Old 10-30-2012, 06:47 PM   #43
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
Originally Posted by fltlevel510 View Post
I replaced my hinges with folding shelf brackets from Rockler Woodworking.
Here is the link to the hinge. Unfortunately the price has doubled since I purchased mine several years ago.
Folding Shelf Brackets | Rockler Woodworking Tools
Thanks for the post. I'm thinking 750 Lbs capacity ought to be enough to take the shock of the highway potholes.
Here are the same ones at a few pennies less.
Heavy Duty Folding Shelf Bracket
Ken
Old 10-30-2012, 07:28 PM   #44
dznf0g's Avatar
Oswego , Illinois
Well, I guess AS isn't too far out on price, based on the prior posts.
-Rich-
Old 10-30-2012, 07:44 PM   #45
Ag&Au's Avatar
Here is a pair that I am considering. They cost even more although shipping is free. Stainless steel sounds like a good idea.
Stainless Steel Folding Shelf or Bench Brackets Pair | eBay
Ken
Old 10-31-2012, 04:01 AM   #46
hang up and drive
kry226's Avatar
2010 30' Classic
:) , Germany
Think I am going to try the Airstream ones first. But again, my trailer still being under warranty plays a big part in that. Good finds though. May need them yet.
2004 Dodge Ram 2500 5.9L Cummins 4WD (SOLD)
2010 Classic 30
ProPride P3-1400
kry226 is offline   Reply With Quote
Old 10-31-2012, 09:46 AM   #47
dznf0g's Avatar
Oswego , Illinois
OK, had to run out to the storage lot. I always forget something when putting her away for the winter. Anyway, got some photos of the old setup with some dimensions. Will have to wait till new brackets get here to verify, but I think, if you don't use an additional block, like the Colonial RV photos in the upthread post, the new brackets will be very visible when the extension is down. IIRC, that is the setup in my brother-in-law's 2012 Classic. Anyway use these in the meantime.
-Rich-
Old 10-31-2012, 10:30 AM   #48
Ag&Au's Avatar
Thanks for the posting the pictures. It certainly seems like something needs to be added to the strips of wood on the cabinet side to make up for the lack of the Horizontal extension piece on the top of the old brackets(where the breaks occur).
I think I'm going to let you figure this out before I order anything.
Ken
Old 02-13-2013, 08:59 AM   #49
hang up and drive
kry226's Avatar
2010 30' Classic
:) , Germany
Headed to Colonial for an appointment on Monday. I'll post the results regarding how they choose to fix the counter extension. More to follow.
2010 Classic 30
ProPride P3-1400
Old 02-13-2013, 12:51 PM   #50
2010 27' FB Classic
N/A , Texas
I just found this thread, and had the same problem with metal fatigue breaks/cracks on the OEM brackets while I was in NM a couple of months ago.
I fixed the problem by buying the same bracket AS used in 2010 at Camping World. I think I paid about $7.00 for 2 brackets.
What I noticed is that I had to make new holes where the brackets attached to both the shelf and cabinet even though the holes in the metal brackets matched up perfectly.
Here is what I believe happened at the plant when they install the shelves:
It's installed as "close enough" then when the shelf does not line up correctly, it is pushed and pulled and brackets are bent to make it fit and causes the metal brackets to flex into shape eventually crack where it was bent.
Of course I took my time and installed it correctly with no fudging and bending of the brackets. Drilled all new holes and used correct sized screws.
Although, I don't know it this will make a difference while still using the OEM style brackets. The only way to prove my point is to travel and use the shelf as before for a couple of years and see if the same thing happens again.
Stay tuned, I'll let you know in 2015.
Old 02-13-2013, 01:01 PM   #51
Ag&Au's Avatar
Of course took my time and installed it correctly with no fudging and bending of the brackets. Drilled all new holes and used correct sized screws.
My trailer is a 2010, and one of my brackets broke on a very bumpy highway. I would be interested in a picture of the ones you bought, if available.
Ken
Old 02-13-2013, 01:08 PM   #52
2010 27' FB Classic
N/A , Texas
Ken
Sure thing. I bought 2 sets at the same time so I probably have a package to show. I can't get to my stuff till the weekend and I'll look for them.
They look just like the ones displayed in post 47.
Old 02-13-2013, 01:16 PM   #53
Ag&Au's Avatar
Don't bother. Those are what I have. My first approach has been to replace the old with ones of the same type. That will keep me going until I have to drive thought western Arizona on I-40 again. I wish they would get some of those illegal immigrants they are always complaining about to fix that road.
Ken
Old 02-13-2013, 09:26 PM   #54
2010 27' FB Classic
N/A , Texas
Ken
Sounds like we both took the same approach.
Old 02-20-2013, 09:15 AM   #55
hang up and drive
kry226's Avatar
2010 30' Classic
:) , Germany
UPDATE:
Very successful trip to Colonial. I will tell you that the standard party line from Airstream (not Colonial) is that they replace the broken brackets with the same... no part numbers have changed. However, being the adamant person I am, and the reasonable service folks Colonial employ, I talked and they listened. We opened a couple of new trailers and saw the new brackets and they went to work researching the upgrade. Come to find out, these new brackets offer an 88 pound support rating (not sure how that's measured though), and Airstream would warranty my broken brackets with the updated ones.
The only problem is that they weren't in stock AND they also require extra wood. Thus, no pics of the fix yet. We're probably going to have them do a little body work to the trailer soon (thank you Mr. 4 Point Buck) and will have them do the bracket install then as well.
It may be a few weeks, but I will post pics of the fix. Also to their credit, Colonial did replace my broken brackets with some of the same until this upgraded fix can be applied.
All in all, great visit, but more to follow.
2010 Classic 30
ProPride P3-1400
Old 03-02-2013, 04:03 PM   #56
2010 30' Classic
Tyler , Texas
For those of you who have had their counter top extension hinge break, I finally fixed my problem after the second one broke. I took it down to my local welding shop and had them re-enforce it by welding supports in the 90 degree corners of the hinge where it broke both times. Problem solved.
patrick p is offline   Reply With Quote
2010 classic
Maximum extension length for shore power? barrettjl Electrical - Systems, Generators, Batteries & Solar 32 05-14-2016 08:14 PM
Old Cracked and Brittle Counter top trim palmtreegirl Cabinets, Counter Tops & Furnishings 4 09-12-2011 01:25 PM
What is this bracket? jkelley73 Awnings 2 08-28-2011 11:20 AM
Relocate awning bracket jkelley73 Awnings 0 08-28-2011 08:26 AM
Counter buck Cabinets, Counter Tops & Furnishings 1 07-31-2011 09:37 PM
