Old 08-18-2008, 09:30 PM   #15
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
2006 30' Safari
Orlando , Florida
I know the screws holding my running and marker lights in place aren't aluminum because they are turning to rust...red rust not aluminum oxide. When this happens, most people replace them with stainless steel screws.
Family of Disney Fanatics
WBCCI# 4821
Old 08-18-2008, 10:03 PM   #16
hampstead38's Avatar
1967 26' Overlander
Upperco , Maryland
Galvanic corrosion requires an electolyte. Salt water is a weak electrolyte. This is why marine applications sometimes use a sacrificial zinc block (or anode)... and why people building metal boats (and ships) worry about it far more than people who build travel trailers.
I doubt an Airstream in a dry climate would have much galvanic corrosion. If you were in a much damper climate (with acidic rain) or in an area with salt spray (like the Eastern Shore), I would think galvanic corrosion might be a greater concern. Personally, I think stainless is preferable to zinc or untreated metal. What might be better, for nominal load applications like holding a light bezel, would be aluminum... at least from a corrosion perspective. From a mechanical perspective, I would prefer a stainless fastener.
hampstead38 is offline   Reply With Quote
String for Blinds DonaldWyllie Upholstery, Blinds, Walls & Interior Finishes 2 07-30-2007 05:43 AM
How long is a piece of string? abridges01 Buyer Guidelines 14 08-13-2006 07:17 AM
string for Day-Night Dwight Upholstery, Blinds, Walls & Interior Finishes 1 07-07-2004 08:56 PM
