Old 09-22-2019, 08:26 AM   #1
2007 31' Classic
Gulf Breeze , Florida
Blue Ox Sway Pro
I like my Blue Ox but I may have the wrong drop shank because my trailer rides a bit nose up and I have not been able to correct this with the seven hole shank turned upside down. Are there other owners using the Blue Ox who use either the nine hole or eleven hole shank.
2016 Ram 2500 TBD with air suspension
2007 Classic 31
Tongue weight is 1075
Using 1500 pound bars
Receiver height 21.5 inches
trumpetguy is offline   Reply With Quote
Old 09-22-2019, 08:37 AM   #2
AirMiles's Avatar
2018 27' Globetrotter
Apollo Beach , Florida
Yes. I have all three 7, 9, 11 hole. The nine hole works for the new F250 4x4 which is fairly tall - almost lifted. The 11 hole would work for lifted trucks. I cut my 11 hole to a ten hole. Now it’s the same length as the nine hole but has one extra hole. I am using a Propride now but still have my Blue Ox. I like the simplicity of the Blue Ox. It works well, just not as good as the Propride on my new F250.
2018 Globetrotter 27Q, 29 nights 4,435 miles, 600W Solar, PD4655L, Duracell EGC2 Batteries, ProPride, 16" Michelin's, Champion 3400W Dual-Fuel, 2019 F250
Sold: 2017 Flying Cloud 25FB, 316 nights 40,150 miles, 400W Solar
Sold: 2013 Casita SD17 89 nights 16,200 miles
AirMiles is offline   Reply With Quote
Old 09-22-2019, 08:39 AM   #3
2007 31' Classic
Thanks. So you think the 11 hole would solve my problem?
Old 09-22-2019, 08:44 AM   #4
AirMiles's Avatar
Yes, you can buy an 11 hole and easily cut it down to the same length as a 9 hole if it’s too long. Your Dodge is tall. The 11 hole should work.
Old 09-22-2019, 09:41 AM   #5
FloydCoVa's Avatar
2015 23' Flying Cloud
Copper Hill , Virginia
Have you considered a lift kit for the airstreams?
FloydCoVa is offline   Reply With Quote
Old 09-22-2019, 10:23 AM   #6
2014 25' Flying Cloud
Temple , Texas
I bought the nine hole for my new Ram 2500, the seven hole resulted in our AS being about 3 inches too high in front. I have not hooked it up yet but I expect it to be right on level based on my initial measurements of the new ball height.
2014 Flying Cloud 25FB
2018 Ram 2500; Diesel
Blue Ox WDH
RamRider is offline   Reply With Quote
Old 09-22-2019, 10:29 AM   #7
2019 27' International
Western , North Carolina
9 was too short for our F350 went to an 11.
2019 International Serenity 27 FBQ ďSerenityĒ
2019 Ford F-350 Platinum
JonDNC is offline   Reply With Quote
Old 09-22-2019, 11:25 AM   #8
FloydCoVa's Avatar
A lift will give you extra 3 inches of clearance, just sayin.
Old 09-22-2019, 12:28 PM   #9
Farrgramm's Avatar
2020 30' Flying Cloud
2020 FC 30 Bunk , Georgia
I have almost the same truck, 2015 also with rear air. Don’t forget that you can lower the truck an inch or two using the Alt Trailer height switch. I usually do that. I use a 9 hole drop and am level pulling a 30 Bunk.
Farrgramm is offline   Reply With Quote
Old 09-22-2019, 12:34 PM   #10
2015 30' Flying Cloud
2016 30' Classic
Covington , Louisiana
Originally Posted by Farrgramm View Post
I have almost the same truck, 2015 also with rear air. Donít forget that you can lower the truck an inch or two using the Alt Trailer height switch. I usually do that. I use a 9 hole drop and am level pulling a 30 Bunk.
I have a 2015 F250 diesel. Iím not aware of the trailer height switch. How do I access the switch?
Sjcjr is offline   Reply With Quote
Old 09-22-2019, 12:48 PM   #11
2007 31' Classic
Thanks for the reply. I do use the Trailer Height toggle but it is still too tall for the AS.
Looks like I will be buying the 11 hole shank. At $150 <> itís a reasonable solution.
Old 09-22-2019, 12:50 PM   #12
2007 31' Classic
I have thought about doing the lift. That will help with those diesel stations having a steep drop.
Do you know which kit works on our trailers.
Old 09-22-2019, 01:07 PM   #13
jeffmc306's Avatar
2019 27' Globetrotter
McHenry , Illinois
Using a Curt Drop Shank from eTrailer
2007 Classic 31
Trumpetguy, I moved from a Ram 1500 to 2500 and ended up with a Curt 2.5Ē receiver, 12Ē rise, 8Ē drop drop shank and it works great with our Blue Ox Sway Pro.
Hope this helps!
Jeff
ID:	352740   Click image for larger version
2019 27í Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB (traded)
2019 Ram 2500 Laramie Blue Ox 1500#
WBCCI# 10258
2020 Retirement Plan
jeffmc306 is offline   Reply With Quote
Old 09-22-2019, 01:51 PM   #14
2007 31' Classic
Man...thatís not much ground clearance.
Old 09-22-2019, 01:53 PM   #15
2007 31' Classic
I donít know about the Ford. Ram has a dash button labeled Alt. Trailer Height.
Old 09-22-2019, 02:25 PM   #16
2007 31' Classic
Blue Ox offers two drawbar options...9 inch or 12 inch long. It would seem the 12 inch would help with jackknifing. Any thoughts from the forum members?
Old 09-22-2019, 05:22 PM   #17
2015 25' FB Flying Cloud
Texarkana , Texas
I have the 7-hole shank for my 2014 Ram 1500 4x4 pulling 2015 FC25FBT with 1,500 bars ... set up in Pender, NE by Blue Ox. Maybe Chad Luber @ Blue Ox can provide some input ... 402-385-2851. Good luck!
lrcunning is offline   Reply With Quote
Old 09-22-2019, 05:32 PM   #18
jeffmc306's Avatar
McHenry , Illinois
I was waiting to trim the last 1.5Ē off the shank but didnít have any trouble on a 2400 mile trip to Rocky Mountain National Park. *The jack foot was down for the photo - itís normally way above the shank. The 2500 sits 3Ē higher than the 1500 it replaced.
WBCCI# 10258
Old 09-22-2019, 07:36 PM   #19
2018 27' Flying Cloud
Delray Beach , Florida
I can’t honestly tell you about your Blue Ox, but I can tell you that ProPride is absolutely amazing. I personally teach customer service for a living, and Sean and his team are the “Gold Standard “ when it comes to support (before, during and after the sale). These guys are awesome.
time2travel is offline   Reply With Quote
Old 09-22-2019, 08:02 PM   #20
2007 31' Classic
Thanks for that input.
Blue Ox Sway Pro AWCHIEF Hitches, Couplers & Balls 172 06-26-2019 11:24 PM
Blue ox sway pro Sjcjr Hitches, Couplers & Balls 31 08-02-2017 03:11 PM
Blue Ox Sway Pro W/D System Ganglin Towing, Tow Vehicles & Hitches 46 01-07-2017 09:17 PM
Equal-i-zer Sway Control Hitch vs Blue Ox Sway Pro airstreampek Hitches, Couplers & Balls 31 06-18-2014 11:56 PM
