06-20-2015, 05:00 AM
2008 25' Classic
Full Time
Classic Dinette Table Warping
My table is warping. Lookin at the edge eye level from the kitchen the ends are lower. Can the warped be removed by placing it in the down position and putting some wight while in storage between trips or do I need to take the table to a professional?
Kelvin
06-20-2015, 06:32 AM
2007 27' Classic FB
Fredericksburg
You could try placing it on a flat surface with a weight in the middle. It might take some of the curvature out of it but probably not all. After you have done that then you will have to seal the bottom side of the table which I don't think has finish on it. The wood is absorbing moisture and the grain is moving in the direction of its natural curvature. If none of this works, it will have to be planed or sanded to flatten the surface.
It is just one of those natural occurrences if you have it stored in a location subject to high humidity.
The Tex-i-can is Ready to Camp
06-20-2015, 07:29 AM
2011 30' Classic
2007 25' International CCD
1993 32' Excella
Largo
Working with wood all the time, that is one of the characteristics of wood. Check to see if the bottom of your table is sealed as well as the top. Once sealed properly the amount of warpage should be minimal. Don't ask me how I know.
>>ron<<
2015 GMC Denali 2500, 4x4, Duramax diesel, Topper, Pro Pride 3 P, Sendel 16" with Michelin LTs, one Yellow Labrador Retriever (AS security)
06-20-2015, 08:04 AM
2012 25' Flying Cloud
Battle Lake
If the solid wood table is sitting with sun exposure to the top, it can dry out and shrink that surface more than the bottom and cause warping. Once warped, it doesn't like to return to its original shape.
Doug and Cheryl
06-20-2015, 10:35 AM
2013 30' Classic
Greenwood
, Mississippi
Time, heat, humidity, and gravity are taking their toll on a laminated wood product. Is it possible to turn it over? The tables aren't really "solid" wood as in one piece- they are several pieces of wood bonded together with an adhesive. The furniture in a Classic is "solid" in the sense that it is not particle board. It is as it was on the tree, just many smaller pieces joined together to make a larger piece.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
06-22-2015, 09:54 AM
2008 25' Classic
Full Time
Thanks. Moved from Texas to Missouri in early 2014. Guess the humidity has affected it. Not sure if the bottom is sealed. I will go back to storage and put the table down and put some weight on the table while in storage. If the warp straightens out then I'll seal the bottom. I need to refinish the top as there are some cloudy spots on it and something has eaten through. Maybe better off taking it to a professional.
Kelvin
06-22-2015, 10:34 AM
Battle Lake
I could sell you a plywood table laminated with formica that won't warp or stain if you were closer to us. We removed it from our Flying Cloud for a recliner conversion and no longer use it. You could probably get something more durable made at any cabinet shop if unable to fix the original.
Doug and Cheryl
06-22-2015, 11:21 AM
2008 25' Classic
Full Time
Thanks, but my wife loves the hickory finish. We will have to be more careful in the furniture using the table. Probably need to use bigger or more place mats.
Missouri has been rough on my Airstream, warped the table and has buckled my vinyl floor in places.
Kelvin
06-25-2015, 04:02 PM
Link’s Travels
2002 25' Safari
1999 35' XL 350 w/slide
LINCOLN
, Nebraska
We have a Safari 25' 2006 yr. Both doors on the clothes closets have warpped; one so bad you can hardly use it. Sat unused for 8 yrs!!! Not good!!!
12-20-2017, 07:54 PM
2009 25' FB Classic
Scottsdale
We live in Phoenix AZ and the table in our 2009 Classic started to warp. So now I take it out and put it in the spare bedroom in our house out of the heat and dry heat of the sun. It does get up to 120 here with about 6% humidity. I also put three five gal bucket of water in the trailer winter and summer to help all that Hickory wood.
Bob & Julie # 5587, 4CU in AZ
