View Poll Results: Would you be in favor of these changes??
Complete trailer frame treated with POR 15 before outer shell is attached. 19 57.58%
Complete trailer frame constructed out of Aluminum materials. 15 45.45%
Doesn't matter about the POR15 paint treatment prior to construction 2 6.06%
Doesn't matter about trailer frame Aluminum constructions 0 0%
Multiple Choice Poll. Voters: 33. You may not vote on this poll
Old 02-20-2009, 06:14 AM   #43
2007 25' Classic
Hydes
I don't think Por 15 would be a cost effective or practical way to protect the chassis. for Airstream. Anyone who has ever purchased or applied the stuff should know what I mean. Gavanizing would be a much better solution. There are probably be many companies that Airstream could job this out to. Airstream sells a life style and image as much as a product and it's obvious which is more important.
craftsman is offline   Reply With Quote
Old 02-20-2009, 07:10 AM   #44
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Image...
Frame, out of sight out of mind.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 02-20-2009, 08:16 AM   #45
Alvarado , Texas
I disagree,
Northwoods rv has been using Por15 on there frames for the Nash and Artic Fox rigs for many years with excellent results.
Ken
ckwizard is offline   Reply With Quote
Old 02-20-2009, 09:09 AM   #46
Interesting.... Starcraft Star Stream
I-Beam Steel Powder-Coated Frame
PFC
"Tahawus"
RLC
John Prine
Old 02-20-2009, 05:39 PM   #47
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Exclamation Odd..
Originally Posted by Inland RV Center, In View Post
Auto spray undercoating works great.
Styrofoam is not recommended since it turns to crumbs from simple vibration.
Andy,
Interesting that you should know this and...Apparently, Airstream doesn't listen to you either..
I took this statement off Airstream's UK site..
Spec..on the floor and I quote~
"48mm thick sandwich floor - Styrofoam insulation"
Here's the entire ads statement..
CHASSIS & SUB STRUCTURE 532 534 684
48mm thick sandwich floor - Styrofoam insulation STD STD STD
BPW galvanised steel chassis, with outriggers STD STD STD
BPW 1700kg torsion bar axle, for smoother ride 1 N/A
1 1 N/A
BPW 1350kg load compensating torsion bar axles N/A 2 N/A N/A 1
EU compliant over-run braking system
STD STD STD
Winterhoff ZAF2,0-2 coupling with WS3000 stabiliser 1 N/A
1 1 N/A
Winterhoff ZAF2,8-2 coupling with WS3000 stabiliser N/A 1
N/A N/A 1
Diamond cut lacquered / black painted 15" alloy wheels 2 4 2 2 4
Heavy duty corner steadies with Big Foot spreader pads 4 4
4 4 4
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 02-20-2009, 06:30 PM   #48
Originally Posted by 53flyingcloud View Post
Andy,
1 1 N/A
STD STD STD
1 1 N/A
N/A N/A 1
4 4 4
Some of them still don't believe in the flat rate manual, that I wrote in 1970, either.
But, since I have a service department, and as hard as it may be to say, I make money from some of their mistakes.
Old 02-20-2009, 08:35 PM   #49
on the hunt
osolow's Avatar
riverton , Kansas
Send a message via Skype™ to osolow
i like the powder coating idea plain black, gloss black, silver or A/S blue would be cool?
It is relatively easy to powder coat something and a big enough oven can do multiple frames at one time.
osolow is offline   Reply With Quote
Old 02-21-2009, 06:17 AM   #50
1972 Travelux Princess 25
Cobourg , Ontario
Sandwich floor means a layer of styrofoam glued between 2 layers of plywood. This makes an immensely strong structure. The outer layers protect the foam.
This makes a very rigid, light weight, insulated floor.
Living in the trailer park of sense, looking out the window at a tornado of stupidity.
Ganaraska is offline   Reply With Quote
Old 02-21-2009, 06:33 AM   #51
Cobourg , Ontario
Is the comparison of an Airstream to a car valid? Given the high cost, long life and intermittent use wouldn't a cottage or beach house be more like?
The life of a car might be 10 to 20 years, but 50 years for an Airstream or cottage is not unheard of.
I'm still thinking of the resale value or trade in value. Airstreams do hold their value better than a car and this should make it easier to "trade up".
I'm also thinking of friends who have taken their 3 to 5 year old luxury car back to the dealer to trade in. And were offered an insulting price like $500 to $2000 for a car they paid $50,000 or $60,000 for. In many cases they left without buying, and stayed sore as hell for a long time.
Old 02-21-2009, 06:55 AM   #52
1984 29' Sovereign
Savannah , Missouri
The only questions that begs an answer is..
1.Can it stand the test of time and, more importantly,
2.Can it stand the exposure to water, however that may be defined?
Personally, I feel that it's way past "time" for an overhaul in the materials selected and/or used on the sub-floor. Plywood just doesn't cut it..How many times do we have to go thru this? Replacing floor rot has to be one of the worse, uncalled for task in keeping an Airstream product usable..I mean, when Wally was using it back 50 yrs ago, it was a product that was cost effective and, seemingly durable. We all know now, that's not true. Even Airstream trailer that are not even 5 yrs old have examples already of floor rot~!! We're seeing examples of cracked frames and floor rot way, way too early~!
Do I expect a Airstream to last forever? YOU BETCHA I DO, EVEN AIRSTREAM BRAGS ABOUT THE LONGEVITY OF the AIRSTREAM TRAILER..
Under their banner.. on the UK site...
Reasons to buy an Airstream...I quote..
Longevity
Airstreams can easily last 40 years and more, rather than the conventional trailer's typical life of 10-15 years. When you amortize the purchase price over its length of service, an Airstream actually costs less to own than other trailers. Nearly 70% of all Airstreams ever made are still on the road today!
Doesn't this sounds like an "implied warranty"??
WBCCI 5292 AIR 807
NEU #64
New England Unit
Old 02-21-2009, 08:03 AM   #53
Wink
Maybe, maybe not...
This car was made for the masses in 1953. Well built, basic nothing really special. Has had nothing more than regular maintenance since, driven year round for it's first 25yrs, I have been offered 25 times what it cost new. It's all relative.
Oh, no frame rot.
Name:	5-13-07 cyber-shot #4 005.jpg
PFC
"Tahawus"
RLC
John Prine
Old 02-21-2009, 09:06 AM   #54
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
I believe it is because autos are a manufactured product that is taken on the road. There are several things that have to happen with a moving product that aren't an issue for cottages or houses. Yes, one could argue the auto industry is huge and that 1 or 2 in every 10 jobs tied to it, whereas the RV sector is nowhere near that. Yet I would argue that any vehicle builder, be it Harley-Davidson, a auto builder, a boat builder or any other builder of a vehicle must do the proper homework and listen closely to it's customer base. Those vehicle builders that have not listened to their customers have in fact gone through some really rough times. How many folks have heard or discussed Newmar Homes or Lexington Homes? How many folks rant and rave between Ford vs. Chevy. My sense is that folk scrutinize and talk a lot more about vehicles than homes, because vehicles are more of an emotional purchase (though I know there are detailed home shoppers out there).
People buy houses because of location and amenities, people buy vehicles for vastly different reasons. In many cases homes are not as much of a discretionary purchase as vehicles are, and more specifically, RVs.
Old 02-22-2009, 08:57 AM   #55
1975 25' Tradewind
Central , California
Who gives a crap, if they top the frame with particle board.
Robert Cross said it best. we already pay more. Time to expect more. I was just at a local service shop. They had just done an insurance claim on a 2005, which had a small plumbing leak. It swelled the particle board floor up and destroyed the entire trailer. I was told the small leak ruined the trailer in just a few days. Total loss.
Funny, I was at a dealership and saw a cross section of the wall and floor. It wasn't until I got home when I realized the wood I saw on the display was actually 3/4 ply wood. I'm surprised they spared the extra expense for the display. I mean the display isn't going to get wet mounted on the wall in the show room.
Pepsi is offline   Reply With Quote
Old 02-22-2009, 09:01 AM   #56
1975 25' Tradewind
Oh, nice car Robert...
Storage: How much you pay ? brunoffrance Winterizing, Storage, Carports & Covers 22 09-23-2008 11:48 PM
What should we pay? hampstead38 Buyer Guidelines 71 09-23-2008 07:51 AM
How Much Should I Pay for a... Alumaholic Trailer Values 1 07-23-2006 09:11 PM
Is this too much to pay? lebolewis Axles 8 06-08-2006 07:57 PM
How Much Did You PAY ???? aviontt Upholstery, Blinds, Walls & Interior Finishes 7 11-19-2003 07:55 PM
