Old 01-29-2019, 07:20 PM   #601
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Originally Posted by loft47 View Post
I would like to join this group. We have an 07 30’ Classic with slide.
Mike. #1469
Mike,
Great to have you join us, always room for another and based on our Data Officer Tom's expert records are you sitting down, awnings in and secured:
The Slide Out Society welcomes Mike and issues S/OS#097.
Hey you got the same year and model as me!
New to the Slide Out? This model was subject to two AS recalls on the brakes for new hoses and inspecting the actuator. Been performed? got questions?
Welcome,
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 02-04-2019, 06:14 AM   #602
STREMN's Avatar
2008 30' Classic S/O
Hampton Beach , New Hampshire
Slide-Out Society - Updated Member List
Welcome Mike S/OS #097 - 2007 Classic 30' S/O
We're happy to have you aboard the Slide-Out Society! Please consider coming to AlumaSlider2 October 18-20 2019 Stone Mountain State Park in North Carolina. http://www.airforums.com/forums/f288...ml#post2201312
I've updated our Member List and the totally unofficial Slide-Out Model number count.
Tom - S/OS #025
ID:	332925   Click image for larger version
- Tom and Wendy - AirSTREMN from New Hampshire -
- 2008 30' Classic S/O - S/OS #025 - Riding on 16" Wheels and Tires -
- Live Free or Die -
STREMN is offline   Reply With Quote
Old 02-09-2019, 08:07 PM   #603
2020 16' Basecamp
Marianna , Florida
Hi - I’d like to join this group, please. Thanks to the group’s feedback, I overcame my fear of slide outs and took the leap to purchase “Mildred.” She’s a 2005 30’ Classic S/O. We will be picking her up next week.
I’m gathering all of the accessories and supplies but am uncertain about the TV antenna setup. Is there some sort of universal mount or will I need a custom installation for the HD antenna? Thanks
Mellie is offline   Reply With Quote
Old 02-09-2019, 08:45 PM   #604
Slide out society #002
Nogginsbro's Avatar
2003 30' Classic S/O
Newnan , Georgia
Welcome Mellie and Mildred! You will love your slide! I know we do!
We use a dish but I’m sure others can help with antenna.
Welcome!
Don & Betsy
2003 30' Classic Limited S/O
2015 F350 diesel 4X4
Amateur radio call KB4GFN
Nogginsbro is offline   Reply With Quote
Old 02-10-2019, 05:37 AM   #605
STREMN's Avatar
Welcome aboard!
Hi Mellie - Welcome to the group Slider! We're excited for you with the new to you Slide-Out. I've got some intel that Gary S/OS #001 is out Sliding around on an adventure. He'll Slide you out that official S/OS # soon. LoL
We've got a 2008 Classic 30 S/O and it came with a Winegard Sensar TV antenna on the roof just above the entrance door area. I'd make a WAG that yours is probably the same, unless a PO made a change. It folds down flat on the roof when not in use. There's a crank handle on the interior ceiling in the same area to raise and lower the antenna. These are directional so you point it in the direction of the stations. A collar at the crank handle lets you turn the antenna to point it.
We had to replace our antenna head with a newer model to catch digital channels. Ours was original to the trailer and needed to be updated for the DTV conversion. That was a simple and inexpensive ($49) swap that took all of 5 minutes with a ladder. The new unit works great. You can find replacements on Amazon, along with many other options to catch broadcast tv.
Here's to you and Mildred!
Tom & Wendy - S/OS #025
Old 02-10-2019, 10:56 AM   #606
nswhite's Avatar
2005 30' Classic S/O
Phoenix , Arizona
Hi Mellie, If you have the original bat wing antenna, it will pick up HD. However, you can add the Wingman to improve the signal. It works just fine for us. https://store.airstream.com/product/winegard-wingman/
Welcome to the group!
nswhite is offline   Reply With Quote
Old 02-10-2019, 02:01 PM   #607
GCinSC2's Avatar
Mellie,
Big congrats and keep the questions coming, but business first.
Fresh from a long weekend getaway with my better half and checking Data Officer Tom's file..............Mellie you are S/OS#098
Wahoo!
Don't forget to check your possibles and see if you can make it to Alumaslider II this Oct.
Now one additional TV antenna quirk, look at the dial just above the crank handle, see an arrow on the base and an arrow on the rotator ring? When lined up, safe to lower and raise. If not lined up with antenna up pull down slightly on rotator ring and turn to line up arrows. That puts the mast in the correct position to park it on the roof. Wrong position, not sure how much that'll cost, but one time it cost me a radio antenna.
Not sure if your AS has the TV signal amplifier , consult manual for details.
Safe travels,
Gary
S/OS #001
Old 02-10-2019, 03:00 PM   #608
2020 16' Basecamp
Marianna , Florida
As usual, y’all are helping me prepare to slide right out onto the road with Mildred next week. Thanks again for all of the support.
We are thrilled to officially be “Slider #98!” We look forward to meeting some of y’all at a rally in the near future.
I’m sure I’ll be shouting out for more help after we pick Mildred up next week.
Old 02-14-2019, 07:54 PM   #609
2020 16' Basecamp
Marianna , Florida
What size trailer ball do I need to tow the slide out? Thanks #098
Old 02-14-2019, 11:29 PM   #610
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
Mellie,
The ball size is the standard 2 5/16" size.
I grease the hitch ball with bearing grease before each coupling. I do all my own maintenance including repacking bearings so I usually have a container of 'extra' grease in my garage. Bearing grease is thick and does not drip. A little goes a long way.
Be sure your hitch is rated to handle the 1,000+ pound tongue weight of a SO. Only a limited number of Class IV hitches are rated for more than 1,000 lbs. You may need a V.
Sir Tristan
Air #48582, S/SO #003, WBCCI #4584
SeeMore is offline   Reply With Quote
Old 02-15-2019, 08:17 AM   #611
2020 16' Basecamp
Marianna , Florida
Great idea to grease the ball. That will sure save a lot of extra work.
Good feedback on the hitch too.
Thanks bunches
Old 02-15-2019, 09:52 AM   #612
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Not to start another mine is better discussion, but what hitch are you using to tow the slider with?
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 02-15-2019, 09:52 PM   #613
2020 16' Basecamp
Marianna , Florida
Unfortunately, that’s a moot point right now. We did the walk through today, discovered a problem with a water leak in an air conditioner and while they were fixing it, a fire almost started. So, we stopped the closing and are awaiting a response from the dealer on the repairs.
It was a sad but good moment. I learned the smoke alarms need to be replaced every 5 years and thankfully, we weren’t caught in an RV that was on fire.
Fingers crossed that everything works out and we are able to get her.
Old 02-15-2019, 11:51 PM   #614
Wow! I hope it all works out for you.
Al
S/OS #004
Old 02-16-2019, 06:22 AM   #615
GCinSC2's Avatar
Mellie,
Sorry to hear that but at least you were able to walk away and regroup.
Good luck keep us posted.
Gary
S/OS #001
Old 02-16-2019, 06:23 AM   #616
ZoominC6's Avatar
2004 30' Classic Slideout
Colleyville , Texas
Howdy from DFW. We're original owners of a 2004 30ft Classic and have used it extensively since '04 with travels to most of the USA and Canada. We've remodeled it with new flooring, leather upholstery, Sleep Number bed, roof mounted sat antenna, Hensley Hitch and disc brakes. We love the newer models with two ACs, 8" wider coach and twin beds but don't feel comfy with the techy stuff and complaints from owners we've met on the road to say nothing of the price! A mortgage doesn't appeal either. We have had trouble with bolts breaking on the S/O mechanism but we now have a great vintage repair shop in the northern part of DFW so we feel confident the slide is repaired once and for all. Time will tell.
Happy trails all
In dog years, I'm dead!
ZoominC6 is offline   Reply With Quote
Old 02-16-2019, 07:54 AM   #617
STREMN's Avatar
Mellie,
Good luck with your prospective rig we all hope it works out for you!
Tom - S/OS #025
Old 02-16-2019, 08:01 AM   #618
STREMN's Avatar
Welcome!
Happy trails all
We're glad you found us ZoominC6! Welcome to the Slider Registry! I'd love to hear more about your Sleep Number sometime...they seem pretty intriguing but I haven't done any research. Love to hear your comments about how it's worked for you.
Tom - S/OS #025
Old 02-16-2019, 12:03 PM   #619
GCinSC2's Avatar
Happy trails all
ZoominC6,
Welcome to the Slide Out Society, and you can speak for over 14 years of Slide Out experience as original owners.
So greetings to ZoominC6 from home base here in SC on a dreary drizzly but still a Saturday to our DFW TX based newest member.
S/OS#099
Hope you can look at your fall calendar and see if Alumaslider II in NC makes you guys feel like traveling.
http://www.airforums.com/forums/f288...-a-188183.html
Regards,
Gary
S/OS #001
Old 02-16-2019, 12:08 PM   #620
GCinSC2's Avatar
I see Tom just hit 500 posts!
S/OS #001
1961-1963 Airstream Bambi owners registry RichardT 1961 - 1963 Bambi 64 11-20-2015 11:47 PM
Registry - How do I add mine to AIR Registry? tomandjana97 Forum Admin, News and Member Account Info 1 07-07-2015 06:05 PM
'Secret Society'?????? jordandvm Off Topic Forum 28 04-11-2008 01:02 PM
WBCCI A Secret Society? myboyburt WBCCI Forum 35 02-28-2006 03:04 PM
