Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Classic > 2006 - 2010 Classic (all lengths)
Old 11-04-2014, 05:15 PM   #1
Bbelk's Avatar
2010 27' FB Classic
Not a good week for the Airstream
Thats probably not true, but more stuff broke this week than all last summer.
A bolt fell out of the steps and is now rattling around behind a riveted panel. Any suggestions would be appreciated.
I broke the awning at 2:00 AM putting it away in a windstorm. Just this little part here, I just have to figure out where to get one.
And finally, when I got home, I found the bracket on the kitchen counter extension broke. I have this recollection of reading something about that bracket on this forum but I don't have any idea how to look it up. If there is something smarter than just replacing it with an OEM part, please let me know.
2010 27FB Classic
1989 190 Class B (Sold)
1977 29 Ambassador Land Yacht (Sold)
Bbelk is offline   Reply With Quote
Old 11-04-2014, 05:29 PM   #2
BassCan's Avatar
2014 27' FB Eddie Bauer
Mobile , Alabama
Well they say things happens in three's. Our bracket was knocked off the kitchen counter extension. Repaired with toothpicks and a lager screw. Waiting for the for then next two things to break. At less you got it all at once.
BassCan is offline   Reply With Quote
Old 11-04-2014, 05:32 PM   #3
2010 25' FB Flying Cloud
Davenport , Iowa
The awning part can be ordered from Zip Dee. It is called the claw, I carry extras, and also order the assembly as it is easier to replace. When ordering the parts, consider the door roller and the "lift handles.
mike
Airtandem is offline   Reply With Quote
Old 11-04-2014, 07:06 PM   #4
dznf0g's Avatar
Oswego , Illinois
Page 5 here shows the upgraded bracket. Mine has been on for some time now and is FAR superior to the original.
http://www.airforums.com/forums/f366...t-78400-5.html
-Rich-
Old 11-04-2014, 07:24 PM   #5
pgr32e's Avatar
1974 27' Overlander
Sault ste Marie , Ontario
can you either reach the bolt with a magnet on a flex rod or pull it to where you can get it?(good magnet on outside of panel and slide it along) If you have trouble getting the end fitting for the awning, I made one by welding a new blank piece and filing the slot, works fine......Phil.
pgr32e is offline   Reply With Quote
Old 11-05-2014, 06:48 AM   #6
Bbelk's Avatar
2010 27' FB Classic
If I can recover the bolt, how do I reinstall it without removing the riveted panel to the right of the steps?
2010 27FB Classic
Old 11-05-2014, 07:54 AM   #7
Bbelk's Avatar
2010 27' FB Classic
Getting closer now. I have the shelf bracket figured out, but I have not done it yet.
Is this a Bright Claw or a Satin Claw?
2010 27FB Classic
Old 11-05-2014, 08:28 AM   #8
dznf0g's Avatar
Oswego , Illinois
Satin, I believe.
-Rich-
Old 11-05-2014, 10:25 AM   #9
Cardiff , California
Claw from Zip Dee
Having just read your post about the broken claw and then seeing the follow up about Zip Dee parts - and knowing I had the exact same issue - I took it upon myself to call Zip Dee. Here's what happened:
1. I called 800-338-2378
2. operator answered
3. I asked for parts
4. a gentleman in parts picked up
5. i explained i had a broken claw
6. he asked for model of Airstream
7. he then explained he can ship the claw + the arm its on - already pre-installed/attached
8. i gave credit card and shipping info
9. cost: $23 for part + 5$ for shipping --
10. Seems pretty awesome.
ryandanz is offline   Reply With Quote
Old 11-05-2014, 10:30 AM   #10
ShinyPete
ShinyPete's Avatar
2014 27' Flying Cloud
Bushnell , Florida
Awesome and thanks for the info! Sounds like a good spare to have aboard.
ShinyPete is offline   Reply With Quote
Old 11-05-2014, 10:38 AM   #11
paiceman's Avatar
2020 28' Flying Cloud
Upper St Clair , Pennsylvania
I also carry an extra claw. While bookdocking in Maine as you did in a wind storm it broke off. Had to hold the awning in place with DucTape for another 1,500 miles, actually worked great.
2020 28' Twin Flying Cloud
2021 F350 6.7 King Ranch
USAF Master Training Instructor (TI) & (MTI)- 68-72
Volunteer K9 Rehabilitator & Trainer
Old 11-05-2014, 11:26 AM   #12
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
On my trailer there is a riveted panel in the belly that can be taken out to access the nut for the step bolt. I need to tighten mine and that is the only way I see into it. But it looks like what Airstream intended for access. Not a big deal to drill it out and replace. In my case the PVC container for the dump hose is riveted across the access panel. I am waiting for a dry day to do it.
Old 11-05-2014, 11:34 AM   #13
Bbelk's Avatar
2010 27' FB Classic
Two claws have been ordered so I will have a spare.
The scary project was the front steps and they have been fixed for free.
This collared bold fell out of the right hand side of the steps with no easy way to retrieve it.
So I cut this hole from the bottom in the black panel to the right of the steps.
Found the bolt and returned it to its proper place and then patched the hole.
You can't see it unless you crawl under there.
Now I just have to order the counter brackets.
2010 27FB Classic
Old 11-05-2014, 11:41 AM   #14
1967 17' Caravel
Pocatello , Idaho
Good work, Brad/Bbelk! All is solved and other suggestions are now available here from helpful forum members, too.
I love this forum!
Vivian
Landshark is offline   Reply With Quote
Old 11-05-2014, 11:53 AM   #15
macofpei's Avatar
2003 30' Classic
Stratford , Prince Edward Island
Send a message via Yahoo to macofpei Send a message via Skype™ to macofpei
I am so used to face book that I was looking for the "like" button. I guess I will say Thanks for this post.
Mac from PEI
Canada
WBCCI #4782
"Southern Belle"
'03 Classic 30'
'10 Toyota CrewMax
macofpei is offline   Reply With Quote
Old 11-05-2014, 12:05 PM   #16
Tltulsa's Avatar
1992 29' Excella
Tulsa , Oklahoma
Awning claw easy replacement, less than $20...i agree with the satin finish. The bolt in wall, different story! You could always immobilize the bold with some expansion foam. Replacing the bolt may take some tricky-dicky skills. Good luck.
1992 Excella Classic 29'
...2013 Chevy 2500 HD, 6.0 Gasser
Tltulsa is offline   Reply With Quote
Propane Gas Detector Went off Last Week-Turns Out NOT the Propane breezyway Electrical - Systems, Generators, Batteries & Solar 4 08-16-2014 08:56 AM
Airstream on the cover of Forbes this week munimula Airstream "In the News" 9 05-01-2009 08:25 PM
wanted: airstream rental in June, 1 week, in New Orleans j_c_c Off Topic Forum 4 04-22-2009 02:18 PM
airstream rally france coming up next week end Perry Other Rallies & Events 2 07-28-2007 06:32 PM
You would not believe what I saw in Sarasota last week!!! So I took a picture!!! TRAPEZE Airstream Motorhome Forums 41 05-11-2004 09:06 AM
