Old 07-12-2010, 03:16 PM   #1
San Jose , United States
Touareg-will it not be enough power to tow?
Hello Everyone
We are strongly considering buying a 1969 Overlander International.
I am worried that our touareg might not be able to handle the weight.
The touareg (V8) can handle 7700 lbs and the Overlanders total weight is 4525 lbs, but once you get your stuff in there it will be much more (maybe 5500).
Should there be more of a reserve of extra weight it can handle?
I really want to get this, but am worried we are cutting it close.
jb1974 is offline   Reply With Quote
Old 07-12-2010, 03:42 PM   #2
JFScheck's Avatar
Rockville , Maryland
Images: 33
With my personal experience I would say you are fine - but I would invest in either a Hensley or ProPride Hitch - and I'm assuming your Overlander won't be longer than 25 - 27 feet.
I tow a 25 footer and with the ProPride I have ZERO issues all through the mountains, deserts, past big rigs and cross winds, etc.
If you can - do a search on "Touareg" on this forum and you will be brought up to speed to include instructions on how to build your brake controller harness.
BTW - Welcome!!!
John "JFScheck" Scheck
In Between Units
Airstream On Order
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 07-12-2010, 03:50 PM   #3
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
You should be fine. I agree with JF, with the shorter wheelbase of the Toureg I'd make sure I bought a good WD/AS hitch.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 07-12-2010, 04:04 PM   #4
Road Ruler's Avatar
Images: 38
You will have a problem..........................................
.............keeping it under 100kph
Old 07-12-2010, 05:06 PM   #5
1978 31' Excella 500
Goose Creek , South Carolina
It should be fine
Holzarbeiter is offline   Reply With Quote
Old 07-12-2010, 06:30 PM   #6
olddog299's Avatar
1990 25' Excella
Glenburn , Maine
The V-8 is fine for what you propose. Our 2004 V-6 is slightly under-powered for our 25' Excella when fully loaded, but only just. I wouldn't hesitate to take it along the coast -- it's stopping while coming into West Virginia in Huntsville that scares the bejeesus out of me... :')
wil
AIR 22828
TAC ME-3
Universal Address: 97XX5 QGG5Z
Longitude: -68.814136
Latitude: 44.894663
olddog299 is offline   Reply With Quote
Old 07-13-2010, 04:40 PM   #7
Westfalia's Avatar
2008 27' International CCD FB
Boerne, TX / , Evergreen, CO
Images: 35
Send a message via AIM to Westfalia Send a message via Skype™ to Westfalia
My V8 has successfully pulled my 7000lb 27'FB with little problem at low altitude. I'm not sure how well It would do at real altitude or long mountain passes, but the V8 in the Touareg always ends up surprising me. Watch your tongue weight. Does your V8 have air suspension?
Chris and Christina- Boerne, TX / Evergreen, CO - TAC TX-7
2008 27'FB Int'l Signature CCD
Westfalia is offline   Reply With Quote
Old 07-14-2010, 11:12 AM   #8
Thank-you so much everyone for your input!!
Yes, we do have the air suspension.
I feel better knowing we should be okay We will most likely be replacing all the appliances and removing the oven, maybe this will lighten the load further and help a bit?
We are heading out to see the AS on Saturday and I am hoping that this is the one (we have seen 7 already this month and the hubby is getting tired of travelling for hours on end to end up with nothing LOL)
Old 07-14-2010, 11:26 AM   #9
Road Ruler's Avatar
Images: 38
A few hundred pounds here or there won't make a difference when towing a Stream.
We have towed our 3,500lb dry weight 23' dry and then with it travel ready at 4,500lbs. With the exception of feeling the weight slightly when accelerating up to speed it tows and feels the same.
Old 07-17-2010, 08:14 AM   #10
2019 22' Sport
High River , Alberta
No, you are not cutting it close at all. You have a great deal of reserve capacity here. Don't go lightening the trailer! Contact Andrew T via this forum if you have setup questions or issues. You may find it worth your while to drive to his store south of London (just over an hour away for you) to have his people to undertake your setup for you. They have done T-regs and Cayennes before.
FWIW, I tow a '75 Overlander with a Volvo sedan. I'd like more power, but it works and stability is a complete non-issue, using a conventional weight distributing hitch and friction sway controls.
AlbertF is offline   Reply With Quote
Old 07-17-2010, 09:03 AM   #11
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
We had a Touareg towing a smaller TT here a couple of weeks ago. A neat feature is the suspension, which allows one to lower the rear while pulling under the hitch. One of the more interesting points the owner brought up was that (according to him) Touareg doesn't want folks to use weight-distribution hitches. I guess it mucks with the automatic leveling system on the automobile side.
Lynn
WBCCI 21043
Old 07-17-2010, 10:07 AM   #12
arcamedies's Avatar
1993 30' Excella
Lakeland , Florida
Images: 69
By using the 80% ideal rule you can easily tow 6300 lbs. Even if you are at 85% you'll easily climb hills and be comfortable towing under all circumstances. Anytime you can add something to dampen sway you are safer regardless of length of the tow vehicle.
There is a video on youtube of a long wheelbase truck being flipped by the trailer it was towing in a severe crosswind gust. (whitebox trailer, square sides, no shocks)
Happy trailering
arcamedies is offline   Reply With Quote
Old 07-17-2010, 01:29 PM   #13
Well we bought it!!! We are so excited!! It is being delivered by the seller in 2 weeks as we need to get the Hensley, wiring harness etc which could take some time-the guy has family close by anyhow... It is in pretty good shape which is surprising for its age.
Hopefully we can take it out in a month for some camping
I did not know that place was there in London, very handy for us!
At least we feel better about our purchase after reading everyones replies, thanks!
Old 07-17-2010, 03:03 PM   #14
Road Ruler's Avatar
Images: 38
Great!.. Post some pics when you get it all hooked up.
Old 07-17-2010, 03:14 PM   #15
Westfalia's Avatar
Images: 35
JB, take a moment to familiarize yourself with and join Club Touareg, a sister forum to Airforums (same owner, AndyR). Towing questions will arise and the towing discussion is, naturally, more Touareg oriented and will have little tidbits like how to reprogram the vehicles computers for trailer stoplight problems, part numbers, etc. You will enjoy being a Touareg owner. I have been since late 2003!
Congrats on your purchase!
Old 01-22-2011, 02:57 PM   #16
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
What kind of mileage are you all getting with that V8? I would like to improve on the 12-13 I get towing with my V10 Ford.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 01-22-2011, 03:06 PM   #17
Westfalia's Avatar
Images: 35
It wont't be any better. I get 13-15 hwy with the V8 without towing. 11-12 towing, best.
Old 01-22-2011, 03:10 PM   #18
NicheVintage's Avatar
1965 26' Overlander
Scottsdale , Southwest
Images: 34
When we owned our 04 V8 Touareg we were getting 11.6 in city driving. 13-16 hwy. We never had the chance to tow with it so I cant say much about that mileage.
NicheVintage is offline   Reply With Quote
Old 01-22-2011, 03:23 PM   #19
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
thanks- reality is I guess 12 or so is as good as it gets ..at least it runs regular and is big as a small house inside
AIR #005
retired!
Old 01-22-2011, 05:10 PM   #20
1965 26' Overlander
Images: 34
We always ran Chevron 89 minimum and usually 91 octane because it would begin to ping with 87. Of course ours may have just been a temper mental Treg.
Another Touareg-er! 67caravel Tow Vehicles 216 04-04-2015 12:53 PM
Worn power cable to tow vehicle keanroger WBCCI Forum 11 08-26-2009 01:32 PM
Touareg V6 Dany Tow Vehicles 12 02-27-2009 10:50 AM
New home for the Touareg. Devoman Our Community 15 02-25-2006 12:51 PM
VW Touareg as tow vehicle davidp Tow Vehicles 13 08-27-2004 01:33 PM
