Old 10-08-2012, 06:40 AM   #1
dclampe's Avatar
1965 26' Overlander
Avon , Indiana
Help needed identifying things on my '65 overlander
We bought a 65 overlander international. There are a few strange brackets and other things I need help identifying what they were used for. For some reason I can't post more than one photo at a time, so ill break this into a few posts.
dclampe is offline   Reply With Quote
Old 10-08-2012, 06:44 AM   #2
dclampe's Avatar
1965 26' Overlander
Avon , Indiana
1. Rusty Steel brackets under rock guard behind propane tanks. They are too far away to be clips for holding the stone guard in place.
Old 10-08-2012, 06:45 AM   #3
dclampe's Avatar
1965 26' Overlander
Avon , Indiana
2. Aluminum bracket next to small lower window on side of airstream opposite door. Thought it might be a bracket for an awning, but it seems to low.
Old 10-08-2012, 06:48 AM   #4
dclampe's Avatar
1965 26' Overlander
Avon , Indiana
3. Copper line coming out of fresh water tank. There's a T connection out of the top of the tank one side goes directly down past the fill hose of the tank and under the belly pan of the trailer with a valve and a patch job in the metal. The other side goes to the other side of the fresh water tank and goes through the belly pan and has a threaded fitting on it. Thought it was a system for draining the tank, but why would the fitting come out of the top of the tank? Maybe compressed air in the threaded side and valve to blow the water out the other side?
Old 10-08-2012, 06:48 AM   #5
dclampe's Avatar
1965 26' Overlander
Avon , Indiana
Picture of valve
Old 10-08-2012, 06:49 AM   #6
dclampe's Avatar
1965 26' Overlander
Avon , Indiana
Picture of threaded fitting
Old 10-08-2012, 06:51 AM   #7
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Bracket 2 looks like it used to hold an outdoor thermometer.
Brackets #1 must have been added by a PO. I'd remove them, clean off the rust, and fill the holes with Olympic rivets.
Chris
Old 10-08-2012, 06:51 AM   #8
dclampe's Avatar
1965 26' Overlander
Avon , Indiana
4. L shaped brackets on roof near awning channel. I'm pretty sure the channel below the brackets is for an awning (non-retractable). Would the L brackets be for storing something on the roof? They don't look original to me.
Old 10-08-2012, 06:52 AM   #9
dclampe's Avatar
1965 26' Overlander
Avon , Indiana
Is the rusty bracket in this picture something for an awning as well?
Old 10-08-2012, 06:53 AM   #10
dclampe's Avatar
1965 26' Overlander
Avon , Indiana
Chris
I didn't think about a thermometer. I bet your right. Thanks!
Old 08-13-2013, 03:58 AM   #11
dclampe's Avatar
1965 26' Overlander
Avon , Indiana
Originally Posted by Bessie1968 View Post
Hi there,
I am looking for my grandfather's 1965 Overlander. Any chance you could check your VIN number for me? Here is my post below, thank you so much for your time:
Looked at a picture of my VIN. Different number and I have the paperwork from the original sale and it originated in the great state of Indiana.
Good luck with the search.
Old 08-13-2013, 06:26 AM   #12
1977 Argosy 24
Milltown , Wisconsin
I bet those brackets held a level vial, used for leveling the trailer side to side.
ventport is offline   Reply With Quote
New to me Overlander Northlander 1975 Overlander 10 12-04-2011 05:33 PM
Catarina 1963 Airstream Overlander :: 1963 Airstream Overlander utee94 Airstream Registry Discussions 0 08-19-2011 08:31 AM
1966 Airstream Overlander Bob J. Mariano 1966 Overlander 1 08-05-2011 03:44 PM
Considering a '67 Overlander, Advice Needed hlo Buyer Guidelines 3 06-16-2011 01:56 PM
