Originally Posted by Native143
I already have a quick connect hose hose that hooks up to my Airstream's port. But the other end does not fit the Coleman stove, ie the 1 lb. fitting. Is there are gadget for that rather than getting your suggestion. I don't want to have to unscrew hoses when I have an easier way. Thanks.
If you eliminate Coleman's regulator and use this instead
https://propanegear.com/coleman-road...t-gen-2-12-ft/
If the hose you have is long enough for you, you can convert the stove end of the hose to a LOW pressure female quick connect fitting and use this in place of Colemans regulator.
https://propanegear.com/coleman-roadtrip-adapter-gen-2/
In any event you must eliminate the Coleman regulator to use the trailer's low pressure quick connect, it converts high pressure propane (like from the 1 lb bottle) to low pressure propane.
Dave S
