Nope. I think my daughters would miss them too much.
Originally Posted by NevadaGeo
Oops, looks like a jack under your rear bumper. Don't think that's a good place, usually there's a marked, strengthened place on the frame to jack up near the rear of your tires. But I don't know your particular trailer.
Look again. I don't even HAVE a rear bumper.
I do have a couple jack stands under the rear framerails to support the rear of the trailer. It is fine.
Here's what I got done last night, snapped the new hubcaps on to see how they looked:
Last night I worked a little bit on the outside light by the door.
I pulled the burnt lightbulb out, cleaned the contacts, put in an 1157 and voila!
There was a small hole in the skin to the right of the light. Someone had punctured through the interior with a screwdriver. I drilled out the rivets and pulled the light housing off and was able to get to the back of the dent/hole with a dolly and work the dent a little with a body hammer. I'll put a dab of silicone on there to keep the water out for now.
Now I need to re-seal behind the housing and re-rivet it back on.
yeah, you made a lot of progress, think about how close you are to getting it usable.
My 66 sat in a field for 19 yrs or so before I got into it. I am enjoying it as we speak.
