Old 05-29-2011, 08:43 PM   #1
AirHedz's Avatar
2010 31' Classic
Keller , Texas
How do you close the door- 2010 Classic?
We have a '10 31 Classic. Needless to say, the first year has been very "challenging", to say the least. But, one thing I have yet to figure out is how to close the door. From the outside it's not as bad since I tip the scales at close to 300 lbs.. I just lean on it. But, from the inside, I haven't figured out how to close it without slamming it. With the amount of force it takes to close it completely it seems like something is going to break sooner or later.
Does anybody have any suggestion?
I looked to see if there was some sort of adjustment, but didn't see anything.
Thanks for your help!
Eric & Lisa
2010 31 Classic
2011 Ford F250 4x4 CC
AirHedz is offline   Reply With Quote
Old 05-29-2011, 08:48 PM   #2
More than one rivet loose
thecatsandi's Avatar
Missoula , Montana
It needs adjustment. The bolt coming out of the frame can be loosened. It has a rivet that holds the nut plate in place. It is hard to explain.
Michelle TAC MT-0
CP*2 blocks off US 12 and US 93
30A+10A/30A and Water
Sarah
, Snowball
I'd rather send my money to Mexico it keeps them there!
Old 05-29-2011, 09:00 PM   #3
AirHedz's Avatar
2010 31' Classic
Keller , Texas
I removed the bolt. There is no adjustment. It screws in and ou.t That's it. Seems like it should move toward the outside of the trailer, but it doesn't move that way.
Eric & Lisa
2010 31 Classic
Old 05-29-2011, 09:11 PM   #4
richinny's Avatar
2011 34' Classic
does it close better before you put the stabilizers down?
Ricky
richinny is online now   Reply With Quote
Old 05-29-2011, 09:34 PM   #5
AirHedz's Avatar
2010 31' Classic
Keller , Texas
No. It is the same either way. It's been a constant issue since it was new.
We have kept it in the same few places for the past year. All are concrete pads that are very level.
I really think the bolt just neefs to be adjusted. But, I can't get it to budge.
Eric & Lisa
2010 31 Classic
Old 05-29-2011, 09:45 PM   #6
MrUKToad's Avatar
2011 28' International
Chatham , Ontario
There's a nice fat rubber seal all around the door and it needs to be compressed a little in order for the door to close but for it to maintain that seal; our 2011 International is the same. I'm hoping that time will help as the seal will degrade slowly, other than that all I can suggest is that you use a careful but firm pull from the inside without lifting the handle any. Because of the height of the handle when you're inside, the natural tendency is to lift it slightly but that, of course just opens the door. Failing that, just slam it!
Steve; also known as Mr UK Toad
"You can't tow that with that!"
http://towedhaul.blogspot.com/
MrUKToad is offline   Reply With Quote
Old 05-29-2011, 11:20 PM   #7
2008 16' International CCD
kitimat , british columbia
http://www.airforums.com/forums/f485...tml#post869916
Tons of info here about doors that misaligne and close poorly. Judging by what I read on here it is a common problem. Yes while pulling it closed on the inside the handle can fall apart in your hands locking you in.
We are finally satisfied with the door, this week we straightend the indoor handle set that was bent from last years misadventure.
Snowey BC is offline   Reply With Quote
Old 05-29-2011, 11:49 PM   #8
6PackCharlie's Avatar
1995 30' Excella
Logan , New Mexico
We pull the handle out, push the door shut (compressing the rubber gasket) and then let go of the handle. We don't slam the door to get it to close.
Charles
Charles & Annette
WBCCI # 1407 -- Member 4CU
1995 31' Excella
Dodge 2500 Diesel-Tow Vehicle
___________________________________________
6PackCharlie is offline   Reply With Quote
Old 05-30-2011, 01:15 AM   #9
withidl's Avatar
2002 31' Classic
Houston , Texas
Yes, time will lessen the problem. My 2002 ASCL 31' door was difficult to close at first, but after a year or so the gasket yielded and now it can be pulled closed from the inside with minimal effort.
withidl is offline   Reply With Quote
Old 05-30-2011, 02:36 AM   #10
Lube the bolt and striker pocket with "silicone spray".
Magic will take place in front of your eyes.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 05-30-2011, 05:53 AM   #11
Well Preserved
overlander63's Avatar
Colfax , North Carolina
The door needs to be adjusted. Adjustment is usually done in a high-tech fashion, usually with a small block of wood and a heavy-duty technician leaning on it in strategic places.
Intelligence is learning from your mistakes. Wisdom is learning from others' mistakes.
Old 05-30-2011, 06:32 AM   #12
Missoula , Montana
Good point Terry. The door is made by different people on the line from the frame. They have a slightly different curve.
Michelle TAC MT-0
Sarah
, Snowball
Old 05-30-2011, 08:59 AM   #13
AirHedz's Avatar
2010 31' Classic
Keller , Texas
Charles
How do you "push the door shut" from the inside? I can push mine from the outside, and that's not much of a problem. But, the inside? Can't "push" it from there.
Eric & Lisa
2010 31 Classic
Old 05-30-2011, 09:01 AM   #14
AirHedz's Avatar
2010 31' Classic
Keller , Texas
That's going to be the next approach.
May just need a little "coaxing".
Eric & Lisa
2010 31 Classic
2010 classic
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
