08-16-2019, 06:36 PM
#281
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer
You do great work in such lousy heat. That backsplash will be so dramatic in your Overlander.
David
WBCCI #8607 VAC Region 11
KnowledgeBase trailer renovation threads: 69 Globetrotter, 76 Sovereign, 75 Overlander, 66 Trade Wind Such fun !
08-21-2019, 12:48 PM
#282
1967 26' Overlander
Alpine
The heat
Been complaining about the heat in the Airstream, but after some jury rigging the electrical to the AC it’s nice . First temp is outside on the skin . Second is in the upper cabinets away from the AC . Might need long underwear. Loving it .
Blue , with no excuses.
08-21-2019, 07:06 PM
#283
1986 34' Limited
1975 27' Overlander
Conifer
We have "dry heat" (think baking oven) here in Colorado. Yesterday the air temp was 83 here, but the sun is so intense. The boards on my south facing deck were 160 degrees by noon, and the entry door was 140 degrees. The sun heats the house and it gets darn warm in here. I'm no fan of intense heat. Like clouds.
Glad you got some relieve with the ac going with ac.
David
09-10-2019, 01:01 PM
#284
1967 26' Overlander
Alpine
Nothing is square in an Airstream
09-13-2019, 06:29 PM
#285
1986 34' Limited
1975 27' Overlander
Conifer
You are correct, there is nothing square in an Airstream. You have to custom fit every piece almost. I like the storage cabinet below the front window. A great way to make a backrest support.
The area you are building is where you will spend the majority of time in the trailer. The kitchen table is the center of most homes.
David
09-16-2019, 08:57 AM
#286
1966 24' Tradewind
Kansas City
, Missouri
Thanks for posting the pics, Joyflea. I just have the bottom section of my dining/sleeping area roughed in while I wait for my new fresh water tank. I like your upper sections. I also noted evidence of your Kreg jig, or whatever version you used for anchoring screws. I, too, have used one of those hanging lights throughout my project.
09-17-2019, 08:20 AM
#287
1972 31' Sovereign
Lexington
Airstream renovations are good for learning how to mark and cut compound curves in cabinetry and countertops! That's how I learned...
Kay
09-17-2019, 11:17 AM
#288
1967 26' Overlander
Alpine
Originally Posted by Minno
Air
Kay
True , so true ! Everyday is a school day.
09-18-2019, 07:49 PM
#289
1967 26' Overlander
Alpine
09-19-2019, 07:54 AM
#290
1972 31' Sovereign
Lexington
Wow, I'm impressed!
Kay
09-19-2019, 01:46 PM
#291
1967 24' Tradewind
North Pole
, Alaska
Likewise! Well done!
09-19-2019, 03:25 PM
#292
1967 26' Overlander
Haute-Aboujagane
, New Brunswick
You will have an amazing Airstream when you are done.
09-21-2019, 12:38 PM
#293
1967 26' Overlander
Alpine
09-21-2019, 06:16 PM
#294
1986 34' Limited
1975 27' Overlander
Conifer
Certainly adds a nice vintage Airstream look to the front room. I made mine out of plywood 'cause I ain't got a louver die and press. Even if I did, they would all be crooked.
You are quite the craftsman.
David
10-03-2019, 02:32 PM
#295
1967 26' Overlander
Alpine
10-04-2019, 07:08 PM
#296
1986 34' Limited
1975 27' Overlander
Conifer
Electrical and plumbing. I find these jobs enjoyable. You made "store bought" cables for your trailer. I made "homemade" cables for mine. Crimped and taped. Not as good as yours.
I have a question for the automotive electrical expert. I elected to leave my converter in it's nearly original Airstream location. Behind the bathtub! Handy huh. I did so because the four 12v circuits that power all the appliances, lights, fans, pumps, et.al. in the trailer radiate from this location. I did not want to splice and extend that big wiring harness.
The battery used to be in the rear of the trailer in a special swing down compartment below the beltline. I did not want a 60 pound battery bouncing up and down as I crossed rough bridge abutments or wavy concrete roads and the like. In 1976 Airstream saw the errors of their ways and moved the battery up front over the frame rails. So I followed suit on my 75.
But the converter is still in the back. So I have 25' of ought sized stranded copper wire from the battery to the converter running under the subfloor. The chart says I will lose about 0.2 volts over this distance with this sized wire. I think I'm okay as I don't boondock much, but it is still a loss of power.
Think I'm in trouble?
David
10-06-2019, 03:16 PM
#297
1967 26' Overlander
Alpine
David
No , I don’ Think you have a problem . I moved mine because I did not like it being under a wet area plus weight . Since I took off the skin and rewired the whole trailer , I planed on the new location . Also put an extra cross member up front under the batteries and welded a large ground plate that I drilled and taped holes in under the floor .
10-06-2019, 06:51 PM
#298
1986 34' Limited
1975 27' Overlander
Conifer
Thanks for your view on this long, long battery cable. My battery is sitting on a piece of 3/4 oak on top of the 3/4" plywood subfloor on top of the A frame member. It is sitting in a plastic battery box. I don't believe it will fall through to the ground. It is a AGM battery that I did not vent to the outside world.
David
10-16-2019, 12:04 PM
#299
1967 26' Overlander
Alpine
Work
10-17-2019, 04:41 AM
#300
1956 22' Safari
1962 28' Ambassador
Williston
, Vermont
Looking good, I can't wait to see it when she is done. You will have a very unique beautiful trailer with all of that aluminum.
If you don't mind, a couple of questions:
What type of aluminum are you using?
Did you use a shrink-er die set for the bench edging? Will the stretcher die set have enough movement to do the inner corner? I haven't worked with those tools but have been intrigued and just don't know their limitations.
What are you using to cut out the aluminum pieces? Your edges are very nice.
Thanks, Mark
