Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Classic > 2006 - 2010 Classic (all lengths)
Old 06-19-2016, 11:07 AM   #1
2009 30' Classic
Huntingdon Valley , Pennsylvania
How to remove refrigerator
I have a 2009 30' Classic Limited trailer and I need to replace the TV that is mounted on the wall between the dinette and the refrigerator. The power cord on the new TV is different and I need to replace it. The problem is that there is no give in any of the wires, (cable, audio/video, or power). Seems like the are pinched between the back of the wall and the refrigerator. So I think I need to slide out the refrigerator. Where are the attachment screws that hold the fridge in place? Thanks in advance for any advise.
Adirondack68 is offline   Reply With Quote
Old 06-19-2016, 08:02 PM   #2
Senior Member
sheriff1's Avatar
2012 27' FB Eddie Bauer
Sparks , Nevada
2 bolts in the rear into the floor 3/8" 1each right and left.
4 screws inside , 2 top, 2 bottom right inside the doors when open. They screw up and down into cabinets.
Disconnect propane and unplug 110ac cord
Cut the calking at the bottom of the refer where it sits on cabinet.
Get a milk crate and a friend and slide it out and set it on milk crate. It's heavy.
2015 F350 CC 4X4 6.7 Diesel
2010 27FB Silver Cloud "The Silver Spoon"
sheriff1 is offline   Reply With Quote
Old 06-19-2016, 08:04 PM   #3
Senior Member
sheriff1's Avatar
Sparks , Nevada
While your in there, replace the condensate drain hose off the back of the refer, if it's not brittle and broken, it will be.
Old 06-20-2016, 04:51 AM   #4
2009 30' Classic
Thank you. I will give it a try and post the result.
Old 06-20-2016, 11:40 AM   #5
1977 31' Sovereign
Lynnwood , Washington
Leave old wires buried inside the wall (out of sight, out of mind). Route new wires to your liking.
Tom
TomKirk is offline   Reply With Quote
Old 06-20-2016, 03:50 PM   #6
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
You'll find the refrigerator is (on purpose) very, very tight. For safety reasons, it has to be. Once you unscrew everything, you might find it helpful to have someone push from the back (avoiding wiring, coils, etc), as you pull from the front. Try to push/pull straight ahead. It's easy to get it wedged in place if you try to go side to side. Good luck!
_________________
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 06-20-2016, 04:51 PM   #7
2009 30' Classic
sheriff1, you had it exactly right. very simple to do. cutting the gunk at the bottom front was absolutely necessary. it wouldn't budge without doing that. it looks like the tv on that wall was a retrofit. thank you and to the other 2 repliers.
A tip: before disconnecting the gas line i bought a flair plug to seal off the end so that it will be easier to restart in gas mode.
I have been a trailer owner for the last 20 years (29' Prowler) but this is my first Airstream.
Thanks again.
How the heck do you remove the round retaining clips to remove the windows?? bvcg1 Windows, Doors, Locks & Vents 2 08-30-2015 01:57 PM
How to remove door to remove frig Silver84 Refrigerators 6 07-06-2015 01:32 PM
How to remove refrigerator 1975 Airstream? bearhere Refrigerators 7 06-09-2015 04:50 AM
HELP!! Bought new Dometic refrigerator--How do I remove the RM60? Shelby Copeland Refrigerators 6 07-17-2012 07:55 PM
74' Excella, to remove wiring or not to remove? BaltiHimal Electrical - Systems, Generators, Batteries & Solar 3 05-30-2010 10:23 AM
