Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Overlander > 1965 - 1969 Overlander
Old 09-09-2015, 12:25 PM   #21
goransons's Avatar
1963 22' Safari
2020 27' Globetrotter
State of , Washington
Send a message via MSN to goransons
Here's a partial update. I found a local rv shop that let me look in some boxes and found that a Valterra trailer deadbolt has the same stud locations and same size actuator. I was able to reuse the deadbolt mechanism as is with the lock cylinder from the new lock. Still trying to salvage the door knob. That's going to be another mess but at least it's secure now.
Name:	ImageUploadedByAirstream Forums1441823041.909937.jpg
Name:	ImageUploadedByAirstream Forums1441823059.484556.jpg
Name:	ImageUploadedByAirstream Forums1441823080.361205.jpg
They have another in stock and I'm going to pick it up and convert the 63 thumb latch travel lock to a deadbolt I think.
Scott & Megan
VAC LIBRARIAN WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 11-02-2015, 06:50 PM   #22
goransons's Avatar
1963 22' Safari
Back to work again. Colder weather is coming so started getting serious about weatherproofing. New stove vent painted and installed and the first sewer vent cleaned and resealed. Tomorrow I hope to do the same on the fridge vent and the other two sewer vents. Also finished shrinking down an access door to fit the opening I have. Then we can finally start cleaning out the mess! Click image for larger version
Name:	ImageUploadedByAirstream Forums1446515413.362186.jpg
ID:	251569Click image for larger version
Name:	ImageUploadedByAirstream Forums1446515439.791283.jpg
Scott & Megan
Old 11-03-2015, 10:27 PM   #23
goransons's Avatar
1963 22' Safari
Well I miss that extra hour of daylight in the evening after work for sure. I did manage to take apart, trim down and rebuild a compartment door and get it installed. Still need the short section of rub rail behind the wheels but the big hole is finally closed up. Hope to get the other project knocked out tomorrow. Click image for larger version
Name:	ImageUploadedByAirstream Forums1446614840.506353.jpg
Scott & Megan
Old 11-06-2015, 03:09 PM   #24
goransons's Avatar
1963 22' Safari
We're BAAAAACK!! new project - '65 Overlander
Three hours of scrubbing and vacuuming up broken glass and who knows what it's feeling less repulsive inside. Solid floor everywhere so far, even against the walls behind stuff (even the rear compartment). Even has a perfect original folding shower curtain! Need to find two drawer face donors for the Goucho and door above the oven but otherwise only minor cabinet repairs needed. Going to be on the lookout for some table leaves too
Name:	ImageUploadedByAirstream Forums1446847582.595966.jpg
ID:	251718Click image for larger version
Name:	ImageUploadedByAirstream Forums1446847595.434630.jpg
ID:	251719Click image for larger version
Name:	ImageUploadedByAirstream Forums1446847607.957468.jpg
ID:	251720Click image for larger version
Name:	ImageUploadedByAirstream Forums1446847620.430467.jpg
ID:	251721Click image for larger version
Name:	ImageUploadedByAirstream Forums1446847633.753623.jpg
ID:	251722Click image for larger version
Name:	ImageUploadedByAirstream Forums1446847645.461923.jpg
ID:	251723Click image for larger version
Name:	ImageUploadedByAirstream Forums1446847659.582146.jpg
ID:	251724Click image for larger version
Name:	ImageUploadedByAirstream Forums1446847670.803250.jpg
ID:	251725Click image for larger version
Name:	ImageUploadedByAirstream Forums1446847684.195290.jpg
Scott & Megan
A New Challenge-1963 Overlander rehab project overlander63 1960 - 1964 Overlander 896 04-07-2017 04:48 PM
New Restoration Project, '72 Overlander surferstyler 1970 - 1973 Overlander 160 08-29-2013 06:28 PM
my new project - '60 Overlander garthbf 1960 - 1964 Overlander 11 07-18-2012 06:40 PM
My New 1962 Overlander Project BarryIowa 1960 - 1964 Overlander 226 06-25-2009 06:30 PM
I'm baaaaack! KY Girl Our Community 5 05-01-2005 08:19 PM
