Old 04-30-2006, 07:50 PM   #1
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Unhappy Popcorn not popping
I tried popping popcorn in my Sharp Carousel Convection Microwave.
I used the popcorn setting and a standard size bag. Only a third of the kernels popped. Bummer
Any suggestions?
Michelle TAC MT-0
Sarah, Snowball
Old 04-30-2006, 08:07 PM   #2
tinman7's Avatar
1976 27' Overlander
St James City , Florida
Images: 13
Old popcorn!
tinman7 is offline   Reply With Quote
Old 04-30-2006, 08:10 PM   #3
Images: 59
What brand?
Old 04-30-2006, 08:44 PM   #4
Keymar , Maryland
Orville Redenbachers Movie theatre butter.
I have not have a problem with this brand in my home based microwave. It is 1100 watts.
Michelle TAC MT-0
Sarah, Snowball
Old 04-30-2006, 08:51 PM   #5
Images: 59
You are right that the wattage may be a problem. Less than 700 watts won't work very well. Also be aware that microwave ovens lose power as they age. A six year old oven may lose as much as 40% power.
Is it possible that the bag had a hole in it? That can prevent inflation and reduce popping drastically. If they bag did not inflate it's probably a broken bag.
And old popcorn may also be a problem, although microwave popcorn doesn't dry out as fast as non-microwave corn.
An interesting fact about microwave popcorn (and other microwave products) is that the consumer usually blames himself first, then his microwave, and lastly the product. Sometimes the product is just junk.
Old 04-30-2006, 08:59 PM   #6
Huh?
Ultradog's Avatar
1975 27' Overlander
Twin Cities , Minnesota
Images: 8
I believe it has something to do with the radar waves bouncing off of the aluminum panels that causes the microwave to function at a lower wattage level. Redenbachers makes a special blend of popcorn using coconut oil and bauxite that seems to work well in most campers. It is available from Thor Industries and Inland RV. The wrapper has foil and not paper.
It's pricey but just one of those things you silently put up with if you own an AS.
Ultradog is offline   Reply With Quote
Old 04-30-2006, 09:50 PM   #7
CanoeStream's Avatar
St. Cloud , Minnesota
... and Michelle's microwave is new enough you could almost call her Classic a 2007!
Originally Posted by Ultradog
Redenbachers makes a special blend of popcorn using coconut oil and bauxite ...
Bauxite = what Airstreamers eat instead of maize! Although the remainder of your post proves why I usually don't wear my Aluminum Foil Deflector Beanie inside my Safari.
5 meter Langford Nahanni
Old 04-30-2006, 11:27 PM   #8
CONSUMR
CONSUMR's Avatar
Images: 20
Send a message via AIM to CONSUMR
We had the same problem. Don't remove the metal rack from the microwave.
"The first step to recovery, would be admitting I have a problem." CONSUMR
CONSUMR is offline   Reply With Quote
Old 05-01-2006, 05:23 AM   #9
DEO
DEO's Avatar
West of Boston , Massachusetts
Any suggestions?
We use the Sharp Microwave all the time.. We don't use the popcorn setting (the instructions on the popcorn bag we got said not to) Just set for 4 minutes and when you hear the poping slow down to about 1 pop per second it is ready... be careful it comes out hot!
DEO is offline   Reply With Quote
Old 05-01-2006, 06:30 AM   #10
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
Geez, and I thought I had problems.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 05-01-2006, 06:39 AM   #11
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Michelle, is this the microwave that came with your new coach?
If so, does it heat everything else satisfactorilly?
Old 05-01-2006, 06:42 AM   #12
Images: 59
In some Sharp convection/microwave ovens, the carousel is metal.
The susceptor (that's the metallic heating patch) in a bag of popcorn absorbs microwave energy to heat the popcorn. In order for the susceptor to work properly, it must be at least 1/2 wavelength from any other metal surface.
In my Sharp Carousel with the metal carousel, I always put the popcorn bag on a microwave safe plastic plate, turned upside down, to elevate the bag above the metal.
Old 05-01-2006, 08:08 AM   #13
Keymar , Maryland
Sounds like I made a wavy error. I thought about the using the grate but that puts the bag pretty high when it would be full. I will try it again witht he grate or a plate, or something to get it up off the floor of the carosel.
It is the orginal micro with the coach and only about a month old.
Michelle TAC MT-0
Sarah, Snowball
Old 05-01-2006, 10:24 AM   #14
SilverRanger's Avatar
2005 19' Safari
1968 24' Tradewind
Rural , Delaware
My AS has the same Sharp microwave/convection oven setup. Shortly after we got it home from a camping trip and plugged in to a 20 amp outlet, just to keep the batteries charged and operate the reefer, my wife fired up the microwave to warm something and noticed that it was taking longer than it should. I then realized the problem could have been that my extension cord was 14 ga. @ 100 ft. I have since made up a much shorter 10 ga. extension cord and it now seems to work fine.
SilverRanger is offline   Reply With Quote
2006 classic
Breaker Popping tomriley Electrical - Systems, Generators, Batteries & Solar 8 02-09-2006 06:16 PM
Sharp Convection/Microwave failure myoung Furnaces, Heaters, Fireplaces & Air Conditioning 7 01-01-2006 05:53 PM
2005 Cherry Blossom Rally fireflyinva WBCCI Rallies & Events 40 10-18-2005 05:46 PM
Furnace "backfires" when hot paddy79 Furnaces, Heaters, Fireplaces & Air Conditioning 6 12-13-2004 08:19 PM
popping fuse on tow vehicle Stefrobrts Tow Vehicles 14 07-07-2004 01:43 PM
