My bath is the same, the only difference being the upper edge of the sink piece is trimmed out on mine just below the window. Nonetheless, the sink can be lifted out as I mentioned before. It looks as though your trim (above and below the sink piece) is the same unobtainable two-piece plastic as mine. The cover part is a "C" that clips over the entire lower part, both made of incredibly brittle material. If you carefully pry the cover off and then drill out the rivets holding the lower section, you can salvage these, and they look great cleaned and painted.
Once the sink is lifted out, you'll have full access to the plumbing. I went with all new fixtures and pex lines, although mccrosti posted that he got a new tub fixture cartridge from Moen and salvaged his for about 50 bucks. I couldn't find a new fixture with an escutcheon plate small enough to fit, so I modified the old plate to a new fixture.
The connector to the shower hose can be a problem to replumb from the back. If the original copper fitting is sound, you may want to cut the copper line to it with just enough length to connect to your new line with a Shark Bite fitting. This may make more sense when you get a look back there; it's hard to describe.
Keep us updated on your progress,
Alan
