compression ignition big inline 6 cylinder power plants.
Gary
07-11-2019, 05:52 PM
#727
2008 34' Classic S/O
Arnprior
, Ontario
help with my slider set up!
Hi Folks
I need some help setting up my 08 34 slider. I make sure that we are level, fore, aft and side to side. I then add a little pressure from my stabs then.... extend my slide. In about 50% of the time we are good to go. The other 50% is my problem. My door doesn't line up properly. It drives me nuts! I have heard about putting blocks under one axle but this helps "sometimes"! Please if you have some actual experience with this..... please let me know the secret.
Thanks in advance.
Pete
Pete Crook
"Put it all behind you!"
S/OS#88
07-11-2019, 06:30 PM
#728
Somewhere
, South Carolina
Pete
Have you tried no stabilizer test door then a tiny bit of stabilizer test door and see if it changes and then the watch this with the stabilizer get the video going and try door again.
I’ve put too much force on stabilizer and the porridge was too hot not hot enough and it was a mess but finding the sweet hot spot and it was just right.
How are the hinge pins doing? Door snug and smooth or loose and sloppy?
Gary
07-11-2019, 10:50 PM
#729
Rivet Puller
2003 28' Safari S/O
Atlanta Burbs
, Georgia
I experienced the door issue a couple times during the first few outings with my trailer over ten years ago. Thereafter, I stuck to the following sequence which stopped the issue except for a handful of times when the soil got drenched during the stay and compressed.
I start by dropping the forward street side stabilizer closest to the slide and work my way around until I reach the forward curb side. I almost always use a 8"x8"x3/4" board under the pads and turn the crank just a fraction less than 1/4 turn after contact. The larger contact pad seems to have helped with loamy field compression issues.
Sir Tristan
Air #48582, S/SO #003, WBCCI #4584
07-13-2019, 06:31 PM
#730
Arnprior
, Ontario
Thanks for the feedback. My door is as tight as a mouse's ear! The part that bugs me is that there is no rhyme nor reason to it! I think that I will look closer the next time out and play with the stab adjustments a bit more. I have the electric versions so maybe I need to get faster on the trigger when I set them down. This is going to need some deep thought and a lot of beer!
Thanks to all
Pete
Pete Crook
S/OS#88
07-14-2019, 05:11 AM
#731
Somewhere
, South Carolina
Got beer get solutions. It’s in the handbook.
07-14-2019, 04:29 PM
#732
2002 30' Classic S/O
Fleming Island
Stabilizer Wired Remote Control
I'm considering doing this. Actually I am within $60 of being committed to do this.
It hurts my back and quads to bend over long enough to run the stabilizer jacks up and down every time I make or break camp. I have designed an add on consisting of two sets of a relay box with two relays and a single plug-in switch box with two switches. The idea is you would take the switch box to the rear stabilizer jack panel, plug it in to the added relay box and while standing use the two switches to run the roadside and curbside jacks up or down as required, unplug, move to the front and repeat.
So I'm wondering if this is something that folks with electric stabilizer jacks (like Slideouts, for sure) would be interested in. I'm ordering 9 boards, due to the minimum buy from the PCB house. I will build mine and test them and if successful I will have 7 boards left over. It takes one relay for each motor, i.e. 4 per trailer and they run about $6 each. If the interest is overwhelming (doubtful) I can order more boards.
Each user would buy their own housings, switches, relays, and PCBs, build up their relay boxes and switch box and connect the relay boxes into the jack control panel. Each relay box would connect to power, ground and the two motors for a total of 6 wires.
An upgrade I'm considering is to add on key fob remote control to eliminate the need for the switch box and waterproof connectors on the relay boxes.
PM me if this is something you would be interested in doing.
Al
07-14-2019, 04:47 PM
#733
Somewhere
, South Carolina
Al
Understand the issue and I’ve thought about separating the switches and moving switch for curb jack from street side to curb side.
Never thought of a remote like you’re proposing.
I’ll be curiously watching.
Gary
07-15-2019, 06:39 AM
#734
Garden Valley
, Idaho
Speaking of the jacks, I got tired of bending down on my knees to position the blocks/pads under the jacks, and retrieving them. So I bought a junker golf iron for $5 and have been using it for years. It maneuvers the pads exactly where I want, and makes it easy to drag them out as well. In a pinch, it could be a weapon too.
Pap
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
07-18-2019, 06:18 AM
#735
Airstream - Other
G
, North Carolina
Slide Out Society
I'm interested. 03 safari 28so. So how do I sign up?
Philcan56
07-18-2019, 08:40 AM
#736
Somewhere
, South Carolina
Philcan56,
You just signed up wasn’t that easy. I’ll get your number tonight I’m still in the office for a little while.
Gary
07-18-2019, 05:40 PM
#737
Somewhere
, South Carolina
Philcan56
OK Philcan56,
From the S/OS HQ in the Pee Dee region of SC yeah it's for real I can't make that one up with the big traditional Whump of the Hickory Stick and the Buddy Rich drum solo, wait for it, here it comes
Philcan56 you're S/OS#0108
If you have any questions, please feel free to post. Guaranteed honest answers absolute bluffs, and other sorted levels of forum replies.
You've got a unique trailer, enjoy and safe travels.
And Data Officer Tom will update the official list as soon as W lets him.
Gary
07-19-2019, 12:46 AM
#738
2005 28' Safari S/O
2017 27' International
Phoenix
Originally Posted by GCinSC2
OK Philcan56,
Gary
Welcome, Philcan56! I’m #107 and I have on 04 Safari 28 s/o.
Ed
07-19-2019, 05:06 AM
#739
Hampton Beach
, New Hampshire
Welcome aboard Philcan56 S/OS#108 with that cool 03 Safari S/O !!!
Our Grand Slider has done the job of sliding out that coveted S/OS #...thanks for that Gary!
Hot here in the Northeast...in for a hot weekend of mid 90's. It's not the norm for us folks...so if your in the area please avoid the piles of clothes where people are just melting away from the heat.
I've included our member list updated with Philcan56 S/OS #108 and the model count.
Great adventures!
Tom - S/OS #025
07-23-2019, 05:16 PM
#740
Planerider
Clermont
Hi Everyone,
Just realized there was a Slide Out group.
Have not been on the forum for a while.
We have had ours since 2007 Classic Limited 30. We have in Parked in Tennessee.
We just decided to sell it so if you know anyone interested it is on the Classified.
