Old 10-07-2019, 07:24 PM   #61
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I'm not a fan of Olympic trifold style rivets except for patches or other non load bearing members. So if you don't have access to the back side of the skin where the patch is going because the interior skins are still in place, then Olympic rivets makes installing your patches easier. The head diameters are 5/32", same as the Airstream solid rivets.
Bucking solid rivets is a two person job and requires a air powered riveting tool on the outside and bucking bar held by a second person on the inside.
You have good advice above for sealing the patches so leaks are less of a concern.
Just a thought to make the job easier.
David
WBCCI #8607
VAC Region 11
Link to my 1975 Overlander Improvement Journal:
https://www.airforums.com/forums/f17...ml#post2053792
Old 10-08-2019, 09:46 AM   #62
1968 26' Overlander
Los Gatos , California
Thanks!
Thanks everyone!
I do have access to both sides of the skin and am planning to use buck rivets (as opposed to Olympic or pop). I guess I missed the memo on needing the powered rivet tool though Hopefully I can find someone in the area with one!
Summer
1968 Overlander
Stargirl is offline   Reply With Quote
Old 10-08-2019, 07:11 PM   #63
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Solid rivet pneumatic tools are readily available. Need an air compressor to run one. They make a lot of noise. Fun.
David
https://www.vintagetrailersupply.com...ting-s/206.htm
WBCCI #8607
VAC Region 11
1968, belly pan, belly pan removal, brake, brake lights, eternabond, full monte, furnace, gut, maxim, maxxair, mice, overlander, removal, renovation, restoration, roof, roof sealant, roof vent, sealant, sealant removal, sealing, subfloor, subfloor replacement, vent, window, wiring
Our '65 Overlander overhaul rivetmonster General Repair Forum 3 08-01-2013 10:37 AM
1971 Overlander overhaul - questions TennTex General Repair Forum 2 12-17-2012 06:55 PM
Winter Overhaul of 1968 GT undercarriage Randy Gates 1965 - 1969 Globetrotter 5 05-10-2011 08:10 PM
69' Overlander Overhaul martinb321 Member Introductions 5 08-09-2006 10:44 PM
'64 Overlander, Needs Complete Overhaul... Worth It??? bechand0128 Trailer Values 4 04-08-2006 09:56 PM
