Old 11-29-2008, 11:36 AM   #1
Hilandr451
Hilandr451's Avatar
1965 26' Overlander
Bakersfield , California
Send a message via Skype™ to Hilandr451
pop-up Roof Vents
I have an Overlander that is in pretty good shape. We are the 3rd owners. We purchased it from a friend in June of 2005 for $3500.00 and couldn't have been happier since the trailer was in such good condition bing preserved in the Mojave desert for the past 30 years with aluminum foil on all of the windows.
The only major damage was to the exterior. As you can imagine the glazing on all of the windows is breaking down, and the ferring for the AC has been ripped from it's attachments and is completely missing along with the pop-up roof vent over the front dining area. A previous owner had fashoned a vent cover from sheet aluminum and a block of wood. This worked pretty good in the desert, but we live in Northern California now where the rainfall is considerably greater than the Mojave desert.
I noticed that the crank mechanisms to open and close the vents are all broken and need to be replaced as well. Can these parts still be found? does anybody know where I could look for replacements? Or is a re-designed alternative available? I did find a ferring for the AC a few years back for $375.00. Right now we have to drape a tarp over the middle of the trailer to keep the water out in the rainy season (so the pristine original floors won't get damaged).
Greg Smith a.k.a. "The Highlander"
Vacaville Ca.
1965 Overlander, 1966 Chevy C20 'Custom Camper' tow vehicle.
http://www.picturetrail.com/gallery/...r451&x=15&y=10
Hilandr451 is offline   Reply With Quote
Old 11-29-2008, 12:30 PM   #2
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Sounds like a great find and a good price based on your description. Can you post a picture or two of the roof vents and opening including the broken lifters? These have changed over the years and I'm not for sure when those changes occurred. A pic or two would help.
Congrats on your new-to-you baby.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 11-29-2008, 12:42 PM   #3
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
Try Inland RV, Andy is here and so is Vintage trailer supply.
here are the web sites
Vintage Trailer Supply - Vintage travel trailer parts and supplies!
Inland RV Center Inc.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 11-29-2008, 05:51 PM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
I tried to get the crank assemblies for my 91 several years ago. Sent Jackson a picture and Airstream claimed they NEVER used such a thing and I must have installed them.
If the gear is stripped, like mine were, you can drill the rivets out and rotate the gear 180 degrees. The crank only uses less than half of the travel of the gear. Just make sure you lub the gear before reassembly and you will most likely get as much or more than the original life out of the rebuild.
2004 Excursion 4x4
Old 11-29-2008, 08:07 PM   #5
We have those vent operators machined.
Check out our part number 72377.
roof vents larrylisa Roof Vents, Skylights & Fans 10 12-28-2009 05:22 PM
Roof vents KeithC Roof Vents, Skylights & Fans 2 05-21-2007 05:43 AM
Roof Vents tique79 Roof Vents, Skylights & Fans 6 03-11-2007 08:07 AM
Roof Vents tmeagle1 Roof Vents, Skylights & Fans 6 01-10-2004 05:49 PM
Roof vents? aviontt Roof Vents, Skylights & Fans 10 10-05-2003 08:31 PM
