07-17-2019, 11:40 AM
2007 31' Classic
Gulf Breeze
Corrosion
Does this look like Filaform corrosion?
07-17-2019, 11:45 AM
The Aluminum Tent 3
2014 23' Flying Cloud
Park City
, Utah
Indeed it is. Time to read up on treatment/abatement methods to slow the spread. Lot's of info out there.
07-17-2019, 11:46 AM
Overkill Specialist
2020 30’ Globetrotter
2014 23' International
Dadeville
, Alabama
Yep. Corrosion X is your new best friend.
http://www.corrosionx.com/
07-17-2019, 11:50 AM
The Aluminum Tent 3
Park City
, Utah
Originally Posted by GMFL
Ronnie, just curious, do you use CorrosionX as a proactive preventative? On my 19, I would apply it with a Q-tip around each and every rivet, and wipe it on all the cut panel seams. Then let it sit a day or two, then wipe again before waxing. Also wiped on my tail light castings, etc.
Haven't bothered with all that on the 23, just keep waxed twice a year. Wonder if I should.
07-17-2019, 12:02 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
At the beginning I treated all cut edges.
That has morphed into treating only the symptoms as they occur. Filiform only happens on an area where the clear has been compromised.
I have not had ANY substantial new out breaks.
Just re-doing previous areas as needed.
The clear-coat pealing has been a more prevalent recent happening.
07-17-2019, 12:11 PM
2010 25' FB Flying Cloud
Davenport
, Iowa
I'm looking at the "dropper bottle" method of application, is this the form of application recommended?
07-17-2019, 01:44 PM
1997 25' Safari
Montgomery
, Alabama
Bob,
All of us with 1997 vintage “ male pattern baldness “ anxiously await your take on this clear-coat peeling. Your solutions always work. Thanks in advance.
Al
PAT & AL MEYER
TAC AL-26 WBCCI 2626
Montgomery, Alabama
follow the Two Bikes and an Airstream blog at https://airgo.blogspot.com
07-17-2019, 03:25 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
If the clear is completely gone the best thing is to clean and smooth the surface and re-coat with a quality rattle can clear. Don't over do it, it will always be there, just cover to keep it from spreading. 👍
This is under the awning...
07-18-2019, 12:57 PM
2007 31' Classic
Gulf Breeze
I watched a video where Vinnie used a bone tool to a scrape the corrosion before applying corrosion X. Is this the accepted treatment. Will new clear coat adhere to a corrosion x treated surface?
07-18-2019, 04:56 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Secondary application of clear needs a clean surface.
The X product prevents the filiform from spreading, apply it after the clear is applied.
07-18-2019, 07:28 PM
Overkill Specialist
Dadeville
, Alabama
I just treat the rivets once a year with a q-tip.
07-19-2019, 06:59 AM
2007 31' Classic
Gulf Breeze
[emoji631]
Thanks.
