Old 10-18-2012, 09:16 AM   #29
Colonial Airstream NJ
Colonial Airstream's Avatar
1968 17' Caravel
Lakewood , New Jersey
Images: 79
Airstream recently changed the flip up bracket to a style we have used in the Airstream Interstate for some time. Airstream used this bracket in the Interstate since it cut down on noise inside the coach. I believe this bracket setup can be retrofitted to your current flip up countertop.
-Lauren Botticelli
Patrick Botticelli - Colonial Airstream 1121 Route 88 Lakewood, NJ 08701 - 1-800-265-9019 www.colonialairstream.com
Colonial Airstream is offline   Reply With Quote
Old 10-18-2012, 12:01 PM   #30
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
-Lauren Botticelli
Thanks for the information. I will definitely research that. Changing to the new style makes more sense that repeatedly replacing the old one.
Ken
Old 10-18-2012, 01:16 PM   #31
dznf0g's Avatar
Oswego , Illinois
Anybody know the dimension of that extra block?
The other thing I noticed about my bro-in-laws 2012 Classic was that the underside of the extension was dressed out in the same gray material that is on the storage compartments. Mine is bare wood. Nice little touch. Now every time I walk into mine, I see that bare wood!!!!
Oh, well, just another little project on the list.
-Rich-
Old 10-18-2012, 02:37 PM   #32
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
The DW was complaining that the counter extension was getting hard to latch in the up position and harder to unlatch for storage. On inspection I noticed on one of the brackets that the section near the hinge end was bent down a bit and pushing upwards on the extension while in the stored position returned it to a right angle and it worked properly once again. I had assumed someone had inadvertently push down on the extension in the stored position.
I then came across this thread and realized the bend was in the same place as the photo showing the broken bracket. I'm now wondering if as others suggested here, the combination of the weight of the Corian extension and the bouncing the trailer is sometimes subject to going down the road is the cause for the bending and bracket failure over time. I would be very interested to hear if the brackets reportedly used on the Interstate and maybe the current production trailers will be the solution for this.
AIR 47751
Air Safe Hitch, Reese Dual Cam 800#, Centramatics
Silver Goose is offline   Reply With Quote
Old 10-30-2012, 02:19 PM   #33
dznf0g's Avatar
Oswego , Illinois
I just ordered the updated brackets from Bill Thomas. Glenn gave me the dimensions of the wood in the newer units as 1/2" X 11" X 2 1/2". My AS is back in storage, does anyone have the dimensions of the older block?
-Rich-
Old 10-30-2012, 02:35 PM   #34
Ag&Au's Avatar
I don't have my trailer here either. However the picture I saw looked like the new wood piece attached on top of the original wood. That would make the 1/2 inch thickness make more sense also. However this is all from a outdated used memory. Who's Bill Thomas and Glenn? What was the price?
Ken
Old 10-30-2012, 03:01 PM   #35
hang up and drive
kry226's Avatar
2010 30' Classic
:) , Germany
Ken
Mine is in storage as well, but we will be headed out on our final trip of the year this coming weekend. I will try to get measurements then and post them. If I remember correctly, the original wood was routed to have a decorative trim. Also, don't forget about the wood affixed to the underside of the corian too.
Bill Thomas is Bill Thomas Camper Sales just outside St. Louis, a pretty reputable AS dealer.
2004 Dodge Ram 2500 5.9L Cummins 4WD (SOLD)
2010 Classic 30
ProPride P3-1400
kry226 is offline   Reply With Quote
Old 10-30-2012, 04:18 PM   #36
dznf0g's Avatar
Oswego , Illinois
These are the photos Glenn Thomas of Bill Thomas Camper Sales sent me. It only shows one thickness of wood....which I think is the same as mine, but I'm not sure.
I wonder if the Corian countertop overhang is less on the new units. Anybody have their older classic at home that could go measure and photo?
-Rich-
Old 10-30-2012, 04:26 PM   #37
hang up and drive
kry226's Avatar
2010 30' Classic
:) , Germany
Unknown about the overhang (I'll check this weekend, but I bet it's the same as above), but I do know that this wood is exactly what mine looks like. It appears that I could just get the brackets, install, and call it good.
Thanks for the pics!
2010 Classic 30
ProPride P3-1400
Old 10-30-2012, 04:30 PM   #38
dznf0g's Avatar
Oswego , Illinois
Hmmm, the pic in post #25 shows a double block and a different bracket extension than my post #36. I think it would work either way, If I am visualizing it right. In post #36, when folded down, the top edge of the extension would be lower than the level of the counter top. In post #25, I thin the edge would be at the same height as the counter top. Am I seeing that correctly?
Oh, Ken, the price is HIGH! for a couple of brackets..$59 plus shipping to my door direct from AS. (That is, Glenn Thomas, AS dealer, orders and has them drop shipped to my house, form AS mothership.)
-Rich-
Old 10-30-2012, 04:33 PM   #39
Ag&Au's Avatar
I am sure the hinge is some standard piece of cabinet hardware. Maybe yours will have some labelling. I have nothing against ordering from a dealer except I'm sure they'd have to order them and that's just one more place it can get screwed up.
Ken
Old 10-30-2012, 05:10 PM   #40
hang up and drive
kry226's Avatar
2010 30' Classic
:) , Germany
You know, the more I look at it, the more I think it will not matter. As long as you get far enough away from the wall so that the hinge will work properly, that's all you need. Anything beyond that, you just take up the "slack" on the counter extension itself. Much easier to show it than write about it.
2010 Classic 30
ProPride P3-1400
Old 10-30-2012, 05:36 PM   #41
fltlevel510's Avatar
2004 30' Classic Slideout
Between Here , And There
Folding Shelf Brackets
I replaced my hinges with folding shelf brackets from Rockler Woodworking.
Here is the link to the hinge. Unfortunately the price has doubled since I purchased mine several years ago.
Folding Shelf Brackets | Rockler Woodworking Tools
fltlevel510 is offline   Reply With Quote
Old 10-30-2012, 06:44 PM   #42
Ag&Au's Avatar
Good Point.
Ken
2010 classic
Maximum extension length for shore power? barrettjl Electrical - Systems, Generators, Batteries & Solar 32 05-14-2016 08:14 PM
Old Cracked and Brittle Counter top trim palmtreegirl Cabinets, Counter Tops & Furnishings 4 09-12-2011 01:25 PM
What is this bracket? jkelley73 Awnings 2 08-28-2011 11:20 AM
Relocate awning bracket jkelley73 Awnings 0 08-28-2011 08:26 AM
Counter buck Cabinets, Counter Tops & Furnishings 1 07-31-2011 09:37 PM
