Lurking for a while. Searched for a vintage AS in decent shape for past few months. I found this one close to me Monday. After talking to seller and seeing pics. I'm driving to pick it up in a few hours. It's a unfinished project. I've been told AC works great serviced recently. Furnace and WH removed for inspection/service. Plastic bins are there too. Subfloor replaced in bathroom. I'll have many questions after I get it home.
We made it home. One minor issue. She started flapping her wings trying to take off. I had to stop for some duck tape. The latches were removed from most windows. Latches are in the parts bin.
Snapped a quick picture at the start of our 125 mile journey home. I think they go together well.
Window clips can be found from several aftermarket suppliers. They just slide on the glass with some sealant to hold them in place. The window cranks and parts are a little difficult to find. They come up on eBy at really high prices. You can find some on parts trailers if you are lucky. If you have all yours you are blessed.
Congratulations on the O-Lander and welcome to the forum. Love the Bluffton area, we spend a good bit of time on the May river digging oysters and catching blue crab.
Keep us posted on your efforts and progress.
Kevin
I assume the univolt should be mounted in the rear wardrobe closet on the right. There's a 6x6 aluminum bracket mounted mid height. Time for a new inverter. Searched a few threads in electrical section, and found the Power Dynamics on ebay they talk about. I'll order one of those soon. Meanwhile I have house power and an improvised inverter. (battery charger/tender) Not camping just keeping lights on while I clean inside.
This is a bunkhouse model. The original cots were stored below twin bunks. Does anyone know all the necessary parts? I don't think everything is here. I see metal brackets mounted in ceiling near air conditioner, but they aren't solid and appear to be mounted in inner skin only.
How solid are the wall brackets for the cots? Could a hammock be strung between brackets instead?
How stiff should the toilet lever be? Steady pressure opens the valve, and it closes. I think the misses will want it a bit easier to operate.
AC is a Duo Therm and not the Bay breeze I've seen in other posts. AC works, but needs to be cleaned.
Next task is plumbing inspection. I'm waiting on weather to warm up. Wait 5 minutes and the weather changes. Snow and freezing temps past few days. 70's this weekend.
The original, or last WBCCI # is 19232. WBCCI sticker and remnants on front. Buried in paperwork I also found a matching sticker. It was in the owners manual.
congrats, she looks great. I think the cots were a canvas type with a frame and attached to those brackets with a cable, but I've never seen one in person so I couldn't be much help. Glad you didn't lose any glass, that stuff is expensive, clips are an easy install.
__________________ Scott & Megan
VAC LIBRARIAN WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
Well unfortunately it looks like more than window clips. I have clips and I have the window locks. The locks are frozen/rusted, or missing the small clip piece. I don't see a way to rebuild other than replace the locks clip. I haven't found a replacement yet.
Snap and post a few photos, lots of people have rebuilt and or may have extras of those latches (which by the way are still to my knowledge not in production). flyrc on here might still have a few kicking around from a totalled 67 he picked up for parts a couple years ago. best bet is to start soaking those cranks etc with some good penetrating oil (something like PB blaster, not wd40) for a few days, that will help get things moving without breaking it in the process.
congrats on the 66. I bought the same year Overlander in the summer, still working on it. Where is the stove in yours? We have a get together in N GA in April if you are interested.
The small heater has been cleaned up, but not sure where it normally mounts. I have a few open gas lines. Any idea what the wooden plug could have been used for? What normally mounts at front of Airstream with the holes? Last is a window latch missing the inner tab to secure the window.
I've been reading your blog and posts for a while trying to catch up.
The stove mounts next to fridge on curbside. It's currently sitting in front of gaucho for testing this weekend.
As of 2 hours ago I will be workcamping sooner than expected. I now have to be ready by feb25th. Oh and move the family to our home in AL that week too.
OOPS! didn't catch stove. i read the post as oven on my phone. The stove vent leaked ruining the counter top. In turn the stove casing rusted out. PO replaced exterior vent and counter. They took stove out and used a camp stove next to sink. I'll have to use similar for the time being. I would like to put a recessed stove with flush cover back in.
I gotcha. I noticed the counter top and no stove. That's cool as you can put in a newer cook top when you are ready. Will be interesting to watch your progress. You probably know this- but I would re-seal every vent on the roof and around the top of the windows first.
I mentioned that because a lot of folks jump into the interior redo , and then the leaks ruin it. I found hidden leaks when I pulled out the fridge, some flooring, etc. Best of luck to you in this project. 66 is a special year for me.
