Old 06-24-2015, 05:28 PM   #1
Mission , Texas
Yes another floor replacement thread
Unless I'm overly confused, the Airstream similar to a house, has a sub-floor (3/4" plywood in my 75 Overlander) and a finish floor (carpeting, floor tile, etc.) Similar to a house the sub-floor needs to be intact and damage free (another discussion in itself).
So a few questions ...
Why use the fake wood or cork supposedly water proof finish floor products?
(from personal experience in hospitals the only true water proof flooring is found in operating rooms and is very expensive)
What about the added weight from these products?
What about replacing the finish floor with a product similar to the original?
For example - mine has floor tile. The PO covered it with a fake wood product (and did a terrible job). Why not replace with floor tile or a sheet product?
Has anyone ever had their old floor tiles tested for asbestos?
Thanks beforehand
nrgtrakr is offline   Reply With Quote
Old 06-24-2015, 05:40 PM   #2
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Hi and welcome.
A few answers-
"Why use the fake wood or cork supposedly water proof finish floor products?"
I don't use them.
"What about replacing the finish floor with a product similar to the original?
For example - mine has floor tile. The PO covered it with a fake wood product (and did a terrible job). Why not replace with floor tile or a sheet product?"
I have used fully glued sheet Marmoleum with good results. You can read the thread "Abby gets some separation H" to see how it did it.
All Airstream floor tiles up to 69 when they went with mostly carpet contain asbestos. The only one I ever tested was a 1966.
Good luck and have fun!
Lance
Top is offline   Reply With Quote
Old 06-24-2015, 06:19 PM   #3
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
We have a floating cork floor in most of our trailer. It is warmer than tile or sheet vinyl. Our vinyl bathroom floor is much colder than the cork. We get many positive comments when people walk in our trailer about the floor. It did add several hundred pounds of weight to the trailer, so we factored that in as we rebuilt the trailer interior. Overall our trailer came in at about the weight we were aiming for at 6500 lb . We would use cork in the bathroom too, if we were to do it again. We are very happy with it.
Kay
Old 06-24-2015, 06:22 PM   #4
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Why is the sky blue?Each to their own tastes and personal preferences.
I for example replaced most of my subfloor with Coosa board which is waterproof and 45% lighter than the plywood it replaced. I used an engineered hardwood flooring on top as I liked the look of wood but didn't want the problems (expansion and contraction) of a solid wood floor. The added weight of the flooring was compensated by using the Coosa below. I don't like carpet and didn't want different types of flooring to busy up the interior as I had linoleum and carpet before. The only place I carpeted was the drivers cockpit and doghouse. There are many other options including a plastic tile slate like flooring, laminate and all sorts of others to personalize your rig.
Are you sure your subfloor is 3/4 as most Airstream including my own is a 5/8 thick subfloor.
Cheers
Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Old 06-25-2015, 12:08 PM   #5
59' Globester
twolanehwy's Avatar
1959 18' "Footer"
1957 26' Overlander
san francisco , California
If I was replacing the floor i'd def use 3/4 as 5/8 is just a lame idea.
I also noticed when i do mine in a year or two I will be beefing up the frame cross members in some spots. There are many ways to improve on the AS design.
twolanehwy is offline   Reply With Quote
Old 06-25-2015, 01:51 PM   #6
bellastream's Avatar
1969 31' Sovereign
Auburn , Washington
I used sheet vinyl flooring and it's warm and it looks like wood!!!Click image for larger version
bellastream is offline   Reply With Quote
Old 06-25-2015, 02:07 PM   #7
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
Love my cork
Floating cork flooring installed in my 55.
ID:	241583   Click image for larger version
BambiTex is offline   Reply With Quote
Old 06-25-2015, 10:56 PM   #8
Mission , Texas
Thanks!
Yes the sub-floor on my 1975 Overlander is 3/4" as is the tub support. Hopefully it will never need a new sub-floor.
The PO did a horrible job with the fake wood over old floor tiles. That is next to go. Hopefully the original floor isn't too bad. If not, as long as we don't snort the removal, life will go on - besides I'll likely die of old age before any asbestos symptoms show up.
Love the photos. I haven't figured out how to post photos yet.
Old 06-26-2015, 12:14 PM   #9
1965 30' Sovereign
1969 23' Safari
Redgranite , Wisconsin
Coosa Sub-Floor
Isuzusweet wrote: I for example replaced most of my subfloor with Coosa board which is waterproof and 45% lighter than the plywood it replaced.
Can you elaborate on how you re-attached your cabinets? I also used this poly product with fiberglass reinforcement as it was lighter, stronger and waterproof. BUT, it doesn't hold screws well. When I reattach my bath cabinets I was thinking of nut-zerks or wood backing plates. Interested to learn what you did.
Lots to do. Getting there.
65Streamer is offline   Reply With Quote
Old 06-26-2015, 03:26 PM   #10
Dazed and Confused
Isuzusweet's Avatar
Nothing that a little PL Premium nails squirted on the back of a L bracket wouldn't solve. PL Premium bonds to practically everything....except ABS.
Cheers
Tony
Old 06-26-2015, 03:34 PM   #11
airdreamers's Avatar
2008 28' International
Venice , Florida
Images: 14
Well, I will add my 2 cents. I read about all these floors being plywood. I replaced several sections of my floor (wafer board). Used 3/4 CDX plywood, Floating laminate on top, good to go, we'll see. I'm happy!
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 06-26-2015, 06:35 PM   #12
Mission , Texas
Sub-floor ... maybe I'm again confused, but in a leakproof, catch the leaks early and shower discipline so water goes down the drain and not elsewhere world there should be no "need" to change the sub-floor. No?
Old 06-26-2015, 06:56 PM   #13
aquinob's Avatar
Portsmouth , Virginia
Most of the rot is caused by water that leaks in between the inner and outer shells and runs down to the c channel and then leaks through and saturates the edge of the subfloor. The owners never see the water, and only if they are vigilant do they see the telltale signs of staining at the edges, usually underneath something or inside on the floor of a cabinet or closet. It all takes quite a bit of time, but in a lot of instances, the current owners aren't using the trailer much or have just lost interest.
Ongoing adventures at:
http://1973overlander.blogspot.com/
aquinob is offline   Reply With Quote
Old 06-26-2015, 07:18 PM   #14
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
I'd be willing to bet you have rotted sub-floor a few places in your trailer. Especially if the PO layered on some "fake wood product".
All Airstreams leak.
Lance
Yes, another Filaform thread AWCHIEF Ribs, Skins & Rivets 19 08-18-2014 10:25 PM
Paint.......yes another thread..... Flysoncloud Upholstery, Blinds, Walls & Interior Finishes 12 04-28-2011 08:22 AM
another floor replacement question durans54 Repairing/Replacing Floor &/or Frame 32 02-01-2007 12:29 PM
Yes, another service manual question - 1971 63Airstream 1970 - 1978 Globetrotter 2 01-16-2007 08:11 AM
Household chemicals Yes, yes or No, No? thecatsandi On The Road... 3 03-27-2006 07:01 PM
