Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Overlander > 1965 - 1969 Overlander
Old 04-02-2010, 11:18 AM   #1
1969 27' Overlander
Kansas City , Missouri
Door gasket
my 69 overlander appears to have a leak in the front door gasket as I get water seepage on floor and floor is spongy at that door entrance. Is it difficult to replace the gasket/seal on the door? It looks like it was sealed into outer and inner panels of the door (riveted). Thanks.
mmcpherson is offline   Reply With Quote
Old 04-07-2010, 09:53 PM   #2
mbmbstreamer's Avatar
2006 25' Safari SS SE
1969 27' Overlander
Martinez , Georgia
Door Gasket on 69 Overlander
We replaced the weatherstripping on all windows, compartments, and the door of our 69 Overlander. The process is simple, but time consuming and details are available from Inland RV. In summary:
1. Cut old weatherstripping off with utility knife. Get it as close to metal as is reasonably quick.
2. Using a wire brush on a drill, remove remaining material and glue residue. Be very careful not to catch the aluminum edge - it bends and scratches easily.
3. Using a solvent (like alcohol) clean the frame.
4. Cut a piece of weatherstripping about 1" longer than needed.
5. Apply black 3M Super Weatherstrip Adhesive to weatherstripping and to frame.
6. Allow both to dry per instructions on adhesive.
7. Carefully place weatherstrip in desired location and work it around with both hands.
8. At joint (should be in the middle of the bottom edge, let overlap stick up (unattached) for about 10 minutes.
9. Cut excess material and finish pressing weatherstrip in place.
10. Wipe off excess adhesive carefully (don't pull on weatherstrip).
Matt
WBCCI # 3518
TAC# GA-6
mbmbstreamer is offline   Reply With Quote
Old 04-07-2010, 09:56 PM   #3
Ottawa , ON
The only suggestion I would make to this is to use a copper-wired wheel on your drill. It's softer and less likely to do damage to your frame or any other bits it touches, yet will do a fine job of burnishing the old bits of stuff off.
Copper wheels can be a bit more $ than regular metal ones, but it's an Airstream: you're used to that, right?
Old 04-20-2010, 09:40 PM   #4
1969 27' Overlander
Thank you so much. Did you get your materials from Inland?
Old 04-20-2010, 10:48 PM   #5
All the exterior gaskets, are easy to replace.
No special tools required.
Scrape off the old, best you can, burnish off the rest with a wire wheel in a drill.
mbmbstreamer, above, lists the installation instructions.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 04-21-2010, 05:38 AM   #6
Retired.
. , At Large
You can get them from most any Airstream dealer.
Old 04-21-2010, 03:53 PM   #7
1969 27' Overlander
Martinez , Georgia
My instructions and weatherstrip came from you, Andy.
Worked great! Now if I could just adjust the door latch. The new gasket (none was present when we bought the trailer) makes it very hard to close. Hints or tips?
Matt
WBCCI # 3518
TAC# GA-6
Old 04-21-2010, 04:25 PM   #8
Is the striker bolt in good condition?
Is the striker pocket nylon, as it should be?
Andy Rogozinski
Inland RV Center
Corona, CA
Old 04-21-2010, 09:08 PM   #9
1969 27' Overlander
Martinez , Georgia
The bolt and lockset are new last summer (from you). The striker pocket is original metal. With the weatherstrip in place, the bolt doesn't reach the pocket without significant force to compress the weatherstrip. I either need a spacer to push the bolt out, away from the exterior surface of the door, or I need to move the pocket closer to the exterior wall.
Matt
WBCCI # 3518
TAC# GA-6
Old 04-21-2010, 10:35 PM   #10
First of all, the correct striker pocket is nylon, not metal.
Replacing it may solve the entire problem.
It also sticks out further than the metal pockets.
Andy Rogozinski
Inland RV Center
Corona, CA
door leak, door seal, gasket
Door gasket Sjean Doors & Locks 30 05-09-2017 10:47 PM
53 door gasket pinktrailer Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 07-03-2009 04:59 AM
'63 Door Gasket dieseleagle Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 06-16-2009 05:04 AM
Which door does gasket go on? 63air Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 05-18-2009 12:02 PM
Gasket on door or inside of door? Becky B. Leaks - Weatherstrips, Gaskets, Caulks & Sealants 14 07-06-2007 01:06 PM
