Old 09-11-2010, 09:49 PM   #1
1967 26' Overlander
Simpsonville , South Carolina
Wrap Removal
Hi all,
I want to begin removing my belly pan and wraps so I can inspect my frame and outriggers ('67 Overlander). My question is how do the front corner wraps come off? They almost look to be atttached to the interior C channel and skin. Is that right? Seems like they should come off without disconnecting the shell from the frame essentially.
Tim
Channeti is offline   Reply With Quote
Old 09-12-2010, 08:30 AM   #2
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
Indeed - as originally installed, the trim has to be dropped and wrap rivets drilled then sort out the underside rivets. Know you are on the precipice of a very slippery slope that can not be traversed wearing rose colored spectacles!
Belly Pan & Banana Wrap Removal IronGiant Belly Pans & Banana Wraps 2 06-06-2009 08:56 PM
Need wrap window coyoteclay Member Introductions 1 10-29-2007 09:12 PM
Cabinet Removal - Closet Removal 2333 Cabinets, Counter Tops & Furnishings 2 10-05-2006 01:00 PM
Banana Wrap Lumatic Belly Pans & Banana Wraps 2 09-05-2005 06:55 PM
Banana Wrap trogers713 Belly Pans & Banana Wraps 1 10-27-2003 05:36 PM
