Old 08-29-2018, 02:01 PM   #43
Joyflea's Avatar
1967 26' Overlander
Alpine , Texas
Foil in
Bucked about 100 rivets this week to tighten up what needed it . Waiting for some oversized to come in so I can finish that .
Sanded from 3 feet of the floor from front to back , side to side inside using a coarse scotch brite . Then used auto epoxy seam sealer on all joints and any place that looked like it might leak . Covered everything I didnít want paint on with plastic sheeting.
After drying, coated it all with PPG epoxy primer , rolled it on . Next day put two coats of lizard skin on . Great insulation I use on the cars I build ,heat and sound .
Then finally put my foil insulation on . 95% done with that . Still got to do the tail light area . Goining to seal that area up with a box after I pull and reseal them .
Will be off the toaster for about 3-4 weeks . Be oot camping and catching up with the Cannonball race and going to an antique Mc road run in SD .
When I return my ZD awnings should be here and Iíll know my mounting areas that I want to relnforce . Then Iíll start wiring.
BlueClick image for larger version
Joyflea is offline   Reply With Quote
Old 08-31-2018, 07:14 PM   #44
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Yeah, take a little break. Enjoy your other hobbies. The trailer will be there when you get back. I think you are building the best vintage Airstream in Texas, and maybe other parts too. Ain't many folks, including me, who go around and replace loose rivets. Great job.
David
WBCCI #8607
VAC Region 11
Link to my 1975 Overlander Improvement Journal:
https://www.airforums.com/forums/f17...ml#post2053792
Old 09-01-2018, 11:02 AM   #45
Joyflea's Avatar
1967 26' Overlander
Alpine , Texas
R&r
Thanks for the nice words . Got ADD so I go overboard sometimes. LOL
I do need some R&R , got my truck camper loaded and changed the oil and plugs in my 49 . Guess Iíll be ready to hit the road next week . BlueClick image for larger version
Old 09-01-2018, 06:44 PM   #46
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
That Harley is as old as you are! It looks beautiful. And I'm sure your Airstream will look beautiful when you are done with it.
Safe travels...
David
WBCCI #8607
VAC Region 11
Old 09-27-2018, 02:13 PM   #47
Joyflea's Avatar
1967 26' Overlander
Alpine , Texas
Back from vacation.
Got home last weekend and after 4or5 days of getting things back to normal I started laying out wire locations for wires after discussion of floor layout (still not completed on floor layout ) . Started pulling wire for 120 AC . Got 5 rolls of 12ga stranded in different colors for 12volt dc. Hope to get the Airstream wired , tv antenna,solar wires,and final floor layout finished by the end of October.Click image for larger version
Don’t know why photos came out sideways ?
Old 09-27-2018, 06:36 PM   #48
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Welcome back joyflea: We did a little Airstream traveling last week too. Overlander sits in the shop, no progress.
Maybe you are taking them with an Apple phone. I can't use the Apple device for pictures as I get weird rotations when I upload them. I also get different sizes of photos when using the phone. So I resorted to my old fashioned cheap "point and shoot" camera. I can load the photos onto my laptop and then upload them to Air Forums. Seems to work better for me. Software comparability? Kinda like a metric nut on a SAE bolt.
I bet others will chime in with the exact reason and correction for sideways pictures. I'm no computer expert by any means. It is just my experience with pictures on Air Forums.
David
Name:	1809 Carbondale Camp-800x600.JPG
WBCCI #8607
VAC Region 11
Old 09-27-2018, 08:28 PM   #49
Joyflea's Avatar
1967 26' Overlander
Alpine , Texas
Shot these with my iPad usually use my cheap camera and download in my iPad . They both look the same in photos .
Old 09-28-2018, 03:35 PM   #50
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
I don't know the reason the pictures are rotated but I do know if I crop them just a bit they show up here correctly.
Nice looking trailer.
Dingo Girl is offline   Reply With Quote
Old 09-28-2018, 04:13 PM   #51
farafield's Avatar
2018 16' Sport
Charlotte , Vermont
Originally Posted by Joyflea View Post
Got home last weekend and after 4or5 days of getting things back to normal I started laying out wire locations for wires after discussion of floor layout (still not completed on floor layout ) . Started pulling wire for 120 AC . Got 5 rolls of 12ga stranded in different colors for 12volt dc. Hope to get the Airstream wired , tv antenna,solar wires,and final floor layout finished by the end of October.Attachment 323841
Attachment 323842
Donít know why photos came out sideways ?
That is so cool to see! Thanks for sharing! -Kim
Don't let the sound of your own wheels drive you crazy...
Kim
Charlotte, VT
2010 F-150, 5.4l, V8, 3.55; Bramble: 2018 Bambi Sport 16
farafield is offline   Reply With Quote
Old 10-05-2018, 12:51 PM   #52
Joyflea's Avatar
1967 26' Overlander
Alpine , Texas
Finished the 110 . Start the 12 volt tomorrow. Man this little crap takes forever.
Old 10-05-2018, 04:45 PM   #53
Joyflea's Avatar
1967 26' Overlander
Alpine , Texas
UPS just showed up .
Well my UPS driver just showed up with our new stove top . Looks well made and I got it off EBay with free shipping from overstock.com . Man I canít wait to start building cabinets, maybe November.Click image for larger version
Old 10-08-2018, 04:23 PM   #54
Joyflea's Avatar
1967 26' Overlander
Alpine , Texas
Wiring
2 more 12v wires to run . Tape all the wires in place . New screws in porch light after some sealer. Run solar wires . Mount tv antenna and run wire . Run drain on ac .
The list gets shorter !
Tested the light circuit and all works great . Hope to have wireing done by Monday . Need to button up some small stuff and be ready to insulate and mount all the interior skin . May get it painted before the weather changes in November.
ID:	324746   Click image for larger version
ID:	324748   Click image for larger version
Old 10-08-2018, 04:29 PM   #55
Joyflea's Avatar
1967 26' Overlander
Alpine , Texas
This looks better .
Old 10-09-2018, 03:33 PM   #56
chrisetmike's Avatar
1967 26' Overlander
Haute-Aboujagane , New Brunswick
It all adds up in the end but the little stuff does seem to take forever! Keep pluging away! It is getting there.
chrisetmike is offline   Reply With Quote
Seeking a 19-21 foot project trailer for Food Truck project debbooooo Airstream Classifieds 0 09-06-2016 01:00 PM
California project trailer - fix title now? kaulike Title, VIN & Registration 9 06-05-2012 04:48 PM
To fix or not to fix nayl Ribs, Skins & Rivets 16 07-17-2010 08:38 PM
1967 Airstream Overlander 27' Good Project, Polsihed! eBay Watch Airstreams on eBay 0 05-27-2009 03:40 PM
You Fix-You Camp-You Fix Some More juel Off Topic Forum 6 08-18-2005 07:50 AM
