Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electronics & Connectivity
Old 03-30-2017, 05:42 AM   #1
NCMEDIC's Avatar
2010 27' FB Classic
2003 36' Land Yacht XC Diesel 330 hp w/2slides
Shelby , North Carolina
Dish Tailgater/27FB
We have a Dish Tailgater system that I've used for several years on our fifth wheel and I would like to move it to the "new to us" 27FB.
I've searched and searched but I can't seem to come up with ideas on exactly how people hooked everything up.
What I'm thinking about at the moment is mounting the VIP211k receiver vertically below the tv and running the coax down into the fridge compartment, then using flat coax to connect to the Tailgater.
I'm not crazy about connecting to the coax under the dinette and then having exposed coax going up to the overhead compartment.
Does anyone have any better ideas?
Thanks!
NCMEDIC is offline   Reply With Quote
Old 03-30-2017, 08:11 AM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
If the receiver is mounted vertically and has a remote. I think you will have communication problems between the remote and the receiver.
I have a Tailgater. I believe it is recommended to use R6 coax for the dish to receiver connection.
Don't know how the flat coax you mention will work.
Old 03-30-2017, 09:12 AM   #3
Al and Missy's Avatar
2002 30' Classic S/O
Fleming Island , Florida
Once you are into the fridge compartment, put a connector on the coax. When you deploy the tailgater, use RG-6 coax to hook up to the connector in the fridge compartment through the door, left open in a crack. Or you could drill a small hole in the door or the trailer skin and use a 75 ohm double female connector.
Another alternative is to use the Cable TV coax. If your trailer has the two connector plate with the jumper on it for TV cable you can hook the Dish receiver up to that and then hook the tailgater up to the other end, wherever that is located on your trailer. If not, you can add one.
Here is a link to what I did:
https://www.airforums.com/forums/att...6&d=1469409767
You will note that I also mounted the DirecTV receiver vertically. The remote worked fine. Apparently there was enough scattering of the IR off the wall to close the link.
Al
Old 03-30-2017, 09:56 AM   #4
NCMEDIC's Avatar
2010 27' FB Classic
Al,
Thanks for the diagram. I get what you're saying but the satellite input is on the floor underneath the dinette. I'd have to put the receiver on the dinette table and have coax going up the side walls into the overhead compartment on the road side in order to connect into the existing onboard coax.
I'm just trying to avoid that, and I appreciate your thoughts on the fridge compartment.
Old 03-30-2017, 11:01 AM   #5
Sorry, missed the part about the coax under the dinette, or didn't understand it.
Al
Tailgater Satellite Dish-DISH TV Mrjkq Computers, Internet & Satellite 15 11-11-2016 11:18 AM
Dish Tailgater wncrasher Airstream Lifestyle 6 07-15-2013 05:20 PM
Any experiences with Tailgater Portable Satellite System by Dish? MarkMc Computers, Internet & Satellite 28 06-15-2013 09:16 AM
Dish Tailgater System with Airstream RichHog Audio, Video & TV 1 12-06-2012 05:39 AM
