Old 01-21-2015, 11:01 AM   #1
carver 1's Avatar
2011 30' Classic
2007 25' International CCD
1993 32' Excella
Largo , Florida
Images: 30
Brake controller on Classic 07
I'm moving up to an 07 31' Classic with disc brakes and electric hydraulic brakes. Can i use the same brake controller that I have used in my 07 25' Int'l that did not have hydraulics?
>>ron<<
2015 GMC Denali 2500, 4x4, Duramax diesel, Topper, Pro Pride 3 P, Sendel 16" with Michelin LTs, one Yellow Labrador Retriever (AS security)
carver 1 is offline   Reply With Quote
Old 01-21-2015, 11:36 AM   #2
boondockdad's Avatar
2008 30' Classic S/O
Dearborn , Michigan
Images: 21
You'd need to check whether it has a electric/hydraulic setting.
I use the Tekonsha P3 for my Classic. Pairs very nicely with the Dexter 1600 actuator. Something this model has, that I've not seen on others, is the "Boost" setting. This provides 4 different levels of 'aggression' for the trailer brakes... basically works to have the trailer brakes 'lead' the TV braking. Kind of a 'precognition', if you will.
Don't know if there's a resource that shows all the brake controllers out there, and their specifications....
but, I can tell you: the E-350 Integrated Brake Controller does NOT have E/H function, while the F series IBC's do. Go figure.
A family of eight, blogging all things camping from our Airstream
https://boondockdad.com/
boondockdad is offline   Reply With Quote
Old 01-21-2015, 12:04 PM   #3
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
I agree with Boondockdad. I have had the Tekonsha P3 for 2-3 years and it is awesome. Its easy to install and easy to use.
NavyCorpsman is offline   Reply With Quote
Old 01-30-2015, 10:48 AM   #4
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Make sure the hydraulic brake recalls have been performed; brake lines and actuator check it its the Actibrake controller. I had the dealer selling my 2008 Classic 25fb perform the recalls. I negotiated the replacement of the Actibrake with a Dexter 1600.
I use a Tekonsha P2. It has a setting from hydraulic brakes.
Kelvin
KJRitchie is online now   Reply With Quote
What Brake Controller Are You Using On Hydraulic Brake Classics? KJRitchie 2006 - 2010 Classic (all lengths) 30 09-25-2014 12:03 PM
Brake lights, brake controller not functioning adwriter73 Brakes & Brake Controllers 17 01-16-2014 09:37 AM
E53 w/ Tekonsha brake controller lights 3rd brake light when manual lever applied warmrain Brakes & Brake Controllers 10 11-14-2013 09:35 AM
Brake controller or trailer brake problem? (newbie alert) jornvango Brakes & Brake Controllers 2 11-01-2012 02:17 PM
New F150 '09 brake controller vs. Prodigy brake controller dukester Brakes & Brake Controllers 17 01-20-2009 10:46 PM
