Old 08-07-2012, 08:14 PM   #1
1965 Overlander
1965 26' Overlander
Greenleaf , Wisconsin
Removed ac unit, now nothing works unless hooked to external power!
I removed my bay breeze ac unit. Now my power won't work unless I am hooked up to external power. If I try to connect the wires back together that are by the thermostat I blow my house breaker. I pulled the wires back in from the roof and reconnected those. I hope this was correct.
Heo is offline   Reply With Quote
Old 08-08-2012, 09:21 AM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
If you intend to do without an air conditioner, disconnect the 110vAC wiring for the A/C at the breaker; don't leave potentially live wires to dead-end where the air conditioner was. You could leave the wires in place rather than pull them out, once they're not connected to the breaker, but they have to be dead wires.
If you connect the wires back together, positive to neutral, where the air conditioner used to be, you've created a dead short, which will naturally trip breakers or blow fuses.
As for the power not working unless you're connected to shore power, if you're equipped with an inverter/charger, then you may have also fried the inverter/charger when the breaker blew, especially if it was charging the batteries at the time.
WBCCI #1105
My Google-Fu is strong today.
