Old 07-17-2019, 11:40 AM   #1
2007 31' Classic
Gulf Breeze , Florida
Corrosion
Does this look like Filaform corrosion?
trumpetguy is offline   Reply With Quote
Old 07-17-2019, 11:45 AM   #2
3rd one is the charm?
pcskier's Avatar
2014 23' Flying Cloud
Park City , Utah
Indeed it is. Time to read up on treatment/abatement methods to slow the spread. Lot's of info out there.
pcskier is offline   Reply With Quote
Old 07-17-2019, 11:46 AM   #3
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Yep. Corrosion X is your new best friend.
http://www.corrosionx.com/
Dept of “OverKill”
Old 07-17-2019, 11:50 AM   #4
pcskier's Avatar
Park City , Utah
Ronnie, just curious, do you use CorrosionX as a proactive preventative? On my 19, I would apply it with a Q-tip around each and every rivet, and wipe it on all the cut panel seams. Then let it sit a day or two, then wipe again before waxing. Also wiped on my tail light castings, etc.
Haven't bothered with all that on the 23, just keep waxed twice a year. Wonder if I should.
Old 07-17-2019, 12:02 PM   #5
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
At the beginning I treated all cut edges.
That has morphed into treating only the symptoms as they occur. Filiform only happens on an area where the clear has been compromised.
I have not had ANY substantial new out breaks.
Just re-doing previous areas as needed.
The clear-coat pealing has been a more prevalent recent happening.
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 07-17-2019, 12:11 PM   #6
2010 25' FB Flying Cloud
Davenport , Iowa
I'm looking at the "dropper bottle" method of application, is this the form of application recommended?
Airtandem is offline   Reply With Quote
Old 07-17-2019, 01:44 PM   #7
twobikes's Avatar
1997 25' Safari
Montgomery , Alabama
Bob,
All of us with 1997 vintage “ male pattern baldness “ anxiously await your take on this clear-coat peeling. Your solutions always work. Thanks in advance.
Al
PAT & AL MEYER
TAC AL-26 WBCCI 2626
Montgomery, Alabama
follow the Two Bikes and an Airstream blog at http://airgo.blogspot.com
twobikes is online now   Reply With Quote
Old 07-17-2019, 03:25 PM   #8
If the clear is completely gone the best thing is to clean and smooth the surface and re-coat with a quality rattle can clear. Don't over do it, it will always be there, just cover to keep it from spreading. 👍
This is under the awning...
ID:	346939   Click image for larger version
W. H. Auden
Amanamus
"Tahawus"
Old 07-18-2019, 12:57 PM   #9
2007 31' Classic
I watched a video where Vinnie used a bone tool to a scrape the corrosion before applying corrosion X. Is this the accepted treatment. Will new clear coat adhere to a corrosion x treated surface?
Old 07-18-2019, 04:56 PM   #10
Secondary application of clear needs a clean surface.
The X product prevents the filiform from spreading, apply it after the clear is applied.
W. H. Auden
Amanamus
"Tahawus"
Old 07-18-2019, 07:28 PM   #11
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
I just treat the rivets once a year with a q-tip.
Dept of “OverKill”
Old 07-19-2019, 06:59 AM   #12
2007 31' Classic
Thanks.
Should I use Corrosion X on brand new trailer to prevent corrosion ILOVESALLY General Repair Forum 31 06-25-2016 12:06 PM
Stainless steel corrosion Dave-O Stoves, Ovens & Microwaves 21 04-05-2014 06:30 PM
ACF-50 Corrosion Inhibitor - Anyone used it? Bob Thompson Clearcoat, Exterior Paint & Trim 3 07-09-2004 06:40 PM
interior wall corrosion? 60traveler Interior Restoration Forum 12 08-11-2003 12:42 PM
corrosion under lites Chas Ribs, Skins & Rivets 4 05-18-2003 08:57 AM
