Old 04-26-2010, 03:38 PM   #1
technautica's Avatar
Red face furnace challenges
Finally dealing with the last item of my restoration. The International MGF 1525 model in my Overlander is on the bench in pieces. I have tested and checked everything and the only issue that still needs attention is the burner manifold which has rusted out. Has anyone found a source for these or replacement parts for this unit; or if not, what furnace is the best fit for a replacement. Comments are not very complementary about these units however I would really like to use the stock unit if I can fix it. Thanks in advance for any help - James
technautica is offline   Reply With Quote
Old 04-26-2010, 03:45 PM   #2
CAUTION That furnace is guaranteed to explode.
Any and all parts for them have long been discarded because of the huge liability.
Take the furnace and bury it, 12 feet deep, so that you make doubley sure NO ONE, ever see's it or touches it.
There were over a dozen recalls on that furnace, "WHEN IT WAS IN WARRANTY".
The gas valve fails to shut off completely, far more often than not, along with many other issues.
Old 04-26-2010, 04:52 PM   #3
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Interesting, if it does not explode where does the original poster go to get action on that guarantee?
>>>>>>>>>Action
Old 04-26-2010, 05:58 PM   #4
RichHog's Avatar
1972 23' Safari
Houston , Texas
Furnace Replacement
The most popular is the Suburban NT30SP. About $340. Put one in mine back in Feb after trying to buck the odds and repair the original furnace Search on that model in the furnace/heater section and you'll find lots on info on where/what to do.
RichHog is offline   Reply With Quote
Old 04-26-2010, 07:03 PM   #5
>>>>>>>>>Action
International Oil Burner.
When they were around, they would probably say, "you must be doing something wrong", because it should blow, as many did.
Old 05-05-2010, 09:25 PM   #6
Aluminitus Carrier
lovingtahoe's Avatar
1968 26' Overlander
south lake tahoe , California
Send a message via Skype™ to lovingtahoe
Thumbs up
What years was this exploding furnace used in Airstreams? Thinking of buying a 1971 Overlander or a 1974 Tradewind... would be wise to replace furnace regardless of functionality? I really don't want to explode :O
addendum - just found answer! http://www.airforums.com/forums/f427...call-2889.html
Come visit my Airstream Web-Log at:
http://mandarava.net/airstream
WBCCI - #4066 / Sierra Nevada Unit 157
TAC - # CA-9
South Lake Tahoe, California
lovingtahoe is offline   Reply With Quote
Old 05-05-2010, 09:58 PM   #7
Suburban furnaces never had a recall regarding any explosions.
The furnace that did and still does have that reputation was made by International Oil Burner, which was used in the early sixties Airstreams.
Contrary to the name, they did make an LPG fuel burning furnace.
Old 05-05-2010, 10:22 PM   #8
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Likely the one in my silver bullet. It is original and I only lit it off once after cleaning the burner area.
It didn't blow up. However I don't really need that kind of heat here, so it hasn't been used since 2002.
So what do I have to do to collect on your guarentee since you made the claim?
>>>>>>>>>>>Action
Old 05-05-2010, 10:26 PM   #9
Aluminitus Carrier
1968 26' Overlander
Ah, thanks Andy for the clarification on that! I have read too many threads on the furnaces issues and I am starting to combine them into one big scary mess in my head! Seems what I should be concerned about is a gas leak.
TAC - # CA-9
Old 05-06-2010, 03:20 AM   #10
>>>>>>>>>>>Action
Well, you could have someone from your estate, call me.
But, I would hear from you, that you planted that furnace, in the water, about 1000 miles west of Los Angeles.
Old 05-07-2010, 08:23 AM   #11
RichHog's Avatar
1972 23' Safari
Houston , Texas
Actually we've started a new reef in the Gulf of Mexico south of
Louisiana.
Old 05-07-2010, 10:33 AM   #12
3 Dog Nite's Avatar
1989 34.5' Airstream 345
Cleveland , Tennessee
Oh no. Please don't put another International oil Burner product in the gulf!
Ricky
"Sometimes I wonder if the world is being run by smart people who are putting us on, or by imbeciles who really mean it." Mark Twain
AIR 22749 WBCCI 2349 NOVA TAC TN-6
1989 345 LE Classic Motorhome
3 Dog Nite is offline   Reply With Quote
Furnace scf31 Furnaces, Heaters, Fireplaces & Air Conditioning 9 03-09-2010 01:11 PM
New Furnace etc. spunjes Furnaces, Heaters, Fireplaces & Air Conditioning 1 11-06-2009 07:11 PM
bathroom challenges technautica 1965 - 1969 Overlander 7 01-17-2008 01:44 AM
Furnace Help Hind-Sight Furnaces, Heaters, Fireplaces & Air Conditioning 2 12-05-2006 12:06 AM
Furnace kooblekidz Airstream Motorhome Forums 3 11-06-2002 06:09 PM
